ESP32-CAM acting as SPI slave - External interrupt init error
jc2020
Postby jc2020 » Tue Dec 22, 2020 2:22 pm
Hello all,
I've been wanting to use an ESP32-CAM as a SPI slave to another ESP32 module.
The example SPI slave code on IDF V3.3 works very well, along with the ESP32-CAM demos from Github.
However when I join the two firmwares together, the camera initialization fails.
When I comment out
ret=spi_slave_initialize(HSPI_HOST, &buscfg, &slvcfg, 1);
the camera init succeeds and goes on to capturing an image.
This is the error I get:
Any thoughts?
Initializing slave...
Slave initialized!
Proceedi to init the camera...
Initializing camera...
I (1314) gpio: GPIO[5]| InputEn1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1314) gpio: GPIO[18]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1314) gpio: GPIO[19]| InputEn: 1| OutputEn: 0| OpenDrain:  Pullup: 1| Pulldown: 0| Intr:0
I (1324) gpio: GPIO[21]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1Pulldown: 0| Intr:0
I (1334) gpio: GPIO[22]| Inpun: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1344) gpio: GPIO[23]| InputEn: 1| Outpun: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
 (1354) gpio: GPIO[25]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1364) go: GPIO[34]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1|ulldown: 0| Intr:0
I (1374) gpio: GPIO[35]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0Intr:0
I (1384) gpio: GPIO[36]| InputEn: 1| Outpun: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1394) gpio: GPIO[39]| InputEn: 1| OutputEn: 0| OpenDin: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1404) sc: pin_sda 26 pin_scl 27
I (1404) gpio: GPIO[32]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldn: 0| Intr:0
I (1554) camera: Detected OV2640 camera
I (54) camera: Allocating 1 frame buffers (37 KB total)
I (1554) camera: Allocating 37 KB frame buffer innBoard RAM
E (1564) camera: gpio_install_isr_servi failed (105)
E (1564) camera: Camera init failed with error 0x105
E (1574) example:take_pictur Camera Init Failed
Here is the source code:
/* SPI Slave example, receiver (uses SPI Slave driver to communicate with sender)
#include <stdio.h>
#include <stdint.h>
#include <stddef.h>
#include <string.h>
#include "freertos/task.h"
#include "freertos/semphr.h"
#include "freertos/queue.h"
#include "lwip/sockets.h"
#include "lwip/dns.h"
#include "lwip/netdb.h"
#include "lwip/igmp.h"
#include "esp_wifi.h"
#include "esp_system.h"
#include "esp_event.h"
#include "esp_event_loop.h"
#include "nvs_flash.h"
#include "soc/rtc_cntl_reg.h"
#include "rom/cache.h"
#include "driver/spi_slave.h"
#include "esp_log.h"
#include "esp_spi_flash.h"
#include <sys/param.h>
#include <string.h>
#include "esp_camera.h"
SPI receiver (slave) example.
This example is supposed to work together with the SPI sender. It uses the standard SPI pins (MISO, MOSI, SCLK, CS) to
transmit data over in a full-duplex fashion, that is, while the master puts data on the MOSI pin, the slave puts its own
data on the MISO pin.
This example uses one extra pin: GPIO_HANDSHAKE is used as a handshake pin. After a transmission has been set up and we're
ready to send/receive data, this code uses a callback to set the handshake pin high. The sender will detect this and start
sending a transaction. As soon as the transaction is done, the line gets set low again.
Pins in use. The SPI Master can use the GPIO mux, so feel free to change these if needed.
#define GPIO_HANDSHAKE 2
#define GPIO_MOSI 13
#define GPIO_MISO 12
#define GPIO_SCLK 14
#define GPIO_CS 15
// ESP32Cam (AiThinker) PIN Map
#define CAM_PIN_PWDN 32
#define CAM_PIN_RESET -1 //software reset will be performed
#define CAM_PIN_XCLK 0
#define CAM_PIN_SIOD 26
#define CAM_PIN_SIOC 27
#define CAM_PIN_D7 35
#define CAM_PIN_D6 34
#define CAM_PIN_D5 39
#define CAM_PIN_D4 36
#define CAM_PIN_D3 21
#define CAM_PIN_D2 19
#define CAM_PIN_D1 18
#define CAM_PIN_D0 5
#define CAM_PIN_VSYNC 25
#define CAM_PIN_HREF 23
#define CAM_PIN_PCLK 22
DMA_ATTR char sendbuf[128]="";
DMA_ATTR char recvbuf[128]="";
static const char *TAG = "example:take_picture";
static camera_config_t camera_config = {
    .pin_pwdn = CAM_PIN_PWDN,
    .pin_reset = CAM_PIN_RESET,
    .pin_xclk = CAM_PIN_XCLK,
    .pin_sscb_sda = CAM_PIN_SIOD,
    .pin_sscb_scl = CAM_PIN_SIOC,
    .pin_d7 = CAM_PIN_D7,
    .pin_d6 = CAM_PIN_D6,
    .pin_d5 = CAM_PIN_D5,
    .pin_d4 = CAM_PIN_D4,
    .pin_d3 = CAM_PIN_D3,
    .pin_d2 = CAM_PIN_D2,
    .pin_d1 = CAM_PIN_D1,
    .pin_d0 = CAM_PIN_D0,
    .pin_vsync = CAM_PIN_VSYNC,
    .pin_href = CAM_PIN_HREF,
    .pin_pclk = CAM_PIN_PCLK,
    //XCLK 20MHz or 10MHz for OV2640 double FPS (Experimental)
    .xclk_freq_hz = 20000000,
    .ledc_timer = LEDC_TIMER_0,
    .ledc_channel = LEDC_CHANNEL_0,
    .pixel_format = PIXFORMAT_JPEG, //YUV422,GRAYSCALE,RGB565,JPEG
    .frame_size = FRAMESIZE_VGA,    //QQVGA-UXGA Do not use sizes above QVGA when not JPEG
    .jpeg_quality = 12, //0-63 lower number means higher quality
    .fb_count = 1       //if more than one, i2s runs in continuous mode. Use only with JPEG
static esp_err_t init_camera()
    //initialize the camera
    esp_err_t err = esp_camera_init(&camera_config);
    if (err != ESP_OK)
        ESP_LOGE(TAG, "Camera Init Failed");
        return err;
    return ESP_OK;
//Called after a transaction is queued and ready for pickup by master. We use this to set the handshake line high.
void my_post_setup_cb(spi_slave_transaction_t *trans) {
    WRITE_PERI_REG(GPIO_OUT_W1TS_REG, (1<<GPIO_HANDSHAKE));
//Called after transaction is sent/received. We use this to set the handshake line low.
void my_post_trans_cb(spi_slave_transaction_t *trans) {
    WRITE_PERI_REG(GPIO_OUT_W1TC_REG, (1<<GPIO_HANDSHAKE));
//Main application
void app_main()
    int n=0;
    esp_err_t ret;
    //Configuration for the SPI bus
    spi_bus_config_t buscfg={
        .mosi_io_num=GPIO_MOSI,
        .miso_io_num=GPIO_MISO,
        .sclk_io_num=GPIO_SCLK
    //Configuration for the SPI slave interface
    spi_slave_interface_config_t slvcfg={
        .mode=0,
        .spics_io_num=GPIO_CS,
        .queue_size=3,
        .flags=0,
        .post_setup_cb=my_post_setup_cb,
        .post_trans_cb=my_post_trans_cb
    //Configuration for the handshake line
    gpio_config_t io_conf={
        .intr_type=GPIO_INTR_DISABLE,
        .mode=GPIO_MODE_OUTPUT,
        .pin_bit_mask=(1<<GPIO_HANDSHAKE)
    //Configure handshake line as output
    gpio_config(&io_conf);
    //Enable pull-ups on SPI lines so we don't detect rogue pulses when no master is connected.
    gpio_set_pull_mode(GPIO_MOSI, GPIO_PULLUP_ONLY);
    gpio_set_pull_mode(GPIO_SCLK, GPIO_PULLUP_ONLY);
    gpio_set_pull_mode(GPIO_CS, GPIO_PULLUP_ONLY);
    //Initialize SPI slave interface
    printf("Initializing slave...\n");
    assert(ret==ESP_OK);
    printf("Slave initialized!\n");
    //char sendbuf[129]="";
    //char recvbuf[129]="";
    memset(recvbuf, 0, 33);
    spi_slave_transaction_t t;
    memset(&t, 0, sizeof(t));
    printf("Proceeding to init the camera...\n");
    vTaskDelay(1000 / portTICK_RATE_MS);
    printf("Initializing camera...\n");
    ret = init_camera();
	printf("Camera init complete!\n");
    while(1) {
        //Clear receive buffer, set send buffer to something sane
        memset(recvbuf, 0xA5, 129);
        sprintf(sendbuf, "This is the ESP32-CAM, slave %04d.", n);
        //Set up a transaction of 128 bytes to send/receive
        t.length=128*8;
        t.tx_buffer=sendbuf;
        t.rx_buffer=recvbuf;
        /* This call enables the SPI slave interface to send/receive to the sendbuf and recvbuf. The transaction is
        initialized by the SPI master, however, so it will not actually happen until the master starts a hardware transaction
        by pulling CS low and pulsing the clock etc. In this specific example, we use the handshake line, pulled up by the
        .post_setup_cb callback that is called as soon as a transaction is ready, to let the master know it is free to transfer
        data.
        ret=spi_slave_transmit(HSPI_HOST, &t, portMAX_DELAY);
        //spi_slave_transmit does not return until the master has done a transmission, so by here we have sent our data and
        //received data from the master. Print it.
        printf("Received: %s\n", recvbuf);
        n++;
        ESP_LOGI(TAG, "Taking picture...");
        camera_fb_t *pic = esp_camera_fb_get();
        // use pic->buf to access the image
        ESP_LOGI(TAG, "Picture taken! Its size was: %zu bytes", pic->len);
        vTaskDelay(5000 / portTICK_RATE_MS);
jc2020
Re: ESP32-CAM acting as SPI slave - External interrupt init error
Postby jc2020 » Wed Dec 23, 2020 11:52 am
I found that the issue is something to do with the ISR. The following init before my camera init seems to solve the issue. Not 100% sure why this is, and feels like a hack so if anyone has any info, please comment!
gpio_install_isr_service(0);
Users browsing this forum: Applebot, Baidu [Spider], PetalBot and 2 guests
