Pipe of Subprocess in ANSI C
lcarnevale
Contact:
Postby lcarnevale » Mon Dec 07, 2020 10:25 am
Hello there,
I am interested in running a pipe of subprocesses written in ANSI C using the ESP32.
The following code is just a sample I have tried to run.
Code: Untitled.c Select all
int parse_output(void) {
char *cmd = "ls -l";
char buf[BUFSIZE];
FILE *fp;
if ((fp = popen(cmd, "r")) == NULL) {
printf("############## Error opening pipe!\n");
return -1;
while (fgets(buf, BUFSIZE, fp) != NULL) {
printf("############## OUTPUT: %s", buf);
if(pclose(fp)) {
printf("############## Command not found or exited with error status\n");
return -1;
return 0;
And the following is the error I receive
c:\esp\../main/app_main.c:139: undefined reference to `popen`
Is then possible to do it?
Lorenzo Carnevale
website: http://lorenzocarnevale.com
davidzuhn
Re: Pipe of Subprocess in ANSI C
Postby davidzuhn » Mon Dec 07, 2020 6:59 pm
The code running on the ESP32 is more like the kernel than an Unix-like process. There are no processes, just tasks within a single address space. So I'm not in any way surprised that popen isn't part of the available libraries.
Also, note that popen isn't part of ANSI C (it's probably standardized within POSIX), as it's very much an OS specific function, as opposed to a language / data structure library call.
You should look at FreeRTOS tasks if you want to run something "in parallel" with the existing code. It'll be a function within the SAME program that serves as the thing to run within the other task.
Postby Sprite » Tue Dec 08, 2020 1:29 am
ESP-IDF indeed does not support the notion of pipes. Suggest you look into using queues or (the ESP-IDF-specific) ringbuffers instead.
lcarnevale
Contact:
Postby lcarnevale » Mon Dec 14, 2020 7:56 am
Thanks for your reply.
Considering my intent was changing the ESP32's behavior in run-time, I was able to use the OTA for this purpose.
Lorenzo Carnevale
Users browsing this forum: Google [Bot], YisouSpider and 4 guests
