I'm learning ProfiNET protocol and how a PLC control an IO module ProfiNET.
At this moment I have an ESP32 that communicates with a W5500 (ethernet) through SPI, to control the IO module ProfiNET.
This way I can define all of the message ProfiNET (without layer 3,4,5) and send over layer 2 (OSI model).
I would like to use the ESP32, but it sending the messages to router wifi, where the IO module would be connected (rj45).
The difficulty is that I can't find an example code to send a raw packet (with or without layer 3,4,5) to a wifi router.
It is possible?
Thank you.
Jorge Torres
Send raw packet through wifi (directly over frame layer)
JorgeTorres
