ESP32 ISR
Posted: Sun Apr 02, 2017 7:19 pm
I need to use external interrupt with my ESP32. I set up the code like this:
I have a nice clean 75.2Hz signal which triggers the ISR.
In a separate task I'm checking the PIN_BIT in the interrupt_event_group like this:
And I'm measuring strange delta time between interrupts like this:
However, if I use xEventGroupSetBits instead of xEventGroupSetBitsFromISR in the ISR I get exactly 0.013s delta time in every cycle, but of course it crashes after a while.
Any idea how to solve this problem?
gpio_pad_select_gpio(GPIO_NUM_5);
gpio_set_direction(GPIO_NUM_5, static_cast<gpio_mode_t>(GPIO_MODE_INPUT));
gpio_set_pull_mode(GPIO_NUM_5, GPIO_PULLUP_ONLY);
gpio_set_intr_type(GPIO_NUM_5, GPIO_INTR_NEGEDGE);
gpio_intr_enable(GPIO_NUM_5);
gpio_isr_register(inthandler, nullptr, 0, 0);
void inthandler(void *arg){
uint32_t gpio_intr_status = READ_PERI_REG(GPIO_STATUS_REG);
uint32_t gpio_intr_status_h = READ_PERI_REG(GPIO_STATUS1_REG);
SET_PERI_REG_MASK(GPIO_STATUS_W1TC_REG, gpio_intr_status);
SET_PERI_REG_MASK(GPIO_STATUS1_W1TC_REG, gpio_intr_status_h);
if((gpio_intr_status & BIT(GPIO_NUM_5)) == BIT(GPIO_NUM_5)) {
BaseType_t xHigherPriorityTaskWoken, xResult;
// xHigherPriorityTaskWoken must be initialised to pdFALSE.
xHigherPriorityTaskWoken = pdFALSE;
// Set bit 0 and bit 4 in xEventGroup.
xResult = xEventGroupSetBitsFromISR(
interrupt_event_group, // The event group being updated.
PIN_BIT, // The bits being set.
&xHigherPriorityTaskWoken );
// Was the message posted successfully?
if( xResult == pdPASS )
//ets_printf("xResult==pdPASS\n");
// If xHigherPriorityTaskWoken is now set to pdTRUE then a context
// switch should be requested. The macro used is port specific and
// will be either portYIELD_FROM_ISR() or portEND_SWITCHING_ISR() -
// refer to the documentation page for the port being used.
//portYIELD_FROM_ISR( xHigherPriorityTaskWoken );
//portEND_SWITCHING_ISR();
} else {
//ets_printf("xResult pdFAIL!\n");
float elapsedSec() {
timeval tv;
gettimeofday(&tv, 0);
return tv.tv_sec + tv.tv_usec * 1.0e-6f;
static void i2cTask(void *param) {
while(1) {
bool clearOnExit=true, waitForAllBits=true;
xEventGroupWaitBits(interrupt_event_group, PIN_BIT, clearOnExit, waitForAllBits, portMAX_DELAY);
float now = elapsedSec();
float dt = now - past;
past = now;
std::cout << "dt: " << dt << std::endl;
