ESP32-S2 ESP32-S3 engineering usb dongle "esp32-sx-stickley"
Postby rudi ;-) » Fri Oct 30, 2020 1:32 pm
Hi folks
based on the espressif's new mini series there comes an usb engineering sample to the maker market.
It is based on ESP32-S2-Mini-1 and ESP32-S2-Mini-1U
ESP32-S2 supports WiFi but also there is the same usb engineering sample to the maker market with an ESP32-S3, which support Wifi and Bluetooth and is based on the ESP32-S3-Mini serie's.
For people which can not wait to get the usb engineering sample there is a small batch available.
I got my personal usb dongle and can share with you guys the act and i will update this post step by step for more details, cause due the corona situation just in time, there are many problems for shipping worldwide it but not impossible, something is being prepared in this direction.
This talked usb dongle was designed purely for USB applications and deliberately refrained from bringing out all PINS. It is build to have only USB-OTG(Host/Device), JTAG, UART, / GPIO's [9] , Wifi and Bluetooth(S3) with your develop system and can be used as transparent USB Device to Wifi / Bluetooth / Wireless things too and for the Master oder Slave in your Application (SVR/CLI/MESH).
A further, little bigger (longer) version, is in testing phase now which is compatible to breadboards with using a platform connector and this has all pins breakout and further things.
Summarized, all is tiny and great same time - more infos follows soon.
- Stickley got requested PID's
- Stickley2021 Journey drafted and listed
- S2: Stickley-S2 foldered
- S3: Stickley-S3 foldered
edit 2021-Oct-09
add WINBOND Datasheet 1Gb latest rev C
W25Q01JV SPI RevC 05032021 Plus dummy.pdf
(2.46 MiB) Downloaded 664 times
Info: ESP32-S3-1Gb mod on the ESP32-S3-DevKitC-1-N8 successful
edit 2021-Nov-09
add ESP32-S3-Stickley to the Stickley Family
ESP32-S3-Stickley
..done!
edit 2022-Dec-01
add ESP32-S2 / ESP32-S3 uTF Stickley to the Stickley Family
ESP32-S2-USBuTF'23 , ESP32-S3-USBuTF'23 Stickley
..work's
edit 2022-Dec-05
add ESP32-S2-Santa-Stickley to the Stickley Family
..rocks :)
got a red pointed cap and another one to put in
edit 2022-Dec-06
add ESP32-S2-IPS to the Stickley Family
ESP32-S2-IPS engineering
..looks good to me :)
engineering #LoRaE5 Messenger on a Stickley SC Version #SCV
edit 2022-Dec-07
add ESP32-S2-HWS to the Stickley Family
ESP32-S2-HWS engineering got the USB HW Case now in the Prerelease
..gets pair mm longer with the case
( pics / link later )
edit 2022-Dec-08
add ESP32-SSC-S2 and ESP32-SSC-S3 to the Stickley Family
ESP32-SSC (S2/S3..C6/C5/H2) gets final uTF and all GPIO Break out, S3 also 47 & 48
..HOT so
edit 2022-Dec-09
add ESP32-Sx-Stickley purple
all bottomlayer 0201 and 0402 things now compressed on the frontlayer in one line
ESP32-Sx-Dongle
ESP32-S2-Dongle
ESP32-S3-Dongle
bobolink
Re: ESP32-S2 ESP32-S3 engineering usb dongle "esp32-sx-stickley"
Postby bobolink » Sat Oct 31, 2020 10:53 am
Can’t wait for any news on S3—mini or maxi
