esp32 BMC_SBUS porting
cepics
Postby cepics » Thu Apr 09, 2020 3:15 pm
I'm trying to port an Arduino Mega sketch, using BMC_SBUS, to esp32!!
https://github.com/boldstelvis/BMC_SBUS ... /README.md
to use this: https://www.kinowheels.com/
with this: https://forum.dji.com/thread-167232-1-1.html
this is the connections: https://forum11.djicdn.com/data/attachm ... htjjsl.png
this is the Arduino Mega sketch connected to the ronin D-bus (it works!! I can move the ronin X and Y axis):
#define BAUDRATE 100000  // oder  100000 115200
#define SERIALPORT Serial  // - uncomment this line if using an arduino based board with more than one HW serial port
class BMC_SBUS
  public:
    uint8_t sbusData[25];
    int16_t servos[18];
    void begin(void);
    void Servo(uint8_t ch, int16_t position);
    void Send(void);
    void Update(void);
  private:
    uint8_t byte_in_sbus;
    uint8_t bit_in_sbus;
    uint8_t ch;
    uint8_t bit_in_servo;
void BMC_SBUS::begin()
  //intialise private data arrays
  //sbus_data is formatted for correct serial output
  //note that the actual 11bit sbus data for each channel is embedded across multiple data bytes in a very stange order
  //byte 1 and bytes 24 and 25 should be left as is
  //the first is a start byte, the last is a stop byte and the second last holds various flags
  //servos is the internal per channel position and is more straightforward - one int_16 per channel
  uint8_t loc_sbusData[25] = {0x0f,0x01,0x04,0x20,0x00,0xff,0x07,0x40,0x00,0x02,0x10,0x80,0x2c,0x64,0x21,0x0b,0x59,0x08,0x40,0x00,0x02,0x10,0x80,0x00,0x00};
  int16_t loc_servos[18]   = {1023,1023,1023,1023,1023,1023,1023,1023,1023,1023,1023,1023,1023,1023,1023,1023,0,0};
  //setup serial port to transmit at 100k baud and use 1 parity and 2 stop bits
  SERIALPORT.begin(BAUDRATE, SERIAL_8E2);
  //setup public data arrays
  memcpy(sbusData,loc_sbusData,25);
  memcpy(servos,loc_servos,18);
void BMC_SBUS::Servo(uint8_t ch, int16_t position)
  //set servo position on single channel
  if ((ch>0)&&(ch<=16))
    constrain (position, 0, 2048); //keep within min/max values
    servos[ch-1] = position; //expects a non zero starting index to the channel
void BMC_SBUS::Send(void)
  //send data over serial port
  SERIALPORT.write(sbusData, 25); //according to docs for Serial we can send the array along as is without a loop
void BMC_SBUS::Update(void)
  //update positions for all servo channels within the SBUS data frame
  //ignores digital servos and any failsafe mode stuff that was originally written
  //clear out existing sbus data for all channel data bytes
  //ignores first and last bytes in the array (start and stop bytes)
  //mapping loop relies on initial 0 values - do not omit this step!
  uint8_t i;
  for (i=1; i<24; i++)
    sbusData[i] = 0;
  //reset counters
  ch = 0;
  bit_in_servo = 0;
  byte_in_sbus = 1;
  bit_in_sbus = 0;
  //format sbus data - maps sevo data array to sbus data array 1bit at a time
  //correctly deals with the little endian byte order in the process
  for (i=0; i<176; i++) //16channels*11bits = 176bits
    if (servos[ch] & (1<<bit_in_servo)) //bitwise AND to check if the correct servo databit is set to 1
      sbusData[byte_in_sbus] |= (1<<bit_in_sbus); //bitwise OR sets the correct sbus databit if true
    //increment bit counters
    bit_in_sbus++;
    bit_in_servo++;
    //if end of sbus byte reset sbus bit counter and increment sbus byte counter
    if (bit_in_sbus == 8)
      bit_in_sbus = 0;
      byte_in_sbus++;
    // if we have reached bit 11 in the servo data increment channel index and reset servo bit counter
    if (bit_in_servo == 11)
      bit_in_servo = 0;
      ch++;
//Declare BMC_SBUS Object
BMC_SBUS mySBUS;
// Sbus delay value
const int sbusWAIT = 7;      //frame timing delay in msecs
// Declare sbus control channels
int panChannel = 1;
int tiltChannel = 2;
int rollChannel = 4;
// Declare Kinowheels Stuff
int XA_SIG=0, XB_SIG=1, YA_SIG=0, YB_SIG=1, pulsesX, pulsesY;
// Declare Stuff for calculating Speed
int xStampEnd=0, yStampEnd=0, timeStampEnd=0, xPassed, yPassed, timePassed, sendX=1023, sendY=1023;
  // Serial.begin(100000); überflüssig, weil in MC_SBUS enthalten
  // Start  KinoWheels Stuff
  attachInterrupt(0, XA_RISE, RISING); // Pin 2
  attachInterrupt(1, XB_RISE, RISING); // Pin 3
  attachInterrupt(4, YA_RISE, RISING); // Pin 19
  attachInterrupt(5, YB_RISE, RISING); // Pin 18
   // Start BMC_SBUS object
  mySBUS.begin();
  for (int i=0; i<1; i++){        //SBUS needs data every 7 Milliseconds. I repeat it three times for some time to pass for calculating speeds.
  mySBUS.Servo(tiltChannel,sendY);
  mySBUS.Servo(panChannel,sendX);
  // Update SBUS object and send data
  mySBUS.Update();
  mySBUS.Send();
  delay(sbusWAIT);
 timePassed = millis() - timeStampEnd;
 xPassed = xStampEnd - pulsesX;
 yPassed = pulsesY - yStampEnd;
 sendX = 1023 + 100* xPassed / timePassed;
 sendY = 1023 + 100* yPassed / timePassed;
for (int i=0; i<1; i++){          //Maybe this one is not needed. Will find it out later
  mySBUS.Update();
  mySBUS.Send();
  delay(sbusWAIT);
 xStampEnd = pulsesX;
 yStampEnd = pulsesY;
 timeStampEnd = millis();
//Rotary Encoder Stuff by KinoWheels
void XA_RISE(){
 detachInterrupt(0);
 //delay(1);
 XA_SIG=1;
 if(XB_SIG==0)
 pulsesX++;//moving forward
 if(XB_SIG==1)
 pulsesX--;//moving reverse
 attachInterrupt(0, XA_FALL, FALLING);
void XA_FALL(){
  detachInterrupt(0);
  //delay(1);
 XA_SIG=0;
 if(XB_SIG==1)
 if(XB_SIG==0)
void XB_RISE(){
 detachInterrupt(1);
 //delay(1);
 XB_SIG=1;
 if(XA_SIG==1)
 if(XA_SIG==0)
 attachInterrupt(1, XB_FALL, FALLING);
void XB_FALL(){
 detachInterrupt(1);
 //delay(1);
 XB_SIG=0;
 if(XA_SIG==0)
 if(XA_SIG==1)
void YA_RISE(){
 detachInterrupt(4);
 //delay(1);
 YA_SIG=1;
 if(YB_SIG==0)
 pulsesY++;//moving forward
 if(YB_SIG==1)
 pulsesY--;//moving reverse
 attachInterrupt(4, YA_FALL, FALLING);
void YA_FALL(){
  detachInterrupt(4);
  //delay(1);
 YA_SIG=0;
 if(YB_SIG==1)
 if(YB_SIG==0)
void YB_RISE(){
 detachInterrupt(5);
 //delay(1);
 YB_SIG=1;
 if(YA_SIG==1)
 if(YA_SIG==0)
 attachInterrupt(5, YB_FALL, FALLING);
void YB_FALL(){
 detachInterrupt(5);
 //delay(1);
 YB_SIG=0;
 if(YA_SIG==0)
 if(YA_SIG==1)
How can I port to M5Stack (esp32)?
this in what I done ... but I have not Y axe control....
M5Stack---------ronin D-bus
grd---------------grd
5V----------------5V
TXD2(G17)------data
#include <M5Stack.h>
#include <ESP32Encoder.h>
ESP32Encoder encoderX;
ESP32Encoder encoderY;
#define SERIALPORT Serial2  // - uncomment this line if using an arduino based board with more than one HW serial port
class BMC_SBUS
  public:
    int16_t servos[18];
    void begin(void);
    void Send(void);
    void Update(void);
  private:
    uint8_t ch;
  uint8_t loc_sbusData[25] = {0x0f, 0x01, 0x04, 0x20, 0x00, 0xff, 0x07, 0x40, 0x00, 0x02, 0x10, 0x80, 0x2c, 0x64, 0x21, 0x0b, 0x59, 0x08, 0x40, 0x00, 0x02, 0x10, 0x80, 0x00, 0x00};
  int16_t loc_servos[18]   = {1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 0, 0};
  memcpy(sbusData, loc_sbusData, 25);
  memcpy(servos, loc_servos, 18);
  if ((ch > 0) && (ch <= 16))
    servos[ch - 1] = position; //expects a non zero starting index to the channel
  uint8_t i;
  for (i = 1; i < 24; i++)
    sbusData[i] = 0;
  //reset counters
  ch = 0;
  bit_in_servo = 0;
  byte_in_sbus = 1;
  bit_in_sbus = 0;
  for (i = 0; i < 176; i++) //16channels*11bits = 176bits
    if (servos[ch] & (1 << bit_in_servo)) //bitwise AND to check if the correct servo databit is set to 1
      sbusData[byte_in_sbus] |= (1 << bit_in_sbus); //bitwise OR sets the correct sbus databit if true
    bit_in_sbus++;
    bit_in_servo++;
      bit_in_sbus = 0;
      byte_in_sbus++;
      bit_in_servo = 0;
      ch++;
BMC_SBUS mySBUS;
// Sbus delay value
int panChannel = 1;
float pulsesX, pulsesY;
int xStampEnd = 0;
int yStampEnd = 0;
int timeStampEnd = 0;
int xPassed;
int yPassed;
int timePassed;
int sendX;// ??????
int sendY;// ??????
// Declare Poti Values
int potiX = 100;
int potiY = 100;
bool PANTILTtoggle = 0;
  M5.begin();
  // clear the encoder's raw count and set the tracked count to zero
  encoderX.clearCount();
  encoderY.clearCount();
  // Attache pins for use as encoder pins
  encoderX.attachHalfQuad(2, 3);
  encoderY.attachHalfQuad(36, 35);
  M5.update();
  sendX = 1023;
  sendY = 1023;
  mySBUS.begin();
  pulsesX = encoderX.getCount();
  pulsesY = encoderY.getCount();
  for (int i = 0; i < 1; i++) {   //SBUS needs data every 7 Milliseconds. I repeat it three times for some time to pass for calculating speeds.
    mySBUS.Servo(tiltChannel, sendY);
    mySBUS.Servo(panChannel, sendX);
    mySBUS.Update();
    mySBUS.Send();
    delay(sbusWAIT);
  M5.update();
    sendX = 1023 + 100 * xPassed / timePassed;
    sendY = 1023 + 100 * yPassed / timePassed;
  if (sendX > 2047) {
    sendX = 2047;
  if (sendX < 0) {
    sendX = 0;
  if (sendY > 2047) {
    sendY = 2047;
  if (sendY < 0) {
    sendY = 0;
  for (int i = 0; i < 1; i++) {     //Maybe this one is not needed. Will find it out later
    mySBUS.Update();
    mySBUS.Send();
    delay(sbusWAIT);
  M5.update();
the strange thing is that the information about X axe, go to the machine connected at G17 (TXD2), but not the Y one..
I'm using an inverter on the TX-----RX line...for (d-bus/s-bus)
tnks a lot
Users browsing this forum: Baidu [Spider], ChatGPT-User and 1 guest
