problem with esp-idf 4.0 and assembler
Posted: Fri Apr 17, 2020 1:53 am
I am in the process of converting a program to esp-idf 4.0. I have installed 4.0 according to the vanilla instructions.
While assembling a .S file with the following lines:
In which I declare a pile of assembler variables,
And then the first few lines of the .text segment
immediately followed, with an intervening comment, by
I get the following errors out of the assembler as invoked with a simple “idf.py build” command:
It looks to me like the assembler is barfing over perfectly normal directives and mnemonics, which used to work with esp-idf 3.3 without error.
I’m seeing other problems as well as I migrate to 4.0, but I’d first like to resolve this.
Thanks.
Code: Untitled.asm Select all
54 // Data segment
55 .bss
56 .global LastReadHi // Last reported read hi word
110 // Code segment
111 .text
112 .global entry
113 entry:
124 // First count and report the number of times ULP has cycled
125 move r3, ULPcycles
126 ld r0, r3, 0
127 add r0, r0, 1
128 st r0, r3, 0Code: Untitled.txt Select all
P.S.obj.d -o esp-idf/ulp/CMakeFiles/__idf_ulp.dir/PartBinULP.S.obj -c ../components/ulp/PartBinULP.S
../components/ulp/PartBinULP.S: Assembler messages:
../components/ulp/PartBinULP.S:55: Error: unknown pseudo-op: `.bss'
../components/ulp/PartBinULP.S:125: Error: unknown opcode or format name 'move'
../components/ulp/PartBinULP.S:126: Error: unknown opcode or format name 'ld'
../components/ulp/PartBinULP.S:127: Error: bad register name: r0
../components/ulp/PartBinULP.S:127: Error: junk at end of line, first unrecognized character is `r'
../components/ulp/PartBinULP.S:127: Internal error in ignore_rest_of_line at /builds/idf/crosstool-NG/.build/HOST-i686-w64-mingw32/xtensa-esp32-elf/src/binutils/gas/read.c:3762.
Please report this bug.I’m seeing other problems as well as I migrate to 4.0, but I’d first like to resolve this.
Thanks.
