Hi
It is true that the C++ compiler of ESP32 sketchs on Arduino IDE is different from the C++ compile of Arduino Uno board?
C++ compiler for Sketch ESP32
Re: C++ compiler for Sketch ESP32
Define 'different'? It's different in that you cannot use the same compiler programs for both CPUs, as the processor core is entirely different. It's the same in that both are versions of GCC, and they should understand and interpret C++ mostly in the same way.
Thanks ESP_Sprite
my problem is to create a scketch for Arduino and ESP32 boards.
My be the compiler (or the switches) arenn't of the same level, for example the C++ compiler for Arduino accepts the default parameters in function declaration but this not happens for the C++ ESP32 compiler.
Another difference (that I have given me many problems) is the char declaration that for C++ ESP32 isn't signed char.
Send the code & the compiler error.My be the compiler (or the switches) arenn't of the same level, for example the C++ compiler for Arduino accepts the default parameters in function declaration but this not happens for the C++ ESP32 compiler.
'signed char' is 'signed char'! So you must be wrongly attributing your error. I would be very suprised if ESP QA dropped that ball! Else am I to suppose that a uint16_t might be an int32_t? Worlds would fall. Posts would be err posted
EDIT: Even under C+11 there is latitude and certainly differences between earlier C++ versions. Code snippet & compiler message is the best way.
The definition of a 'char' is not specified by the C specs at least iirc; it can be signed or unsigned by default, depending on the architecture; you may be right in that that differs between Xtensa and AVR. From what I know, gcc can change it with a command line option. (Although I'd posit good code would explicitly use an uint8_t or int8_t instead...) No idea wrt default function arguments, from what I can tell that should work; can you post an example of the code and error there?
Thanks ESP_Sprite
I agree with you on the use int8_t instead of char, because there is difference in compiling for Arduino and ESP32: for example if char variable = -1 this instruction mYArray[variable+1]; works in Arduino and crash on ESP32.
For the functions with default variable this is the fragment that works for Arduino:
Compiling for ESP32 this is the errors list
For completeness the compilation is not aborted in a first attempt where the default declaration was only on the .h script
// .h source
unsigned long clocker(bool ms=false);
// .cpp source
unsigned long handleEvents::clocker(bool ms=false) { // returns time at seconds or at milliseconds if ms=true
static unsigned long millisOld = 0;
if (millisOld > millis()) {*ag_Clock += secondsTimerCount;}
millisOld = millis();
if (!ms) return (*ag_Clock)+millis()/1000;
return (*ag_Clock)*1000+millis();
Arduino: 1.8.12 (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
handleEvents.cpp:14:50: error: default argument given for parameter 1 of 'long unsigned int handleEvents::clocker(bool)' [-fpermissive]
In file included from sketch\handleEvents.cpp:9:0:
sketch\handleEvents.h:60:17: note: previous specification in 'long unsigned int handleEvents::clocker(bool)' here
exit status 1
Default arguments for a function must be defined in the function declaration (in the .h file), not in the definition. Your code is wrong and the compiler is working correctly. http://www.icce.rug.nl/documents/cplusp ... 2.html#l17
