esp32-at guidance (dev board, volume ordering)
rozzie
Postby rozzie » Sat Sep 05, 2020 5:13 pm
Hello. I have what will be a high volume solution that requires
1) the lowest cost esp32 Module that will run the rsp-at AT command firmware with a PCB antenna (likely ESP32-S2-WROOM or even ESP32-S2-MINI-1)
2) that the esp-at AT command firmware be preloaded so that our CM does not need to load any further firmware
Where might I please get guidance on
A) which specific modules are recommended, and
B) the very specific part number(s) that I can order that guarantees, when ordered, that the modules will be delivered with the AT command firmware preloaded by espressif?
C) where can I quickly obtain a development kit that has the AT software preloaded? I have wasted several hours trying to load it myself and I am frustrated beyond belief
Thank you!
ESP_Sprite
Re: esp32-at guidance (dev board, volume ordering)
Postby ESP_Sprite » Sun Sep 06, 2020 12:04 pm
Suggest you contact sales@espressif.com; they can do custom runs of modules with custom/user-specified firmware flashed.
Users browsing this forum: hyxamp and 38 guests
