[CLOSED]"Brownout detector was triggered" failure on my ESP32
Python Schlange
Postby Python Schlange » Sat Jun 27, 2020 5:37 pm
I tried to upload my code, everything worked but when I opened the Serial Monitor, it showed me that Issue:
Code: Untitled.cpp Select all
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:9720
ho 0 tail 12 room 4
load:0x40080400,len:6352
entry 0x400806b8
PS: I tried to search a topic, but I just got a blank page so I started a new topic.
Last edited by Python Schlange on Sat Jun 27, 2020 5:58 pm, edited 1 time in total.
lbernstone
Re: "Brownout detector was triggered" failure on my ESP32
Postby lbernstone » Sat Jun 27, 2020 5:50 pm
Your USB port is not providing enough power. Try another port, or else you will need an external power source (perhaps a powered USB hub).
Postby Sprite » Sat Jun 27, 2020 5:52 pm
Also, suspect your USB cable. There are some with extremely thin conductors out there.
Python Schlange
Postby Python Schlange » Sat Jun 27, 2020 5:57 pm
Sorry for the whole topic, just realized I had got the wrong Uploadspeed (921600) :oops: .
Changed it to 115200 and everything is working :D
krzychb
Contact:
Re: [CLOSED]"Brownout detector was triggered" failure on my ESP32
Postby krzychb » Sat Jun 27, 2020 6:16 pm
Hi Python Schlange,
Upload speed should not be the issue. This message is reported when voltage supplied to the chip gets too low. A spike below the brownout voltage (I believe default is 2.44 V) is enough to trigger this error. If you see this message again try replacing power supply, USB cable, install capacitor on power supply terminals of your module, etc.
Also refer to https://github.com/nkolban/esp32-snippets/issues/168 for related discussion.
Arav24
Postby Arav24 » Wed Mar 22, 2023 4:35 am
Im having the same issue, Does this problem impact NVS storage?
Arivenkkataram
Postby Arivenkkataram » Tue Sep 03, 2024 7:54 am
Hello everyone, I purchased two ESP32 WROOM 32 boards, but one works fine while the other displays a brownout error. After investigation, I found that the issue is due to an improper power supply to the AMS1117 IC 3.3V regulator on the faulty board. Although the board's maximum current rating is 0.15A, which allows for successful program uploading, running the program on the ESP32 requires a higher current rate. This triggers the brownout detector when connecting to WiFi and performing other tasks. To resolve this issue, I replaced the AMS1117 IC 3.3V regulator. After replacing the AMS1117 IC 3.3V, the ESP32 board now works fine.
Users browsing this forum: Bytespider, ChatGPT-User, Perplexity-User, PerplexityBot and 3 guests
