Help ESP32-CAM PB with ESP32D0WDQ6 (revision 1) not with ESP32D0WDQ5 (revision 1)
Posted: Tue Nov 17, 2020 11:30 am
by MikeBee59
I have 2 ESP32-CAMs. The first to the version "Chip is ESP32D0WDQ5 (revision 1)", the second to the Chip is ESP32D0WDQ6 (revision 1) version.
The first one works very well. The second no. The boot starts indefinitely. I am using the Arduino IDE to load the code. Here is what it displays at boot:
rst: 0x3 (SW_RESET), boot: 0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP: 0xee
clk_drv: 0x00, q_drv: 0x00, d_drv: 0x00, cs0_drv: 0x00, hd_drv: 0x00, wp_drv: 0x00
mode: DIO, clock div: 1
load: 0x3fff0018, len: 4
load: 0x3fff001c, len: 1216
ho 0 tail 12 room 4
load: 0x40078000, len: 9720
ho 0 tail 12 room 4
load: 0x40080400, len: 6352
entry 0x400806b8
ets Jun 8 2016 00:22:57
and when loading by IDE Arduino :
Serial port COM3
Connecting ....
MAC: 8c: aa: b5: 85: d8: e4
Uploading stub ...
Running stub ...
Stub running ...
Can you help me please ?
Re: Help ESP32-CAM PB with ESP32D0WDQ6 (revision 1) not with ESP32D0WDQ5 (revision 1)
Posted: Tue Nov 17, 2020 12:23 pm
by Sprite
From memory, the 5 and 6 indicate the physical package the chip is in; electrically both are identical and should act entirely the same. That suggests your problem is elsewhere.
Posted: Tue Nov 17, 2020 3:21 pm
by MikeBee59
Thank you.
I close this post. There is indeed an electrical difference between these 2 versions of the chip. In IDE Arduino config, the V6 works with Flash Mode = "DIO" and not with Flash Mode = "QIO". The V5 works with Flash QIO mode. Why ? I don't have the answer.
Posted: Thu Sep 21, 2023 1:45 am
by ronaldandresmh
Hi MikeBee59, i just bought 7 board with chip esp32d0wdq6. Ive tried everything and i saw that you found the answer to my problem. Can you please explain what do you actually didi to the boards? Thank you!
