I have a small sketch I would like to port to the ESP32, but I can't get it to work.
The Arduino sketch and partially modified ESP32 sketch are here: https://github.com/Account-Git/Arduino-to-ESP32
Please, can anyone help?
Something so simple shouldn't be this difficult.
Porting basic code to ESP32
Re: Porting basic code to ESP32
My glass ball needs a repair.
Please define "can't get it to work".
What did you do?
What did you expect?
What did you get instead?
What did you do?
Sorry, yes I should have made myself more clear.
First, I took my original, working, Arduino sketch (as shown on GitHub).
Then, I changed the pin numbers to match the GPIO pins on the ESP32. I also changed the baud rate for the Serial monitor.
And that's all I did.
I was hoping (expecting) to get the same results as I did with the Arduino.
i.e. When one of the inputs on the 74HC165 goes high the microcontroller receives a 1 on that bit, or a 0 if it goes low.
What I got instead was either one 0 instead of eight bits, or eight 1s, and sometimes just a load of rubbish (2 bits, 4bits, 5bits, etc).
It seems that the SPI setup is way off somewhere, but I am new to ESP32 and don't know how to set it up for this type of application despite it appearing very simple at the outset.
I have not examined your code, but generally the biggest porting issue from Arduino (UNO, Mega, Nano, Micro) and ESP32 is that AVR 8-bit uC has int defined as 16-bits and int on ESP32 is 32-bit.
Good luck.
Ray
Thanks, Ray
What is the "fix/workaround" for this?
Users browsing this forum: No registered users and 141 guests
