BLE TX POWER LEVEL ADJUST
jp.leriche@gmail.com
Postby jp.leriche@gmail.com » Fri Jul 03, 2020 10:02 am
No matter what I do, I have been through every discussion on this forum, I can not increase the TX power level on my ESP32-Wroom 32D.
I do not need to connect, just transmit advertising data, but the maximum distance I get is about 4m!
Can someone please provide more information and maybe a working example?
Re: BLE TX POWER LEVEL ADJUST
Postby Sprite » Fri Jul 03, 2020 12:10 pm
Why do you think the issue is your Tx level? What hardware are you running on? Are you sure you're not shielding the antenna or something?
Postby jp.leriche@gmail.com » Fri Jul 03, 2020 12:30 pm
Because no matter what TX power level setting I enter, the power level stays the same as the default.
Definitely not shielded.
Using the ESP32-WROOM-32D and NRF BLE App to check the reception.
hhelmbold
Postby hhelmbold » Sat Jul 04, 2020 7:46 am
Can you give a bit more info on the "power level" you referring to? Is this the baud rate? I don't have enough info but I believe the voltage is more the issue here. Assuming you using the ESP32 directly you have 3.3V - The max distance on 5V is 5m with a high quality cable (using USB as reference), so 4m sounds correct with 3.3V. I am no pro on this but this is just my first thoughts. Maybe something like a Logic Level Converter may help?
Postby Sprite » Sat Jul 04, 2020 8:03 am
@hhelmbold: BLE is Bluetooth Low Energy, so no cables involved.
hhelmbold
Postby hhelmbold » Sat Jul 04, 2020 11:27 am
OH!!! LOL! And so I learn :lol: I am still trying to get cables to work, nevermind wireless
chegewara
Postby chegewara » Sun Jul 05, 2020 9:13 am
Maybe here you can find some answers:
https://github.com/espressif/esp-idf/issues/2390
Users browsing this forum: ChatGPT-User and 5 guests
