ESP32 IDF BLE Dynamic Advertising Data Change
WardMas
Postby WardMas » Fri Jun 19, 2020 11:23 am
Hello Everybody,
I am using ESP32 WROOM module with gatt_server and I am trying to change the data being advertised on the go in the main function using the following code segment.
static esp_ble_adv_params_t adv_params1 = {
    .adv_int_min        = 0x0A0, 		//160 * 0.625 ms = 100ms,
    .adv_int_max        = 0x140,		//320 * 0.625 ms = 200ms,
    .adv_type           = ADV_TYPE_IND,
    .own_addr_type      = BLE_ADDR_TYPE_PUBLIC,
    //.peer_addr            =
    //.peer_addr_type       =
    .channel_map        = ADV_CHNL_ALL,
    .adv_filter_policy = ADV_FILTER_ALLOW_SCAN_ANY_CON_ANY,
  		   static uint8_t test_manufacturer[4] =  { 0x23, 0x07, 0x41, 0x56};
  		   static uint8_t adv_service_uuid128[32] = {
  		     /* LSB <--------------------------------------------------------------------------------> MSB */
  		     //first uuid, 16bit, [12],[13] is the value
  		     0xfb, 0x34, 0x9b, 0x5f, 0x80, 0x00, 0x00, 0x80, 0x00, 0x10, 0x00, 0x00, 0xEE, 0x00, 0x00, 0x00,
  		     //second uuid, 32bit, [12], [13], [14], [15] is the value
  		     0xfb, 0x34, 0x9b, 0x5f, 0x80, 0x00, 0x00, 0x80, 0x00, 0x10, 0x00, 0x00, 0xFF, 0x00, 0x00, 0x00,
  		   	static uint8_t service[5] = {0, 1, 2, 3, 4};
			esp_ble_gap_stop_advertising();
			static esp_ble_adv_data_t ADVinfo;
			ADVinfo.set_scan_rsp = false;
			ADVinfo.include_name = true;
			ADVinfo.include_txpower = true;
			ADVinfo.appearance = 0x2A79;
			ADVinfo.min_interval = 0x0036; //slave connection min interval, Time = min_interval * 1.25 msec
			ADVinfo.max_interval = 0x0040; //slave connection max interval, Time = max_interval * 1.25 msec
			ADVinfo.appearance = 0x00;
			ADVinfo.manufacturer_len = sizeof(test_manufacturer); //TEST_MANUFACTURER_DATA_LEN,
			ADVinfo.p_manufacturer_data =  test_manufacturer; //&test_manufacturer[0],
			ADVinfo.service_data_len = 0;
			ADVinfo.p_service_data  = NULL;
			ADVinfo.service_uuid_len = sizeof(adv_service_uuid128);
			ADVinfo.p_service_uuid = adv_service_uuid128;
			ADVinfo.flag = (ESP_BLE_ADV_FLAG_GEN_DISC | ESP_BLE_ADV_FLAG_BREDR_NOT_SPT);
			test_manufacturer[2] = test_manufacturer[2] + 1;
			esp_ble_gap_config_adv_data(&ADVinfo);
			esp_ble_gap_start_advertising(&adv_params1);
is it possible to modify the data being advertised on the go ?if yes what is the proper way of doing that?
Thank you
You can always visit my YouTube channel for embedded systems related tutorials
https://youtube.com/user/wardzx1
chegewara
Re: ESP32 IDF BLE Dynamic Advertising Data Change
Postby chegewara » Fri Jun 19, 2020 7:04 pm
WardMas
Postby WardMas » Sat Jun 20, 2020 12:15 pm
Hi thank you for your reply. I could solve the problem as you recommended but of course I also had to reset adv_config_done flag to allow the program to start advertising when ESP_GAP_BLE_ADV_DATA_SET_COMPLETE_EVT interrupt occurs
