disable warnings as erros
mairswartz
Postby mairswartz » Wed Oct 14, 2020 5:09 am
I'm trying to integrate a third party library with the IDF.
When I try to compile I get the following error
 error: 'func' may be used uninitialized in this function [-Werror=maybe-uninitialized]
I'm looking at cmakelists.txt target_compile_options but I cant find any examples of how to disable the warning
Any help would be appreciated,
check out my course https://learnesp32.com
nvannote
Re: disable warnings as erros
Postby nvannote » Wed Oct 14, 2020 5:03 pm
The compiler flag your looking for is -Wno-maybe-uninitialized.
Best Regards
mairswartz
Postby mairswartz » Wed Oct 14, 2020 9:43 pm
Thanks @nvannote
Do you have an example on how to switch it off. Its seems on my default
I've tried
target_compile_options(${COMPONENT_LIB} PRIVATE -Wno-maybe-uninitialized=0)
but that didn't work
looking at https://docs.espressif.com/projects/esp ... -variables
It seems I need to switch it off in the root cmakelists.txt
I've tried
cmake_minimum_required(VERSION 3.5)
set(WARN_UNINITIALIZED 0)
project(proj)
but that didn't work either. It maybe my syntax is wrong. I'm still getting familiar with cmake
nvannote
Postby nvannote » Thu Oct 15, 2020 2:54 am
I have done this with IDF in the past. In my case I was porting a library specifically as a component.
After your idf_component_register, you can add a line...
set_target_properties(${COMPONENT_LIB} PROPERTIES COMPILE_FLAGS -Wno-maybe-uninitialized)
In my case, and perhaps you would like to do similar; I singled out the specific offending source file.
set_source_files_properties(your/path/to/source/file/here.c PROPERTIES COMPILE_FLAGS -Wno-maybe-uninitialized)
Best Regards
Footnote:
While this will get around the immediate issue, I will note that compilers are pretty good at catching such things and rarely make a fuss unless its real. I would take a look at the source in question and verify and/or bring it to the attention of the maintainer of the library.
mairswartz
Postby mairswartz » Thu Oct 15, 2020 7:39 am
@ nvannote
Brilliant!
That works perfectly.
Thank you vary much :D
Users browsing this forum: Amazon [Bot], ChatGPT-User and 3 guests
