MQTT & MQTTS - Sample implementation for ESP32
martinius96
Postby martinius96 » Thu Apr 23, 2020 9:13 pm
Hello, today I would like to show you sample implementations for connection and Publish / Subscribe to MQTT Broker.
Example is using public MQTT Broker located in Slovakia - use only for development (not my Broker)... Everyone can see / modify your datas there.
MQTT Broker details:
Webpage of MQTT Broker: https://mqtt.iotindustries.sk/
Implementations are for MQTT and secure MQTT (MQTTS) connection with that Broker. ESP32 is using socket for connection based on WiFi.h library or secured socket under WiFiClientSecure.h. Implementation for MQTT is for WPA/WPA2 PSK and also for Enterprise networks (such as eduroam, Ziggo). Each implementation is Publish-ing increment value from counter... Datas are send each 10 seconds and they are also Subscribed from same board (verify of sent datas).
Implementations are ESP8266, ESP32, Arduino + Ethernet compatible (MQTTS only for ESP8266, ESP32).
Topic for Publish / Sebscribe in example: esp32/pocitadlo
Output in Serial monitor:
If you want to read all topics on MQTT broker, ask for topic #.
You can see user datas about temperature, humidity, users in channels (chat) and so on. That MQTT Broker is public and anyone can modify / delete / read your datas too. For that you can use that server as backup or for testing / developing purposes.
Output will be:
Implementations available also at: https://github.com/martinius96/MQTT-Bro ... Industries
MQTT connection - WPA/WPA2 - PSK
//ESP32, ESP8266, Arduino + Ethernet - Publish / Subscribe
//Author: Martin Chlebovec (martinius96)
//Web: https://arduino.php5.sk
//Donate for more: https://paypal.me/chlebovec
#if defined(__AVR_ATmega168__) || defined(__AVR_ATmega328P__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
#include <SPI.h>
#include <Ethernet.h>
//#include <Ethernet2.h> //for Wiznet W5500 Ethernet module
#elif defined(ESP32)
#include <WiFi.h>
#elif defined(ESP8266)
#include <ESP8266WiFi.h>
#endif
#include <PubSubClient.h>
#if defined(ESP32) || defined(ESP8266)
WiFiClient espClient;
const char* ssid = "WIFI_NAME";
const char* password = "WIFI_PASSWORD";
#elif defined(__AVR_ATmega168__) || defined(__AVR_ATmega328P__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
EthernetClient espClient;
byte mac[] = { 0xAA, 0xBB, 0xCC, 0x81, 0x7B, 0x4A };
//IPAddress ip(192, 168, 0, 2);
//IPAddress dnServer(192, 168, 0, 1);
//IPAddress gateway(192, 168, 0, 1);
//IPAddress subnet(255, 255, 255, 0);
#endif
const char* mqtt_server = "mqtt.iotindustries.sk";
PubSubClient client(espClient);
unsigned long lastMsg = 0;
char msg[50];
int pocitadlo = 0;
void callback(char* topic, byte* message, unsigned int length) {
  Serial.print("Message arrived on topic: ");
  Serial.print(topic);
  Serial.print(". Message: ");
  String messageTemp;
  for (int i = 0; i < length; i++) {
    Serial.print((char)message[i]);
    messageTemp += (char)message[i];
  Serial.println();
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect("ESP8266Client")) {
      Serial.println("connected");
      // Subscribe
      client.subscribe("esp32/output");
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
  Serial.println("UART ready");
  WiFi.begin(ssid, password);
    delay(500);
    Serial.print(".");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  if (Ethernet.begin(mac) == 0) {
    Ethernet.begin(mac);
    //Ethernet.begin(mac, ip);
    //Ethernet.begin(mac, ip, dns);
    //Ethernet.begin(mac, ip, dns, gateway);
    //Ethernet.begin(mac, ip, dns, gateway, subnet);
  Serial.print("  DHCP assigned IP ");
  Serial.println(Ethernet.localIP());
#endif
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback);
  if (!client.connected()) {
    reconnect();
  if (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
#endif
  client.loop();
  if (millis() - lastMsg > 10000) {
    char pocitadlo_pole[8];
    pocitadlo  = pocitadlo + 1;
    dtostrf(pocitadlo, 1, 2, pocitadlo_pole);
    client.publish("esp32/pocitadlo", pocitadlo_pole);
    client.subscribe("esp32/pocitadlo");
    lastMsg = millis();
MQTT connection - WPA/WPA2 - Enterprise (eduroam, Ziggo)
#include <WiFi.h>
#include "esp_wpa2.h" //wpa2 library for connections to Enterprise networks
char EAP_ANONYMOUS_IDENTITY[] = "anonymous@example.com";
char EAP_IDENTITY[] = "id@example.com";
char EAP_PASSWORD[] = "EDUROAM_PASSWORD";
const char* ssid = "eduroam"; // eduroam SSID
char msg[50];
int pocitadlo = 0;
  String messageTemp;
  Serial.println();
void reconnect() {
      // Subscribe
      delay(5000);
  esp_wifi_sta_wpa2_ent_set_identity((uint8_t *)EAP_ANONYMOUS_IDENTITY, strlen(EAP_ANONYMOUS_IDENTITY));
  esp_wifi_sta_wpa2_ent_set_username((uint8_t *)EAP_IDENTITY, strlen(EAP_IDENTITY));
  esp_wifi_sta_wpa2_ent_set_password((uint8_t *)EAP_PASSWORD, strlen(EAP_PASSWORD));
  esp_wpa2_config_t config = WPA2_CONFIG_INIT_DEFAULT(); //set config settings to default
  esp_wifi_sta_wpa2_ent_enable(&config); //set config settings to enable function
  WiFi.begin(ssid); //connect to wifi network under Enterprise 802.1x
    delay(500);
    Serial.print(".");
    reconnect();
    WiFi.begin(ssid);
    delay(500);
    Serial.print(".");
  client.loop();
    lastMsg = millis();
MQTTS connection - WPA/WPA2 - PSK (SECURED MQTT)
//ESP32, ESP8266 - Publish / Subscribe - MQTTS
//ESP8266 COMPATIBLE CORE 2.5.0, 2.5.2
#include <WiFiClientSecure.h>
#if defined(ESP32)
#include <WiFi.h>
// Root CA
const static char* test_root_ca PROGMEM = \
    "-----BEGIN CERTIFICATE-----\n" \
    "MIIFdzCCBF+gAwIBAgIQE+oocFv07O0MNmMJgGFDNjANBgkqhkiG9w0BAQwFADBv\n" \
    "MQswCQYDVQQGEwJTRTEUMBIGA1UEChMLQWRkVHJ1c3QgQUIxJjAkBgNVBAsTHUFk\n" \
    "ZFRydXN0IEV4dGVybmFsIFRUUCBOZXR3b3JrMSIwIAYDVQQDExlBZGRUcnVzdCBF\n" \
    "eHRlcm5hbCBDQSBSb290MB4XDTAwMDUzMDEwNDgzOFoXDTIwMDUzMDEwNDgzOFow\n" \
    "gYgxCzAJBgNVBAYTAlVTMRMwEQYDVQQIEwpOZXcgSmVyc2V5MRQwEgYDVQQHEwtK\n" \
    "ZXJzZXkgQ2l0eTEeMBwGA1UEChMVVGhlIFVTRVJUUlVTVCBOZXR3b3JrMS4wLAYD\n" \
    "VQQDEyVVU0VSVHJ1c3QgUlNBIENlcnRpZmljYXRpb24gQXV0aG9yaXR5MIICIjAN\n" \
    "BgkqhkiG9w0BAQEFAAOCAg8AMIICCgKCAgEAgBJlFzYOw9sIs9CsVw127c0n00yt\n" \
    "UINh4qogTQktZAnczomfzD2p7PbPwdzx07HWezcoEStH2jnGvDoZtF+mvX2do2NC\n" \
    "tnbyqTsrkfjib9DsFiCQCT7i6HTJGLSR1GJk23+jBvGIGGqQIjy8/hPwhxR79uQf\n" \
    "jtTkUcYRZ0YIUcuGFFQ/vDP+fmyc/xadGL1RjjWmp2bIcmfbIWax1Jt4A8BQOujM\n" \
    "8Ny8nkz+rwWWNR9XWrf/zvk9tyy29lTdyOcSOk2uTIq3XJq0tyA9yn8iNK5+O2hm\n" \
    "AUTnAU5GU5szYPeUvlM3kHND8zLDU+/bqv50TmnHa4xgk97Exwzf4TKuzJM7UXiV\n" \
    "Z4vuPVb+DNBpDxsP8yUmazNt925H+nND5X4OpWaxKXwyhGNVicQNwZNUMBkTrNN9\n" \
    "N6frXTpsNVzbQdcS2qlJC9/YgIoJk2KOtWbPJYjNhLixP6Q5D9kCnusSTJV882sF\n" \
    "qV4Wg8y4Z+LoE53MW4LTTLPtW//e5XOsIzstAL81VXQJSdhJWBp/kjbmUZIO8yZ9\n" \
    "HE0XvMnsQybQv0FfQKlERPSZ51eHnlAfV1SoPv10Yy+xUGUJ5lhCLkMaTLTwJUdZ\n" \
    "+gQek9QmRkpQgbLevni3/GcV4clXhB4PY9bpYrrWX1Uu6lzGKAgEJTm4Diup8kyX\n" \
    "HAc/DVL17e8vgg8CAwEAAaOB9DCB8TAfBgNVHSMEGDAWgBStvZh6NLQm9/rEJlTv\n" \
    "A73gJMtUGjAdBgNVHQ4EFgQUU3m/WqorSs9UgOHYm8Cd8rIDZsswDgYDVR0PAQH/\n" \
    "BAQDAgGGMA8GA1UdEwEB/wQFMAMBAf8wEQYDVR0gBAowCDAGBgRVHSAAMEQGA1Ud\n" \
    "HwQ9MDswOaA3oDWGM2h0dHA6Ly9jcmwudXNlcnRydXN0LmNvbS9BZGRUcnVzdEV4\n" \
    "dGVybmFsQ0FSb290LmNybDA1BggrBgEFBQcBAQQpMCcwJQYIKwYBBQUHMAGGGWh0\n" \
    "dHA6Ly9vY3NwLnVzZXJ0cnVzdC5jb20wDQYJKoZIhvcNAQEMBQADggEBAJNl9jeD\n" \
    "lQ9ew4IcH9Z35zyKwKoJ8OkLJvHgwmp1ocd5yblSYMgpEg7wrQPWCcR23+WmgZWn\n" \
    "RtqCV6mVksW2jwMibDN3wXsyF24HzloUQToFJBv2FAY7qCUkDrvMKnXduXBBP3zQ\n" \
    "YzYhBx9G/2CkkeFnvN4ffhkUyWNnkepnB2u0j4vAbkN9w6GAbLIevFOFfdyQoaS8\n" \
    "Le9Gclc1Bb+7RrtubTeZtv8jkpHGbkD4jylW6l/VXxRTrPBPYer3IsynVgviuDQf\n" \
    "Jtl7GQVoP7o81DgGotPmjw7jtHFtQELFhLRAlSv0ZaBIefYdgWOWnU914Ph85I6p\n" \
    "0fKtirOMxyHNwu8=\n" \
    "-----END CERTIFICATE-----\n";
const static char fingerprint[] PROGMEM = "f6 15 f1 2a fb b5 ec a1 39 a1 79 30 2a bf 97 bc ce 49 14 5e"; //SHA1 FINGERPRINT
#endif
WiFiClientSecure  espClient;
#endif
char msg[50];
int pocitadlo = 0;
  String messageTemp;
  Serial.println();
void reconnect() {
      // Subscribe
      delay(5000);
#if defined(ESP32)
  espClient.setCACert(test_root_ca);
  espClient.setFingerprint(fingerprint);
#endif
    delay(500);
    Serial.print(".");
  client.setServer(mqtt_server, 8883);
    reconnect();
    delay(500);
    Serial.print(".");
  client.loop();
    lastMsg = millis();
MQTTS connection - WPA/WPA2 - Enterprise (eduroam, Ziggo)
//ESP32 - Publish / Subscribe - MQTTS - WPA/WPA2 Enterprise
#include <WiFi.h>
// Root CA
char msg[50];
int pocitadlo = 0;
  String messageTemp;
  Serial.println();
void reconnect() {
      // Subscribe
      delay(5000);
    delay(500);
    Serial.print(".");
    reconnect();
    WiFi.begin(ssid);
    delay(500);
    Serial.print(".");
  client.loop();
    lastMsg = millis();
More projects from my portfolio: https://arduino.php5.sk/?lang=en
