Flash encryption
filipESP
Flash encryption
Postby filipESP » Thu May 21, 2020 8:44 am
I set below options:
https://iv.pl/image/GtBgqND
https://iv.pl/image/GtBgpSY
and partition table in csv.
https://iv.pl/image/GtBg13e
Before encryption I could read every partition using: target.read_partition(PartitionType(<type>, <subtype>), "file.bin")
I undertood that by default only app partitions are encrypted and partitions marked as encrypted in csv file.
In my case I leave storage data as decrypted and now the question is: whether partition storage should be readable by target.read_partition() after encryption?
I try do this but I get error: UnicodeDecodeError: 'utf-8' codec can't decode byte 0x8d in position 0: invalid start byte
filipESP
Re: Flash encryption
Postby filipESP » Tue May 26, 2020 10:25 am
Is it possible to flash new bootloader without secure boot and encryption? These are my security fuses:
I can't back to normal flash using.
Security fuses:
FLASH_CRYPT_CNT        Flash encryption mode counter                     = 7 R/W (0x7)
FLASH_CRYPT_CONFIG     Flash encryption config (key tweak bits)          = 15 R/W (0xf)
CONSOLE_DEBUG_DISABLE  Disable ROM BASIC interpreter fallback            = 1 R/W (0x1)
ABS_DONE_0             secure boot enabled for bootloader                = 1 R/W (0x1)
ABS_DONE_1             secure boot abstract 1 locked                     = 0 R/W (0x0)
JTAG_DISABLE           Disable JTAG                                      = 1 R/W (0x1)
DISABLE_DL_ENCRYPT     Disable flash encryption in UART bootloader       = 0 R/W (0x0)
DISABLE_DL_DECRYPT     Disable flash decryption in UART bootloader       = 1 R/W (0x1)
DISABLE_DL_CACHE       Disable flash cache in UART bootloader            = 1 R/W (0x1)
BLK1                   Flash encryption key
BLK2                   Secure boot key
BLK3                   Variable Block 3
  = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W
ESP_Angus
Postby ESP_Angus » Wed May 27, 2020 4:01 am
Hi filip,
Sorry noone replied to you before now.
If the data is not encrypted then it should be possible to read it out on the host using partition tool, same as if encryption was not enabled.
If you're getting this Python error then can you please post the full error backtrace with all lines of context, and also please let us know which ESP-IDF version you're using and what operating system you're doing this on? It may be a bug.
filipESP wrote: Is it possible to flash new bootloader without secure boot and encryption? These are my security fuses:
It's not possible to disable secure boot once it's enabled in hardware (efuse ABS_DONE_0 is set to 1), and the FLASH_CRYPT_CNT efuse is already at its maximum value (0x7) so flash encryption cannot be disabled again. FLASH_CRYPT_CNT is set to the maximum if you enable flash encryption and secure boot together to prevent undoing any security protections.
As it looks like Flash Encryption is enabled in "Development" mode then it should be possible to flash new signed apps with the encrypted-flash target.
It may also be possible to flash a new bootloader if you enabled Secure Boot in "Reflashable" mode, meaning you can generate the digest to match a new bootloader binary. Unfortunately the screenshot links no longer work so I can't see exactly what config was used.
filipESP
Postby filipESP » Mon Jun 01, 2020 11:37 am
sdk config - boot options:
https://zapodaj.net/images/d89faae4a2ac7.png
sdk config - partition table:
https://zapodaj.net/images/3b66441118ba7.png
csv file - partition table:
https://zapodaj.net/images/88d8d83e3603a.png
attempt to read partition with type data:
https://zapodaj.net/images/36cea10773801.png
My OS is Win10 and idf version is 4,0.
ESP_Angus
Postby ESP_Angus » Mon Jun 01, 2020 11:34 pm
Hi Filip,
Sorry I missed a detail in my first reply.
The error posted in the last screenshot indicates a problem reading the partition table back from flash, the magic byte doesn't match the expected magic byte for a partition.
This is because the partition table itself has been encrypted, you won't be able to use this approach to read out any partition table entries from the host.
However if you know the offset of the unencrypted data partition (can find this from the "idf.py partition_table" target) then you can read the bytes from that address in flash directly (using esptool.py read_flash or a similar approach), as they are unencrypted.
Users browsing this forum: Baidu [Spider] and 20 guests
