Play wav snippets in a loop
Posted: Mon Jan 04, 2021 10:35 pm
Hi guys,
how can one play wave snippets in a loop?
I want to build a music box and couldn't find anything in the net.
This is the pipeline I have which works fine for one time play:
I added a callback on the fatfs_reader, which triggers if there is no data left:
Any other hints? recommendations?
audio_pipeline_register(pipeline_play, fatfs_reader_el, "file_reader");
audio_pipeline_register(pipeline_play, wav_decoder_el, "wav_decoder");
audio_pipeline_register(pipeline_play, sonic_el, "sonic");
audio_pipeline_register(pipeline_play, i2s_writer_el, "i2s_writer");
const char *link_play[4] = {"file_reader", "wav_decoder", "sonic", "i2s_writer"};
audio_pipeline_link(pipeline_play, &link_play[0], 4);Code: Select all
audio_element_set_event_callback(wav_decoder_el, audio_element_event_handler, NULL);
esp_err_t audio_element_event_handler(audio_element_handle_t self, audio_event_iface_msg_t *event, void *ctx)
ESP_LOGI(TAG, "Audio event %d from %s element", event->cmd, audio_element_get_tag(self));
if (event->cmd == AEL_MSG_CMD_REPORT_STATUS)
switch ((int)event->data)
case AEL_STATUS_STATE_RUNNING:
ESP_LOGI(TAG, "AEL_STATUS_STATE_RUNNING");
break;
case AEL_STATUS_STATE_STOPPED:
ESP_LOGI(TAG, "AEL_STATUS_STATE_STOPPED");
break;
case AEL_STATUS_STATE_FINISHED:
ESP_LOGI(TAG, "AEL_STATUS_STATE_FINISHED");
//create_fatfs_stream(SAMPLE_RATE, BITS, CHANNEL, AUDIO_STREAM_READER);
// audio_pipeline_reset_items_state(pipeline_play);
// fatfs_reader_el = create_fatfs_stream(SAMPLE_RATE, BITS, CHANNEL, AUDIO_STREAM_READER);
// audio_element_info_t writer_info = {0};
// audio_element_getinfo(fatfs_reader_el, &writer_info);
// ESP_LOGI(TAG, "%d Total bytes", (int)writer_info.total_bytes);
/* what has to be done here to make it play from the beginning? */
audio_element_set_byte_pos(fatfs_reader_el,0);
event->data = AEL_STATUS_STATE_RUNNING;
break;
default:
ESP_LOGI(TAG, "Some other event = %d", (int)event->data);
return ESP_OK;
