Hi all,
I'm new with adf framework and I startd with the asr example.
I have configured Audio HAL to use LyraT-Mini v.1.1 (despite I have v1.2) and english language.
I can build the example and flash it with the "make -j4 flash" command with no errors.
When I connect to the monitor (make monitor) I saw the board reboot continuosly becase an error on the partition table:
I (10) boot: ESP-IDF v3.3.1 2nd stage bootloader
I (10) boot: compile time 08:46:22
I (10) boot: Enabling RNG early entropy source...
I (14) qio_mode: Enabling default flash chip QIO
I (19) boot: SPI Speed : 80MHz
I (23) boot: SPI Mode : QIO
I (27) boot: SPI Flash Size : 8MB
I (31) boot: Partition Table:
I (35) boot: ## Label Usage Type ST Offset Length
I (42) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (49) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (57) boot: 2 factory factory app 00 00 00010000 00100000
I (64) boot: End of partition table
I (69) boot_comm: chip revision: 1, min. application chip revision: 0
I (76) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x1e0494 (1967252) map
I (605) esp_image: segment 1: paddr=0x001f04bc vaddr=0x3ffb0000 size=0x02010 ( 8208) load
I (608) esp_image: segment 2: paddr=0x001f24d4 vaddr=0x40080000 size=0x00400 ( 1024) load
0x40080000: _WindowOverflow4 at C:/msys32/home/fdrag/esp/esp-idf/components/freertos/xtensa_vectors.S:1779
I (612) esp_image: segment 3: paddr=0x001f28dc vaddr=0x40080400 size=0x0b198 ( 45464) load
I (636) esp_image: segment 4: paddr=0x001fda7c vaddr=0x00000000 size=0x02594 ( 9620)
I (639) esp_image: segment 5: paddr=0x00200018 vaddr=0x400d0018 size=0x40444 (263236) map
0x400d0018: _stext at ??:?
E (712) esp_image: Image length 2294912 doesn't fit in partition length 1048576
E (712) boot: Factory app partition is not bootable
E (714) boot: No bootable app partitions in the partition table
Just to let you know I can run succesfully the idf examples (hello word and blink) and the ADF example VAD.
What can I do to solve this issue ?
Kind regards,
Fabio Drago
ASR example doesn't work (at least for me)
Jalakamkiran
Re: ASR example doesn't work (at least for me)
Hey did you find a workaround. I am facing the same issue with my AI thinker board.
