Clarification on SD_CARD Pins
Postby rudi ;-) » Tue May 09, 2017 9:37 am
hi
i have seen some circuits and all have the same "not ideal thinking" about SD Card.
the most creator think this for SD CARD
SD_CLK ( IO6 )
SD_DAT0 ( IO7 )
SD_DAT1 ( IO8 )
SD_DAT2 ( IO9)
SD_DAT3 ( IO10 )
SD_CMD ( IO11 )
be sure your circuit is well mean - this are pins for the SPI Flash
and just in time there is no sharing code available with this as SD Card and SPI Flash
the SD Card Demo example is on this pins
SD_HOST_CLK ( IO14 )
SD_HOST_D0 ( IO2 ) ( switched for Firmware flash )
SD_HOST_D1 ( IO4 )
SD_HOST_D2 ( IO12 )
SD_HOST_D3 ( IO13 )
SD_HOST_CMD ( IO15 )
hope this helps
@ivan
do you plan SD CARD SPI Version ?
Re: Clarification on SD_CARD Pins
Postby rudi ;-) » Mon May 22, 2017 6:59 am
Wire and Connection: 1-Bit Mode
You need Hardware Pullups!
Software Pullups does not work!
igrr
Postby igrr » Mon May 22, 2017 7:33 am
Yes, the SD SPI driver is almost ready! Hope to release it soon.
Postby rudi ;-) » Mon May 22, 2017 8:15 am
txs.
for completion now:
SD Mode
like the Demo in ESP-IDF
you can use 4Bit Mode (Dat0, Dat1, Dat2, Dat3) or 1Bit Mode (Dat0 )
SPI Mode ( driver comes like Ivan sayed )
you can drive by usually SPI Master then with MISO, MOSI, CLK, CS
Users browsing this forum: Bytespider and 3 guests
