ESP32-Ethernet-Kit V1.1 and AT commands
stokersoft
Postby stokersoft » Tue Jul 28, 2020 1:35 pm
Hi there
We are currently using the esp-wroom-02 device, that gives WiFi support to our products, it works perfectly.
Now we need Ethernet support, and are looking at the architecture used in ESP32-Ethernet-Kit V1.1
We would like to use the WiFi as we use to do with esp-wroom-02 but then use Ethernet also through the AT commands.
From what i can see, there are no AT commands available for the ethernet part.
Am i right, or did i miss something?
If i am right, what would be the best procedure to make the AT commands for ethernet? Do we have to implement these ourselves, and create an extension to the at commands for wifi and bluetooth. Or did someone already do this?
Regards Jens
morris
Re: ESP32-Ethernet-Kit V1.1 and AT commands
Postby morris » Thu Jul 30, 2020 8:47 am
stokersoft
Postby stokersoft » Fri Jul 31, 2020 11:06 am
Yes thanks, very helpful. So its automatic. You just plug in the ethernet cable, it obtains an ip address automatically, and then the tcp commands work on the ethernet instead of the wifi.
Has anyone tried this, and is it as easy as that?
Regards Jens
Users browsing this forum: PetalBot, Qwantbot and 4 guests
