TCP/IP stack
esch_esp
TCP/IP stack
Postby esch_esp » Mon May 08, 2017 9:27 am
After experiencing unreliable TCP access (esp-idf 2.0), checking the code there seem to be some
inconsistency.
lwip/opt.h: here we define
#define TCP_LISTEN_BACKLOG 1
in tcp.c:
void tcp_pcb_purge(struct tcp_pcb *pcb)
if (pcb->state == SYN_RCVD)
in tcp_in.c:
static err_t tcp_process(struct tcp_pcb *pcb)
switch (pcb->state) {
case SYN_RCVD:
.... no call to tcp_pcb_purge at all !?
case FIN_WAIT_1:
tcp_pcb_purge(pcb);
case FIN_WAIT_2:
tcp_pcb_purge(pcb);
A workaround is to set TCP_LISTEN_BACKLOG 0
ScottEsp
Re: TCP/IP stack
Postby ScottEsp » Thu Jan 25, 2018 3:43 pm
Any update on how this worked out for you?
Users browsing this forum: Applebot, Google [Bot] and 4 guests
