SD Card which format should be
Hello, which format should the SD Card have (FAT, etc.) ? Is the a limit in capazity?
Re: SD Card which format should be
Hi wolsue,
currently, SD card APIs support the FAT filesystem.
SD cards larger than 32GB as per SDXC standard are formated using the exFAT file system and won't work with the ESP-IDF.
https://github.com/espressif/esp-idf/bl ... ple_main.c
https://en.wikipedia.org/wiki/SD_card
https://docs.espressif.com/projects/esp ... index.html
Users browsing this forum: Baidu [Spider], Bing [Bot], ChatGPT-User, Google [Bot], PerplexityBot, Qwantbot and 5 guests
