'esp_wifi_get_inactive_time' was not declared in this scope
digsub
Postby digsub » Mon Dec 28, 2020 10:36 am
ESP-IDF function esp_wifi_get_inactive_time() is found in esp_wifi.h, but code below won't compile in Arduino IDE 1.8.13 due to 'esp_wifi_get_inactive_time' was not declared in this scope
other functions in esp_wifi.h e.g. esp_wifi_set_bandwidth() are fine.
Checked spelling, conflicts, etc & I can't find the cause. Thanks!
#include <WiFi.h>
#include "esp_wifi.h"
  ESP_ERROR_CHECK(esp_wifi_set_bandwidth(ESP_IF_WIFI_STA, WIFI_BW_HT20));
  ESP_ERROR_CHECK(esp_wifi_set_bandwidth(ESP_IF_WIFI_AP, WIFI_BW_HT20));
  uint16_t sec;
  ESP_ERROR_CHECK(esp_wifi_get_inactive_time(ESP_IF_WIFI_AP, &sec));
void loop() {}
Jan
Re: 'esp_wifi_get_inactive_time' was not declared in this scope
Postby Jan » Wed Dec 30, 2020 2:08 am
Hi digsub,
you are experiencing this issue because the arduino-esp32 is not the same as ESP-IDF.
The header file esp_wifi.h from arduino-esp32 can be found here:
https://github.com/espressif/arduino-es ... esp_wifi.h
To use the function esp_wifi_get_inactive_time you may want to consider to moving your development to the ESP-IDF.
Feel free to post any follow-up questions.
Jan
Users browsing this forum: Applebot, Baidu [Spider], Qwantbot and 0 guests
