hi
Yesterday I start to download new v2.0 release
git clone https://github.com/espressif/esp-idf.git esp-idf-v2.0
cd esp-idf-v2.0/
git checkout v2.0
git submodule update --init
When I run "make menuconfig", the output is follow
rock@rock-virtual-machine:~$ cd newworkspace/hello_world/
rock@rock-virtual-machine:~/newworkspace/hello_world$ export IDF_PATH=~/newworkspace/esp-idf/
rock@rock-virtual-machine:~/newworkspace/hello_world$ echo $IDF_PATH
/home/rock/newworkspace/esp-idf/
rock@rock-virtual-machine:~/newworkspace/hello_world$ make menuconfig
/home/rock/newworkspace/esp-idf/make/common.mk:10: /home/rock/newworkspace/hello_world/build/include/config/auto.conf: 没有那个文件或目录
make[1]: Entering directory '/home/rock/newworkspace/esp-idf/tools/kconfig'
make[1]: lxdialog/check-lxdialog.sh:命令未找到 command not found
cc -DLOCALE -c -o mconf.o mconf.c
In file included from mconf.c:23:0:
lxdialog/dialog.h:38:10: error: #include expects "FILENAME" or <FILENAME>
#include CURSES_LOC
lxdialog/dialog.h:103:2: error: unknown type name ‘chtype’
chtype atr; /* Color attribute */
lxdialog/dialog.h:200:16: error: unknown type name ‘WINDOW’
int on_key_esc(WINDOW *win);
lxdialog/dialog.h:221:17: error: unknown type name ‘WINDOW’
void attr_clear(WINDOW * win, int height, int width, chtype attr);
lxdialog/dialog.h:221:54: error: unknown type name ‘chtype’
lxdialog/dialog.h:223:21: error: unknown type name ‘WINDOW’
void print_autowrap(WINDOW * win, const char *prompt, int width, int y, int x);
lxdialog/dialog.h:224:19: error: unknown type name ‘WINDOW’
void print_button(WINDOW * win, const char *label, int y, int x, int selected);
lxdialog/dialog.h:225:18: error: unknown type name ‘WINDOW’
void print_title(WINDOW *dialog, const char *title, int width);
lxdialog/dialog.h:226:15: error: unknown type name ‘WINDOW’
void draw_box(WINDOW * win, int y, int x, int height, int width, chtype box,
lxdialog/dialog.h:226:66: error: unknown type name ‘chtype’
lxdialog/dialog.h:227:8: error: unknown type name ‘chtype’
chtype border);
lxdialog/dialog.h:228:18: error: unknown type name ‘WINDOW’
void draw_shadow(WINDOW * win, int y, int x, int height, int width);
mconf.c: In function ‘conf’:
lxdialog/dialog.h:97:29: error: ‘KEY_MAX’ undeclared (first use in this function)
#define ERRDISPLAYTOOSMALL (KEY_MAX + 1)
mconf.c:671:45: note: in expansion of macro ‘ERRDISPLAYTOOSMALL’
if (res == 1 || res == KEY_ESC || res == -ERRDISPLAYTOOSMALL)
lxdialog/dialog.h:97:29: note: each undeclared identifier is reported only once for each function it appears in
mconf.c: In function ‘show_help’:
mconf.c:793:19: warning: implicit declaration of function ‘getmaxx’ [-Wimplicit-function-declaration]
help.max_width = getmaxx(stdscr) - 10;
mconf.c:793:27: error: ‘stdscr’ undeclared (first use in this function)
mconf.c: In function ‘conf_choice’:
mconf.c:855:9: note: in expansion of macro ‘ERRDISPLAYTOOSMALL’
case -ERRDISPLAYTOOSMALL:
<builtin>: recipe for target 'mconf.o' failed
make[1]: *** [mconf.o] Error 1
make[1]: Leaving directory '/home/rock/newworkspace/esp-idf/tools/kconfig'
/home/rock/newworkspace/esp-idf/make/project_config.mk:20: recipe for target '/home/rock/newworkspace/esp-idf/tools/kconfig/conf' failed
make: *** [/home/rock/newworkspace/esp-idf/tools/kconfig/conf] Error 2
I check the Makefile file and folder, the check-lxdialog.sh file exists
rock@rock-virtual-machine:~/newworkspace/hello_world$ cd ..
rock@rock-virtual-machine:~/newworkspace$ cd esp-idf/tools/kconfig/
rock@rock-virtual-machine:~/newworkspace/esp-idf/tools/kconfig$ ls
check.sh Kconfig mconf.c qconf.h
conf.c kconfig-language.txt menu.c streamline_config.pl
confdata.c kxgettext.c merge_config.sh symbol.c
expr.c list.h nconf.c util.c
expr.h lkc.h nconf.gui.c zconf.gperf
gconf.c lkc_proto.h nconf.h zconf.l
gconf.glade lxdialog POTFILES.in zconf.y
images.c Makefile qconf.cc
rock@rock-virtual-machine:~/newworkspace/esp-idf/tools/kconfig$ cd lxdialog/
rock@rock-virtual-machine:~/newworkspace/esp-idf/tools/kconfig/lxdialog$ ls
BIG.FAT.WARNING check-lxdialog.sh inputbox.c textbox.c yesno.c
checklist.c dialog.h menubox.c util.c
Actually I never met such issue on esp-idf-v2.0-rc1 version.
fail to compile esp-idf-v2.0 release on ubuntu linux env
Re: fail to compile esp-idf-v2.0 release on ubuntu linux env
Just try to download the v2.0 version by zip file download directly, the compile error is gone. So the code base download by my git command may be corrupted, or my git command is not right one.
Yes, the log indicates that " lxdialog/check-lxdialog.sh:命令未找到 command not found", so either lxdialog/check-lxdialog.sh is not present under tools/kconfig directory, or it doesn't have executable permission for the current user.
you should specify the path first, "export IDF_PATH=******", "******"means the path of "esp-idf".
Users browsing this forum: Google [Bot], Qwantbot, Semrush [Bot] and 1 guest
