I made a custom ESP32 board with an lan8720 controller to provide ethernet. Using the wifi/lan8720 example in arduino I am able to see if a device is connected but can't communicate with the router.
On closer inspection it seems I messed up and wired the TXD0 pin on the lan8720 to the TXD1 on the ESP32, and similarly the TXD1 goes to the TXD0. Urgh.
Is there a way to reassign the TXD0 and TXD1 pins on the ESP32 ? from what I am finding it seems these are part of the RMII bus which is fixed...
