I2S DMA
I2S DMA
I would like to inquire about using I2S to transmit voice. If using DMA, I want to generate an interrupt after the data is transmitted, but I do n’t see the DMA interrupt in the ESP32 technical manual, so I would like to ask the people who have used it to share it. Thank you very much for your experience!
Re: I2S DMA
Hi Small Coke
I've done that - It is quite easy just wait for i2s_evt.type == I2S_EVENT_TX_DONE using xQueueReceive(i2s_queue, &i2s_evt, portMAX_DELAY);
The queue handle you will get from you driver install setup call
i2s_driver_install(0, &i2s_config, 10, &i2s_queue);
Let me know if you need more liquor to spice up you coke
/J
/J
double sweepPeriod = 4; // in sec
uint32_t i = 0;
i2s_event_t i2s_evt;
sweepCnt = 0;
freq = 50.0;
angleSpeed = 2*M_PI*freq/sampleRate;
while (1) {
if (i2s_evt.type == I2S_EVENT_TX_DONE)
{ timer_cnt++;
switch (mode) {
case 0 : gate = 1; // Continues
case 1 : // Sweep
if (sweepCnt == 0 ) {
gate = 1;
freq = sweepStartFreq;
} else
{ freq = freq * sweepSpeed;
if ( freq > sweepStopFreq )
{ gate = 0;
//printf("sweepCnt : %d",sweepCnt);
sweepCnt = ( sweepCnt > sweepPeriod*lengthSig) ? 0 : sweepCnt + 1;
} else
{ sweepCnt++;
Analog Digital IC designer / DevOps @ Merus Audio, Copenhagen, Denmark.
We do novel and best in class Audio amplifiers for consumer products.
Programmed assembler for C-64 back in 1980's, learned some electronics - hacking since then
Re: I2S DMA
Thank you very much!I feel you are right, I already have ideas!
Re: I2S DMA
Sorry, I still have some problems. I had some ideas according to your statement before, but when I look back and continue to look at the code you provided, I do n’t know if I did n’t understand it or if your code is incomplete. In normal logic, I think your code is missing some braces. Forgive me for being a little white. There may be some offenses between words, sorry!
Re: I2S DMA
Missing a lot ...
It is only a couple of lines from a signal generator component.
You can check out the full project from the repo :
https://github.com/jorgenkraghjakobsen/sig_gen.git
/j
/j
Users browsing this forum: No registered users and 72 guests
