Can't upload
ats3788
Can't upload
Postby ats3788 » Thu Jul 16, 2020 8:34 am
Hello
I have a ESP32 Himalaya Board and
I tried everything. I drive IO0 to Ground I let GPIO2 float I drove it down to GND
I use an External 3V3 nothing
When I push Reset I get
mode:DIO, clock div:2
load:0x3fff0008,len:8
load:0x3fff0010,len:3480
load:0x40078000,len:7804
ho 0 tail 12 room 4
load:0x40080000,len:252
entry 0x40080034
␛[0;32mI (45) boot: ESP-IDF v2.0-3-gbef9896 2nd stage bootloader␛[0m
␛[0;32mI (45) boot: compile time 05:59:45␛[0m
␛[0;32mI (45) boot: Enabling RNG early entropy source...␛[0m
␛[0;32mI (64) boot: SPI Speed : 40MHz␛[0m
␛[0;32mI (77) boot: SPI Mode : DIO␛[0m
␛[0;32mI (89) boot: SPI Flash Size : 4MB␛[0m
␛[0;32mI (101) boot: Partition Table:␛[0m
␛[0;32mI (113) boot: ## Label Usage Type ST Offset Length␛[0m
␛[0;32mI (135) boot: 0 phy_init RF data 01 01 0000f000 00001000␛[0m
␛[0;32mI (159) boot: 1 otadata OTA data 01 00 00010000 00002000␛[0m
␛[0;32mI (182) boot: 2 nvs WiFi data 01 02 00012000 0000e000␛[0m
␛[0;32mI (205) boot: 3 at_customize unknown 40 00 00020000 000e0000␛[0m
␛[0;32mI (228) boot: 4 ota_0 OTA app 00 10 00100000 00180000␛[0m
␛[0;32mI (252) boot: 5 ota_1 OTA app 00 11 00280000 00180000␛[0m
␛[0;32mI (275) boot: End of partition table␛[0m
␛[0;32mI (288) boot: Disabling RNG early entropy source...␛[0m
␛[0;32mI (305) boot: Loading app partition at offset 00100000␛[0m
␛[0;32mI (1481) boot: segment 0: paddr=0x00100018 vaddr=0x00000000 size=0x0ffe8 ( 65512) ␛[0m
␛[0;32mI (1481) boot: segment 1: paddr=0x00110008 vaddr=0x3f400010 size=0x1c5f0 (116208) map␛[0m
␛[0;32mI (1498) boot: segment 2: paddr=0x0012c600 vaddr=0x3ffb0000 size=0x0215c ( 8540) load␛[0m
␛[0;32mI (1528) boot: segment 3: paddr=0x0012e764 vaddr=0x40080000 size=0x00400 ( 1024) load␛[0m
␛[0;32mI (1551) boot: segment 4: paddr=0x0012eb6c vaddr=0x40080400 size=0x1b028 (110632) load␛[0m
␛[0;32mI (1630) boot: segment 5: paddr=0x00149b9c vaddr=0x400c0000 size=0x00034 ( 52) load␛[0m
␛[0;32mI (1631) boot: segment 6: paddr=0x00149bd8 vaddr=0x00000000 size=0x06430 ( 25648) ␛[0m
␛[0;32mI (1647) boot: segment 7: paddr=0x00150010 vaddr=0x400d0018 size=0x7a56c (501100) map␛[0m
␛[0;32mI (1675) heap_alloc_caps: Initializing. RAM available for dynamic allocation:␛[0m
␛[0;32mI (1697) heap_alloc_caps: At 3FFBA6B8 len 00025948 (150 KiB): DRAM␛[0m
␛[0;32mI (1718) heap_alloc_caps: At 3FFE8000 len 00018000 (96 KiB): D/IRAM␛[0m
␛[0;32mI (1740) heap_alloc_caps: At 4009B428 len 00004BD8 (18 KiB): IRAM␛[0m
␛[0;32mI (1761) cpu_start: Pro cpu up.␛[0m
␛[0;32mI (1772) cpu_start: Single core mode␛[0m
␛[0;32mI (1785) cpu_start: Pro cpu start user code␛[0m
␛[0;32mI (1846) cpu_start: Starting scheduler on PRO CPU.␛[0m
␛[0;32mI (2068) uart: queue free spaces: 10␛[0m
Bin version:0.10.0
I (2069) wifi: wifi firmware version: c604573
I (2069) wifi: config NVS flash: enabled
I (2071) wifi: config nano formating: disabled
I (2079) wifi: Init dynamic tx buffer num: 32
I (2079) wifi: wifi driver task: 3ffc4eac, prio:23, stack:3584
I (2084) wifi: Init static rx buffer num: 10
I (2088) wifi: Init dynamic rx buffer num: 0
I (2092) wifi: Init rx ampdu len mblock:7
I (2096) wifi: Init lldesc rx ampdu entry mblock:4
I (2101) wifi: wifi power manager task: 0x3ffca254 prio: 21 stack: 2560
I (2107) wifi: wifi timer task: 3ffcb2d4, prio:22, stack:3584
␛[0;31mE (2113) phy_init: PHY data partition validated␛[0m
␛[0;32mI (2141) phy: phy_version: 329, Feb 22 2017, 15:58:07, 0, 0␛[0m
I (2142) wifi: mode : softAP (24:0a:c4:13:b6:e9)
I (2145) wifi: mode : sta (24:0a:c4:13:b6:e8) + softAP (24:0a:c4:13:b6:e9)
I (2148) wifi: mode : softAP (24:0a:c4:13:b6:e9)
See attachment
Any Idea
ESP32 Dev Module.jpg (292.33 KiB) Viewed 3383 times
ats3788
Re: Can't upload
Postby ats3788 » Thu Jul 16, 2020 8:53 am
I found this https://esp32.com/viewtopic.php?t=8704
My Problem is the Part I have to press Reset and Boot then you have to release Reset and then Boot then it works
