How to use SPIFFS
rebel88
How to use SPIFFS
Postby rebel88 » Sun Apr 05, 2020 3:14 pm
Hi All.
It is a couple of weeks I'm playing with ESP32 DevKit V1.
Now I'm stduding how to save file on SPIFFS partition.
I can create the partition and save simple file using the example.
Now I want to create an advanced sketch where i have to save several structures on this kind of file.
I know i can use FILE* from stdio librarie, my question is : Can i use fstream library to write and read data?
I have written a class but when i load it on the ESP32 it goes in "Guru meditation"
Guru Meditation Error: Core  0 panic'ed (Unhandled debug exception)
Debug exception reason: BREAK instr
Core 0 register dump:
PC      : 0x3ffb81e0  PS      : 0x00060220  A0      : 0x0a6d305b  A1      : 0x80058bc2
A2      : 0x3ffb5640  A3      : 0x3ffb6778  A4      : 0x3ffae920  A5      : 0x3ffb8228
A6      : 0x00000000  A7      : 0x00000000  A8      : 0x00000000  A9      : 0x800fe3de
A10     : 0x3ffb5660  A11     : 0x3ffb6778  A12     : 0x3f402a04  A13     : 0x0000001a
A14     : 0x00000080  A15     : 0x0000001a  SAR     : 0x00000001  EXCCAUSE: 0x00000001
EXCVADDR: 0x0a6d303b  LBEG    : 0x3ffb6778  LEND    : 0x3ffae920  LCOUNT  : 0xfffffffd
ELF file SHA256: 6151d98a471f83575f4f2f8fdcd38cd7fa9000faa02e486e9ceb0468da88ca51
Backtrace: 0x3ffb81dd:0x80058bc2 |<-CORRUPTED
Rebooting...
ets Jun  8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:6864
ho 0 tail 12 room 4
load:0x40078000,len:14076
load:0x40080400,len:4304
entry 0x400806e8
I (75) boot: Chip Revision: 1
I (75) boot_comm: chip revision: 1, min. bootloader chip revision: 0
I (41) boot: ESP-IDF v4.0-dirty 2nd stage bootloader
I (41) boot: compile time 16:47:40
I (41) boot: Enabling RNG early entropy source...
I (46) boot: SPI Speed      : 40MHz
I (51) boot: SPI Mode       : DIO
I (55) boot: SPI Flash Size : 4MB
I (59) boot: Partition Table:
I (62) boot: ## Label            Usage          Type ST Offset   Length
I (70) boot:  0 nvs              WiFi data        01 02 00009000 00006000
I (77) boot:  1 phy_init         RF data          01 01 0000f000 00001000
I (84) boot:  2 factory          factory app      00 00 00010000 00100000
I (92) boot:  3 storage          Unknown data     01 82 00110000 000f0000
I (99) boot: End of partition table
I (104) boot_comm: chip revision: 1, min. application chip revision: 0
I (111) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x174e8 ( 95464) map
I (154) esp_image: segment 1: paddr=0x00027510 vaddr=0x3ffb0000 size=0x0218c (  8588) load
I (158) esp_image: segment 2: paddr=0x000296a4 vaddr=0x40080000 size=0x00400 (  1024) load
0x40080000: _WindowOverflow4 at C:/Users/Admin/esp-idf/components/freertos/xtensa_vectors.S:1778
I (161) esp_image: segment 3: paddr=0x00029aac vaddr=0x40080400 size=0x06564 ( 25956) load
I (181) esp_image: segment 4: paddr=0x00030018 vaddr=0x400d0018 size=0x423dc (271324) map
0x400d0018: _stext at ??:?
I (278) esp_image: segment 5: paddr=0x000723fc vaddr=0x40086964 size=0x036c8 ( 14024) load
0x40086964: rtc_init at C:/Users/Admin/esp-idf/components/soc/esp32/rtc_init.c:70
I (290) boot: Loaded app from partition at offset 0x10000
I (291) boot: Disabling RNG early entropy source...
I (291) cpu_start: Pro cpu up.
I (295) cpu_start: Application information:
I (299) cpu_start: Project name:     template-app
I (305) cpu_start: App version:      1
I (309) cpu_start: Compile time:     Apr  5 2020 16:47:28
I (315) cpu_start: ELF file SHA256:  6151d98a471f8357...
I (321) cpu_start: ESP-IDF:          v4.0-dirty
I (327) cpu_start: Starting app cpu, entry point is 0x400811c8
0x400811c8: call_start_cpu1 at C:/Users/Admin/esp-idf/components/esp32/cpu_start.c:272
I (313) cpu_start: App cpu up.
I (337) heap_init: Initializing. RAM available for dynamic allocation:
I (344) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (350) heap_init: At 3FFB47E8 len 0002B818 (174 KiB): DRAM
I (356) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (363) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (369) heap_init: At 4008A02C len 00015FD4 (87 KiB): IRAM
I (375) cpu_start: Pro cpu start user code
I (397) spi_flash: detected chip: generic
I (397) spi_flash: flash io: dio
I (397) cpu_start: Starting scheduler on PRO CPU.
I know that the class and the code are good because i have tried it on CodeBlocks but it is pure C++ compiler.
My first answer is I can't use fstream library to write and read data.
Could Someone help me understand what is appening?
Thankyou in advance.
Re: How to use SPIFFS
Postby Sprite » Sun Apr 05, 2020 7:46 pm
That's pretty much impossible to say from the coredump... can you show your code here?
rebel88
Postby rebel88 » Mon Apr 06, 2020 6:40 am
This is my code,
Main.cpp:
it first main is to create a way to test the class :
/* Hello World Example
#include <stdio.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_spi_flash.h"
#include "esp_spiffs.h"
#include "esp_log.h"
#include "PresetIO.h"
static const char *TAG = "example";
extern "C" void app_main(void)
    PresetIO PresetLoadSave;
    //----- CREATE EFFECT------
    singleEffect_t Effect1={1,10,20,30,40};
    singleEffect_t Effect2={1,50,60,70,80};
    singleEffect_t Effect3={0,90,100,110,120};
    singleEffect_t Effect4={0,130,140,150,160};
    singleEffect_t Effect5={1,170,180,190,200};
    singleEffect_t Effect6={0,210,220,230,240};
    //----- CREATE PRESET------
    MultiEffect_t Preset_1 ={Effect1,Effect2,Effect3,Effect4,Effect5,Effect6};
    MultiEffect_t Preset_2 ={Effect2,Effect2,Effect3,Effect4,Effect5,Effect6};
    MultiEffect_t Preset_3 ={Effect1,Effect1,Effect3,Effect6,Effect5,Effect6};
    MultiEffect_t ExtractPreset={};
    //---------- Initialize File partition
    ESP_LOGI(TAG, "Initializing SPIFFS");
    esp_vfs_spiffs_conf_t conf = {
      .base_path = "/spiffs",
      .partition_label = NULL,
      .max_files = 5,
      .format_if_mount_failed = true
        // Use settings defined above to initialize and mount SPIFFS filesystem.
    // Note: esp_vfs_spiffs_register is an all-in-one convenience function.
    esp_err_t ret = esp_vfs_spiffs_register(&conf);
    if (ret != ESP_OK) {
        if (ret == ESP_FAIL) {
            ESP_LOGE(TAG, "Failed to mount or format filesystem");
        } else if (ret == ESP_ERR_NOT_FOUND) {
            ESP_LOGE(TAG, "Failed to find SPIFFS partition");
            ESP_LOGE(TAG, "Failed to initialize SPIFFS (%s)", esp_err_to_name(ret));
        return;
    size_t total = 0, used = 0;
    ret = esp_spiffs_info(NULL, &total, &used);
        ESP_LOGE(TAG, "Failed to get SPIFFS partition information (%s)", esp_err_to_name(ret));
        ESP_LOGI(TAG, "Partition size: total: %d, used: %d", total, used);
    //---------- END Initialize File partition
    //----- Show PresetLoadSave banks we would use
    cout<<"Show Preset 1";
    PresetLoadSave.showPresetBank(1);
    cout<<"Show Preset 5";
    PresetLoadSave.showPresetBank(5);
    cout<<"Show Preset 99";
    PresetLoadSave.showPresetBank(99);
    cout<<"\n---------------INSERT EFFECTS-----------------------\n";
    PresetLoadSave.insertMultiEffect(uint8_t(1),Preset_1);
    PresetLoadSave.insertMultiEffect(uint8_t(5),Preset_2);
    PresetLoadSave.insertMultiEffect(uint8_t(99),Preset_3);
    cout<<"\nShow Inserted Preset 1\n";
    cout<<"\nShow Inserted Preset 5\n";
    cout<<"\nShow Inserted Preset 99\n";
    cout<<"\n---------------SAVE EFFECTS-----------------------\n";
    PresetLoadSave.savePresetBankFile();
    cout<<"\n---------------EXTRACT EFFECTS-----------------------\n";
    ExtractPreset =PresetLoadSave.getMultiEffect(5);
    cout << "\nExtractPreset from position 5: ";
    for (uint8_t i=0; i<NUMB_PED; i++)
        cout << "\nStatus: ";
        printf("%3d",ExtractPreset.Pedal[i].status);
        cout << "\tPot1 Value:  ";
        printf("%3d",ExtractPreset.Pedal[i].pot_1);
        cout << "\tPot2 Value:  ";
        printf("%3d",ExtractPreset.Pedal[i].pot_2);
        cout << "\tPot3 Value:  ";
        printf("%3d",ExtractPreset.Pedal[i].pot_3);
        cout << "\tPot4 Value:  ";
        printf("%3d",ExtractPreset.Pedal[i].pot_4);
    PresetLoadSave.insertMultiEffect(uint8_t(10),ExtractPreset);
    cout<<"\nShow Inserted Preset 10\n";
    PresetLoadSave.showPresetBank(10);
    cout<<"\n---------------LOAD EFFECTS-----------------------\n";
    PresetLoadSave.loadPresetBankFile();
    cout<<"\n---------------CHECK EFFECTS-----------------------\n";
    cout<<"\nPosition 10 should be empty after load\n";
    cout<<"\nShow Inserted Preset 1";
    cout<<"\nShow Inserted Preset 5";
    cout<<"\nShow Inserted Preset 99";
    cout<<"\nShow Inserted Preset 10";
The class PresetIO.cpp is used to manage structure and to save and load data from file using fstream:
PresetIO::PresetIO()
    //ctor
PresetIO::~PresetIO()
    //dtor
void PresetIO::printPedal(singleEffect_t sp)
    printf("%3d",sp.status);
    printf("%3d",sp.pot_1);
    printf("%3d",sp.pot_2);
    printf("%3d",sp.pot_3);
    printf("%3d",sp.pot_4);
void PresetIO::printMultiEffect(MultiEffect_t me)
        printPedal(me.Pedal[i]);
void PresetIO::insertMultiEffect(uint8_t id,MultiEffect_t me)
    PresetBanks[id] = me;
    printf("\nMulti Effect saved in %d location\n",id);
    printMultiEffect(PresetBanks[id]);
void PresetIO::showPresetBank(uint8_t id)
    printf("\nPrtint Effect saved in location %d",id);
    cout<<endl;
MultiEffect_t PresetIO::getMultiEffect(uint8_t id)
    return PresetBanks[id];
uint8_t PresetIO::savePresetBankFile()
    uint8_t result;
    ofstream output_file(SAVE_FILE_NAME, ios::binary);
    result=output_file.rdstate(); //check if file is correcyly opened
    if(!result)
        output_file.write((char*)&PresetBanks, sizeof(PresetBanks));
        output_file.close();
        printf("\nFile Saved Correctly, tot %d KB",sizeof(PresetBanks)/1024);
    }else
        cout<<"\nError While saving File";
    return result;
uint8_t PresetIO::loadPresetBankFile()
    uint8_t result;
    ifstream input_file(SAVE_FILE_NAME, ios::binary);
    result=input_file.rdstate(); //check if file is correcyly opened
    if(!result)
        input_file.read((char*)&PresetBanks, sizeof(PresetBanks));
        printf("\nFile Correctly Loaded,tot %d KB",sizeof(PresetBanks)/1024);
    }else
        cout<<"Error While saving File";
    return result;
and this is the PrestIO.h :
#ifndef PRESETIO_H
#define PRESETIO_H
#include "sdv_t.h"
#include <iostream>
#include <fstream>
#include <string.h>
#define SAVE_FILE_NAME "/spiffs/effects.data"
using namespace std;
class PresetIO
    public:
        PresetIO();
        virtual ~PresetIO();
        * @brief    insertMultiEffect is used to insert a generic MultiEffect Variabile in defined position
        * @param id value from 0 to NUMB_PRESET-1 identify the position where store data
        * @param me Multieffect variable identify values of all 6 Effects
        void insertMultiEffect(uint8_t id,MultiEffect_t me);
        * @brief    showPresetBank is used to print on screen what is written in specific PresetBanks position
        * @param id value from 0 to NUMB_PRESET-1 identify the position from where read data
        void showPresetBank(uint8_t id);
        * @brief    getMultiEffect is used to extract a MultiEffect Structure from saved PresetBanks
        * @return MultiEffect_t, the structure extracted from PresetBanks
        MultiEffect_t getMultiEffect(uint8_t id);
        * @brief    savePresetBankFile is a function used to save PresetBanks on file
        *           the file name is SAVE_FILE_NAME, it uses ofstream output_file
        * @return   returns the output_file.rdstate status, if 0 OK else there is a problem
        uint8_t savePresetBankFile();
        * @brief    loadPresetBankFile is a function used to Load PresetBanks from file
        *           the file name is SAVE_FILE_NAME, it uses ifstream input_file
        * @return   returns the input_file.rdstate status, if 0 OK else there is a problem
        uint8_t loadPresetBankFile();
    protected:
    private:
        *@brief PresetBanks is an array of NUMB_PRESET(default 100) possible Preset
        *       used to save and load info from files
        *       PresetBank:
        *           o 99*Multi Effect
        *               o 6*single Effects
        MultiEffect_t PresetBanks[NUMB_PRESET]={};
        * @brief    printPedal is used to print on screen what is inside one of MultiEffect Pedals
        * @param    sp is the singleEffect passed the the function
        void printPedal(singleEffect_t sp);
        * @brief    printPedal is used to print on screen what is inside a MultiEffect
        * @param    me is the MultiEffect passed the the function
        void printMultiEffect(MultiEffect_t me);
#endif // PRESETIO_H
this last file is an header" sdv_t.h"used to create structures types :
#ifndef SDV_T_H_INCLUDED
#define SDV_T_H_INCLUDED
#include <iostream>
#define NUMB_PED      6  //NUMBER OF PEDAL USED
#define NUMB_PRESET 100  //NUMBER OF PRESET
* singleEffect_t is a structure identify the single Pedal made of:
* Status (on/off)
* 4* Pot values
struct singleEffect_t
    uint8_t status; //on off status of the pedal
    uint8_t pot_1;  //potentiometer 1 value
    uint8_t pot_2;  //potentiometer 2 value
    uint8_t pot_3;  //potentiometer 3 value
    uint8_t pot_4;  //potentiometer 4 value
* MultiEffect_t is a structure identify the single preset of all NUMB_PED pedals
struct MultiEffect_t
    singleEffect_t Pedal[NUMB_PED];
#endif // SDV_T_H_INCLUDED
and this last file is the SPIFFS partition table setup "partitions.csv" :
# Name,   Type, SubType, Offset,  Size, Flags
# Note: if you have increased the bootloader size, make sure to update the offsets to avoid overlap
nvs,      data, nvs,     0x9000,  0x6000,
phy_init, data, phy,     0xf000,  0x1000,
factory,  app,  factory, 0x10000, 1M,
storage,  data, spiffs,  ,        0xF0000,
I have attached the entrire project I have written.
The only configuration to do is in menuconfig :
- Partition Table \ Custom Partition Table,
-select partitions.csv
-Offset 0x8000
I have already used the partition.csv and correctly set menuconfig to test spiffs before.
I think the wrong part is on fstream because is the only new thing i'm using in this sketch.
Thakyou for your help.
15_SaveLoad_SPIFFS.rar
(9.37 KiB) Downloaded 459 times
rebel88
Postby rebel88 » Mon Apr 06, 2020 7:01 am
HI ALL, I HAVE A BIG UPDATE.
I have solved my problem reading better the error log.
It was written that i have a "overflow of the heap"
So i have changed the declaration of my object using pointer, in this way the memory scope has changed.
PresetIO *PresetLoadSave = new PresetIO;
Now i can build and use my sketc, so the problem was in the memory occupation.
This is my new main code if you are interested :
#include <stdio.h>
      .max_files = 5,
        return;
    PresetLoadSave->showPresetBank(1);
    PresetLoadSave->showPresetBank(5);
    PresetLoadSave->showPresetBank(99);
    PresetLoadSave->insertMultiEffect(uint8_t(1),Preset_1);
    PresetLoadSave->insertMultiEffect(uint8_t(5),Preset_2);
    PresetLoadSave->insertMultiEffect(uint8_t(99),Preset_3);
    PresetLoadSave->savePresetBankFile();
    ExtractPreset =PresetLoadSave->getMultiEffect(5);
    PresetLoadSave->insertMultiEffect(uint8_t(10),ExtractPreset);
    PresetLoadSave->showPresetBank(10);
    PresetLoadSave->loadPresetBankFile();
    while(1)
If you have suggestion I'm here to read you.
Thankyou.
Users browsing this forum: ChatGPT-User and 6 guests
