ESP32-CAM Guru Meditation Error: Core 1 panic'ed (LoadStoreAlignment)
sky5media
Postby sky5media » Fri Apr 17, 2020 5:49 am
Dear Community,
I am posting it here too because I am not sure where the problem is, is it esp-idf or something else.
Development Board: ESP32-CAM
Module or chip used: ESP32-S
IDF version: v4.0
Build System: Make
Compiler version: xtensa-esp32-elf-gcc (crosstool-NG esp-2019r2) 8.2.0
I am trying to build latest micropython for ESP32-CAM. Board has 8M PSRAM chip (IPUS IPS1704L-SQ)
When trying to allocate 160 KB buffer with:
heap_caps_calloc(_fb2->size, 1, MALLOC_CAP_SPIRAM)
I am getting Guru Meditation Error
Guru Meditation Error: Core 1 panic'ed (LoadStoreAlignment). Exception was unhandled.
I tried both CONFIG_SPIRAM_USE_CAPS_ALLOC=y and CONFIG_SPIRAM_USE_MALLOC=y
same result
Some debugging info:
heap_caps_get_free_size(MALLOC_CAP_DEFAULT) -> -1431534259 (negative)
heap_caps_get_free_size(MALLOC_CAP_INTERNAL) -> 172184
heap_caps_get_free_size(MALLOC_CAP_SPIRAM) -> -1431655771 (negative)
heap_caps_get_free_size(MALLOC_CAP_8BIT) -> -1431501531 (negative)
heap_caps_get_free_size(MALLOC_CAP_32BIT) -> -1431483587 (negative)
heap_caps_get_free_size(MALLOC_CAP_DMA) -> 154240
esp_get_free_heap_size() -> 2863433037
esp_spiram_get_size() -> 8388608
esp_himem_get_free_size() -> 4325376
esp_himem_get_phys_size() -> 4325376
esp_himem_reserved_area_size() -> 131072
Please notice that heap_caps_get_free_size(MALLOC_CAP_SPIRAM) returns negative value.
himem API seems to be working and can recognize and use PSRAM chip.
When using CONFIG_SPIRAM_USE_MEMMAP=y
heap_caps_get_free_size(MALLOC_CAP_SPIRAM) is obviously 0, but
(uint8_t*) calloc(_fb2->size, 1);
ain't working either
When dumping or trying to get info about heap with MALLOC_CAP_SPIRAM getting same Guru Meditation Error after which device restarts
Same behavior on 2 different boards of the same type
Board images:
Depending on CONFIG_SPIRAM_USE I am getting Guru Meditation Error either when calling :
or when doing:
(uint8_t*) heap_caps_calloc(_fb2->size, 1, MALLOC_CAP_SPIRAM | MALLOC_CAP_8BIT);
Debug Logs
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:5200
ho 0 tail 12 room 4
load:0x40078000,len:14032
load:0x40080400,len:3800
entry 0x4008063c
I (579) psram: This chip is ESP32-D0WD
I (579) spiram: Found 64MBit SPI RAM device
I (579) spiram: SPI RAM mode: flash 40m sram 40m
I (582) spiram: PSRAM initialized, cache is in low/high (2-core) mode.
I (589) cpu_start: Pro cpu up.
I (593) cpu_start: Application information:
I (598) cpu_start: Compile time:     Apr 16 2020 21:10:15
I (604) cpu_start: ELF file SHA256:  0000000000000000...
I (610) cpu_start: ESP-IDF:          v4.0
I (614) cpu_start: Starting app cpu, entry point is 0x40083484
I (606) cpu_start: App cpu up.
I (1463) spiram: SPI SRAM memory test OK
I (1464) heap_init: Initializing. RAM available for dynamic allocation:
I (1464) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM
I (1470) heap_init: At 3FFB6388 len 00001C78 (7 KiB): DRAM
I (1476) heap_init: At 3FFB9A20 len 00004108 (16 KiB): DRAM
I (1482) heap_init: At 3FFBDB5C len 00000004 (0 KiB): DRAM
I (1489) heap_init: At 3FFCCD18 len 000132E8 (76 KiB): DRAM
I (1495) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (1501) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1508) heap_init: At 4009B9C4 len 0000463C (17 KiB): IRAM
I (1514) cpu_start: Pro cpu start user code
I (1519) spiram: Adding pool of 3968K of external SPI memory to heap allocator
I (1551) esp_himem: Initialized. Using last 4 32KB address blocks for bank switching on 4224 KB of physical memory.
I (1552) spi_flash: detected chip: generic
I (1556) spi_flash: flash io: dio
I (1561) cpu_start: Starting scheduler on PRO CPU.
I (1571) spiram: Reserving pool of 32K of internal memory for DMA/internal allocations
MicroPython v1.12-263-g8d34344dc-dirty on 2020-04-16; ESP32 module (spiram) with ESP32
Type "help()" for more information.
>>> import camera
>>> camera.init()
I (1060751) sccb: pin_sda 26 pin_scl 27
I (1060751) gpio: GPIO[32]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1060881) gpio: GPIO[35]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1060881) gpio: GPIO[34]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1060891) gpio: GPIO[39]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1060901) gpio: GPIO[36]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1060911) gpio: GPIO[21]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1060921) gpio: GPIO[19]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1060931) gpio: GPIO[18]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1060941) gpio: GPIO[5]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1060951) gpio: GPIO[25]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1060961) gpio: GPIO[23]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1060971) gpio: GPIO[22]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1060981) camera: Allocating 1 frame buffers (160 KB total)
Core 1 register dump:
PC      : 0x40094aee  PS      : 0x00060133  A0      : 0x80096a82  A1      : 0x3ffd8820
A2      : 0x66555559  A3      : 0x00060520  A4      : 0x00000001  A5      : 0x0000abab
A6      : 0xb33fffff  A7      : 0x00000001  A8      : 0x0000cdcd  A9      : 0x3ffd8920
A10     : 0x0000abab  A11     : 0x00000000  A12     : 0x00000003  A13     : 0x3ffc8534
A14     : 0x3ffba7ec  A15     : 0x00000000  SAR     : 0x00000004  EXCCAUSE: 0x00000009
EXCVADDR: 0x66555559  LBEG    : 0x400973ad  LEND    : 0x400973bd  LCOUNT  : 0xfffffff8
ELF file SHA256: 0000000000000000000000000000000000000000000000000000000000000000
Backtrace: 0x40094aeb:0x3ffd8820 0x40096a7f:0x3ffd8850 0x40096ab4:0x3ffd8870 0x40085c64:0x3ffd88a0 0x40085c9a:0x3ffd88c0 0x40098a92:0x3ffd88e0 0x40098ab4:0x3ffd8900 0x4016ae0d:0x3ffd8920 0x4016b285:0x3ffd89d0 0x400fbb07:0x3ffd8a00 0x400e3d6b:0x3ffd8a20 0x400dfdd1:0x3ffd8a40 0x400dff0a:0x3ffd8a60 0x400ee063:0x3ffd8a80 0x400e3f40:0x3ffd8b20 0x400dfdd1:0x3ffd8b70 0x400dfdfa:0x3ffd8b90 0x40106468:0x3ffd8bb0 0x4010668a:0x3ffd8c40 0x400f7224:0x3ffd8c80 0x40093df9:0x3ffd8cb0
Rebooting...
According to
SPIRAM should be added to heap, but when trying to allocate a buffer or dump or get info about heap with caps MALLOC_CAP_SPIRAM getting
and board restarts
sdkconfig
CONFIG_ESP32_SPIRAM_SUPPORT=y
CONFIG_SPIRAM_BOOT_INIT=y
CONFIG_SPIRAM_TYPE_ESPPSRAM64=y
CONFIG_SPIRAM_SIZE=-1
CONFIG_SPIRAM_SPEED_40M=y
CONFIG_SPIRAM_MEMTEST=y
CONFIG_SPIRAM_CACHE_WORKAROUND=y
CONFIG_SPIRAM_BANKSWITCH_ENABLE=y
CONFIG_SPIRAM_BANKSWITCH_RESERVE=4
CONFIG_SPIRAM_MALLOC_ALWAYSINTERNAL=16384
CONFIG_SPIRAM_MALLOC_RESERVE_INTERNAL=32768
CONFIG_SPIRAM_ALLOW_BSS_SEG_EXTERNAL_MEMORY=
CONFIG_ESP32_DEFAULT_CPU_FREQ_240=y
CONFIG_TASK_WDT_CHECK_IDLE_TASK_CPU0=n
CONFIG_ESP32_XTAL_FREQ_AUTO=y
# v3.3-only (renamed in 4.0)
CONFIG_SPIRAM_SUPPORT=y
# FreeRTOS
CONFIG_SUPPORT_STATIC_ALLOCATION=y
CONFIG_ENABLE_STATIC_TASK_CLEAN_UP_HOOK=y
# UDP
CONFIG_PPP_SUPPORT=y
CONFIG_PPP_PAP_SUPPORT=y
CONFIG_PPP_CHAP_SUPPORT=y
Tried in 2 same boards from different producer, Espressif and DM DIY More with same results.
I spent 5 days trying to debug the problem without any luck, please help!
MaestroPlease
Re: ESP32-CAM Guru Meditation Error: Core 1 panic'ed (LoadStoreAlignment)
Postby MaestroPlease » Wed Aug 25, 2021 7:22 pm
Hey, pretty old issue you're describing but it turns out, that I'm dealing with a very similar issue with my esp32/micropython combination. Have you found a solution for this?
BR
Christian
