HI
i HAVE USED FIRST RELEASE OF ESP-IDF-MASTER SDK IN THAT DAC DRIVER IS WORKING.( i USED FOR AUDIO AMPLIFIER) BUT LATEST VERSION OF ESP-IDF DAC IS NOT WORKING. IT IS LINKED WITH RTC. PLS SUGGEST ME ANY EXAMPLE OF DAC DRIVER.
THANKS.
DAC is not working
Re: DAC IS NOT WORKING
I think in the current version you should first call and then you can call
dac_output_enableCode: Select all
dac_output_voltageRe: DAC IS NOT WORKING
hiHI
THANKS.
please, use not only upper-case letters - this stands for "Cry out, be angry, scold" - are you angry?
"any example" is the most example here named ESP32 Webradio
rudi
Users browsing this forum: No registered users and 6 guests
