BLE Mesh when the LPN creates a friendship no group addresses are registered
mishafarms
Postby mishafarms » Tue Jun 09, 2020 12:10 am
I am playing with BLE Mesh and LPN. If my node already has a friendship and I provision a group subscription, when I send to the group the node gets the message. But if the node loses the friendship either because the node or the friend is reset or because I lose network connectivity, When the new friendship is established, I no longer get the group messages.
This is because they are not re-registered with the friend. I believe that the LPN should do this at a low layer. But I currently solved it by calling this code in my main. I think this is a bug in the LPN code. Am I correct? or should this be done in the prov_cb?
Michael
static void register_sub_with_friend(void)
	// need a pointer to the composition data
	u16_t myGroups[CONFIG_BLE_MESH_LPN_GROUPS];
	int groupIdx = 0;
	const esp_ble_mesh_comp_t *myComp = esp_ble_mesh_get_composition_data();
	if (myComp == NULL)
		ESP_LOGE(TAG, "No composite data found");
		// we are done now
		return;
	// I got the composite. now walk the element list.
	for (int i = 0; i < myComp->element_count; i++)
		// access the element
		const esp_ble_mesh_elem_t *myElement = &myComp->elements[i];
		// walk the SIG models
		for (int j = 0; j < myElement->sig_model_count; j++)
			// now I need to look to see which groups are registered for this model
			const esp_ble_mesh_model_t *myModel = &myElement->sig_models[j];
			if (myModel == NULL)
				// this shouldn't happen
				ESP_LOGE(TAG, "Model is NULL");
				continue;
			for (int k = 0; k < CONFIG_BLE_MESH_MODEL_GROUP_COUNT; k++)
				if (myModel->groups[k])
					if (groupIdx < CONFIG_BLE_MESH_LPN_GROUPS)
						myGroups[groupIdx++] = myModel->groups[k];
						ESP_LOGI(TAG, "Group %04x registered", myModel->groups[k]);
		for (int j = 0; j < myElement->vnd_model_count; j++)
			const esp_ble_mesh_model_t *myModel = &myElement->vnd_models[j];
				continue;
	// delete all the groups, then add them again, this should be no problem and make sure that we subscribe at the
	// friend
	bt_mesh_lpn_group_del(myGroups, groupIdx);
	// now do it one at a time
	for (int i = 0; i < groupIdx; i++)
		bt_mesh_lpn_group_add(myGroups[i]);
Users browsing this forum: Amazon [Bot], MicroController, Semrush [Bot] and 0 guests
