Guru Meditation Error while accessing PSRAM
salbdch
Postby salbdch » Mon Jan 11, 2021 10:25 am
I have board rebooting problem while allocating frame buffer in PSRAM for OV5640 camera.
Any guide for me to fix this problem?
Regards,
1. Logging Camera-webserver-demo with ESP-EYE board. (Booting Success)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:4
load:0x3fff0034,len:5640
load:0x40078000,len:14084
load:0x40080400,len:4324
entry 0x40080658
I (382) psram: This chip is ESP32-D0WD
I (382) spiram: Found 64MBit SPI RAM device
I (383) spiram: SPI RAM mode: flash 80m sram 40m
I (385) spiram: PSRAM initialized, cache is in low/high (2-core) mode.
I (392) cpu_start: Pro cpu up.
I (396) cpu_start: Application information:
I (401) cpu_start: Project name:     camera_web_server
I (407) cpu_start: App version:      v0.9.3-60-g73d4e2d-dirty
I (413) cpu_start: Compile time:     Dec 31 2020 12:58:16
I (419) cpu_start: ELF file SHA256:  0fedb032fcbe2bae...
I (425) cpu_start: ESP-IDF:          v4.1-dirty
I (431) cpu_start: Starting app cpu, entry point is 0x40081628
I (0) cpu_start: App cpu up.
I (1321) spiram: SPI SRAM memory test OK
I (1321) heap_init: Initializing. RAM available for dynamic allocation:
I (1322) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (1328) heap_init: At 3FFBE308 len 00021CF8 (135 KiB): DRAM
I (1334) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (1341) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1347) heap_init: At 4009C398 len 00003C68 (15 KiB): IRAM
I (1353) cpu_start: Pro cpu start user code
I (1358) spiram: Adding pool of 4096K of external SPI memory to heap allocator
I (1378) spi_flash: detected chip: generic
I (1379) spi_flash: flash io: qio
I (1379) cpu_start: Starting scheduler on PRO CPU.
I (1483) wifi:wifi driver task: 3ffc6848, prio:23, stack:6656, core=0
I (1483) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (1503) wifi:wifi firmware version: 3ea4c76
I (1503) wifi:config NVS flash: enabled
I (1503) wifi:config nano formating: disabled
I (1503) wifi:Init dynamic tx buffer num: 32
I (1513) wifi:Init data frame dynamic rx buffer num: 32
I (1513) wifi:Init management frame dynamic rx buffer num: 32
I (1523) wifi:Init management short buffer num: 32
I (1523) wifi:Init static tx buffer num: 16
I (1533) wifi:Init static rx buffer size: 1600
I (1533) wifi:Init static rx buffer num: 10
I (1543) wifi:Init dynamic rx buffer num: 32
I (1543) camera wifi: wifi_init_softap finished.SSID:KIOT-OV5640 password:
I (1643) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0
I (1653) wifi:mode : softAP (ac:67:b2:56:9a:09)
I (1653) wifi:Total power save buffer number: 8
I (1653) wifi:Init max length of beacon: 752/752
I (1663) wifi:Set ps type: 0
I (1663) gpio: GPIO[13]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1673) gpio: GPIO[14]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1683) gpio: GPIO[5]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1693) gpio: GPIO[13]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1703) gpio: GPIO[14]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1713) gpio: GPIO[25]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1723) gpio: GPIO[27]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1733) gpio: GPIO[34]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1743) gpio: GPIO[35]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1753) gpio: GPIO[36]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1753) gpio: GPIO[37]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1763) gpio: GPIO[38]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1773) gpio: GPIO[39]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1783) sccb: pin_sda 18 pin_scl 23
I (2493) camera: Detected OV5640 camera
I (2493) camera: Allocating 2 frame buffers (1920 KB total)
I (2493) camera: Allocating 960 KB frame buffer in PSRAM
I (2753) camera: Allocating 960 KB frame buffer in PSRAM
I (3063) camera_httpd: Starting web server on port: '80'
I (3073) camera_httpd: Starting stream server on port: '81'
I (3073) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
2. Logging Camera-webserver-demo with my custom board which use esp32-wrover-e module (Booting Failed)
mode:DIO, clock div:2
entry 0x40080658
I (415) psram: This chip is ESP32-D0WD
I (416) spiram: Found 64MBit SPI RAM device
I (416) spiram: SPI RAM mode: flash 80m sram 40m
I (419) spiram: PSRAM initialized, cache is in low/high (2-core) mode.
I (426) cpu_start: Pro cpu up.
I (430) cpu_start: Application information:
I (434) cpu_start: Project name:     camera_web_server
I (440) cpu_start: App version:      v0.9.3-60-g73d4e2d-dirty
I (447) cpu_start: Compile time:     Dec 31 2020 21:06:50
I (453) cpu_start: ELF file SHA256:  8674791e2127d7d9...
I (459) cpu_start: ESP-IDF:          v4.1-dirty
I (464) cpu_start: Starting app cpu, entry point is 0x40081628
I (1357) spiram: SPI SRAM memory test OK
I (1357) heap_init: Initializing. RAM available for dynamic allocation:
I (1358) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (1364) heap_init: At 3FFBE308 len 00021CF8 (135 KiB): DRAM
I (1370) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (1377) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1383) heap_init: At 4009C398 len 00003C68 (15 KiB): IRAM
I (1389) cpu_start: Pro cpu start user code
I (1394) spiram: Adding pool of 4096K of external SPI memory to heap allocator
I (1414) spi_flash: detected chip: gd
I (1415) spi_flash: flash io: qio
I (1415) cpu_start: Starting scheduler on PRO CPU.
I (1498) wifi:wifi driver task: 3ffc6848, prio:23, stack:6656, core=0
I (1498) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (1518) wifi:wifi firmware version: 3ea4c76
I (1518) wifi:config NVS flash: enabled
I (1518) wifi:config nano formating: disabled
I (1518) wifi:Init dynamic tx buffer num: 32
I (1528) wifi:Init data frame dynamic rx buffer num: 32
I (1528) wifi:Init management frame dynamic rx buffer num: 32
I (1538) wifi:Init management short buffer num: 32
I (1538) wifi:Init static tx buffer num: 16
I (1548) wifi:Init static rx buffer size: 1600
I (1548) wifi:Init static rx buffer num: 10
I (1558) wifi:Init dynamic rx buffer num: 32
I (1558) camera wifi: wifi_init_softap finished.SSID:KIOT-OV5640 password:
I (1658) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0
I (1658) wifi:mode : softAP (40:f5:20:5b:05:e5)
I (1658) wifi:Total power save buffer number: 8
I (1658) wifi:Init max length of beacon: 752/752
I (1668) wifi:Init max length of beacon: 752/752
I (1668) wifi:Set ps type: 0
I (1678) gpio: GPIO[16]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1678) gpio: GPIO[21]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1688) gpio: GPIO[23]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1698) gpio: GPIO[25]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1708) gpio: GPIO[26]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1718) gpio: GPIO[32]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1728) gpio: GPIO[33]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1738) gpio: GPIO[34]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1748) gpio: GPIO[35]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1758) gpio: GPIO[36]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1768) gpio: GPIO[39]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1778) sccb: pin_sda 18 pin_scl 22
I (2478) camera: Detected OV5640 camera
I (2478) camera: Allocating 2 frame buffers (1920 KB total)
I (2478) camera: Allocating 960 KB frame buffer in PSRAM
Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:
PC      : 0x4009141c  PS      : 0x00060330  A0      : 0x80084470  A1      : 0x3ffc0080
A2      : 0x3f800000  A3      : 0x000f0000  A4      : 0x00000000  A5      : 0x0000000c
A6      : 0x0000001f  A7      : 0x00000001  A8      : 0x00000000  A9      : 0xffffffff
A10     : 0x3f800010  A11     : 0xffffffff  A12     : 0x3f800014  A13     : 0x00000000
A14     : 0x00000044  A15     : 0x3ffbff30  SAR     : 0x00000004  EXCCAUSE: 0x0000001c
EXCVADDR: 0xffffffff  LBEG    : 0x4008b3c9  LEND    : 0x4008b3d9  LCOUNT  : 0xfffffffe
Backtrace: 0x40091419:0x3ffc0080 0x4008446d:0x3ffc00a0 0x4008469a:0x3ffc00c0 0x400e213e:0x3ffc00e0 0x400e299d:0x3ffc0110 0x400e2d11:0x3ffc0140 0x400d94a1:0x3ffc0170 0x400d8ff6:0x3ffc0220 0x400d31c0:0x3ffc0240 0x4008d789:0x3ffc0260
Rebooting...
ets Jul 29 2019 12:21:46
Re: Guru Meditation Error while accessing PSRAM
Postby Sprite » Tue Jan 12, 2021 2:40 am
That is strange... can you decode that backtrace? Is the firmware 100% the same on both boards, or did you need to change things because e.g. different board layouts?
abansal22
Postby abansal22 » Tue Jan 12, 2021 7:30 am
Regards,
entry 0x40080658
entry 0x40080658
Rebooting...
This error arises due to the allocation of the buffer on the psRam. Please provide the menu configuration for the spiRam.
Also I read somewhere that the some board throw the error when there is no enough power supply to them. It seems that it has been powered by the computer/ laptop. Try to connect to the 5v stable power supply.
Thanks!
salbdch
Postby salbdch » Tue Jan 12, 2021 5:06 pm
Regards,
entry 0x40080658
entry 0x40080658
Rebooting...
Thanks!
(Top) → Component config → ESP32-specific → Support for external, SPI-connected RAM → SPI RAM config
Espressif IoT Development Framework Configuration
Type of SPI RAM chip in use (Auto-detect) ---> Set RAM clock speed (40MHz clock speed) ---> [*] Initialize SPI RAM during startup [ ] Ignore PSRAM when not found SPI RAM access method (Make RAM allocatable using malloc() as well) ---> [*] Run memory test on SPI RAM initialization (16384) Maximum malloc() size, in bytes, to always put in internal memory [ ] Try to allocate memories of WiFi and LWIP in SPIRAM firstly. If failed, allocate internal memory (32768) Reserve this amount of bytes for data that specifically needs to be in DMA or internal memory [ ] Allow .bss segment placed in external memory [*] Enable workaround for bug in SPI RAM cache for Rev1 ESP32s SPIRAM cache workaround debugging ---> [*] Enable bank switching for >4MiB external RAM (8) Amount of 32K pages to reserve for bank switching [ ] Allow external memory as an argument to xTaskCreateStatic PSRAM clock and cs IO for ESP32-DOWD ---> PSRAM clock and cs IO for ESP32-D2WD ---> PSRAM clock and cs IO for ESP32-PICO ---> [ ] Enable SPI PSRAM 2T mode
salbdch
Postby salbdch » Tue Jan 12, 2021 5:59 pm
I think Flash memory size and OV5640 camera interface is different.
Below is about my custom board.
# Automatically generated file. DO NOT EDIT.
# Espressif IoT Development Framework (ESP-IDF) Project Configuration
CONFIG_IDF_CMAKE=y
CONFIG_IDF_TARGET="esp32"
CONFIG_IDF_TARGET_ESP32=y
CONFIG_IDF_FIRMWARE_CHIP_ID=0x0000
# SDK tool configuration
CONFIG_SDK_TOOLPREFIX="xtensa-esp32-elf-"
# CONFIG_SDK_TOOLCHAIN_SUPPORTS_TIME_WIDE_64_BITS is not set
# end of SDK tool configuration
# Build type
CONFIG_APP_BUILD_TYPE_APP_2NDBOOT=y
# CONFIG_APP_BUILD_TYPE_ELF_RAM is not set
CONFIG_APP_BUILD_GENERATE_BINARIES=y
CONFIG_APP_BUILD_BOOTLOADER=y
CONFIG_APP_BUILD_USE_FLASH_SECTIONS=y
# end of Build type
# Application manager
CONFIG_APP_COMPILE_TIME_DATE=y
# CONFIG_APP_EXCLUDE_PROJECT_VER_VAR is not set
# CONFIG_APP_EXCLUDE_PROJECT_NAME_VAR is not set
CONFIG_APP_RETRIEVE_LEN_ELF_SHA=16
# end of Application manager
# Bootloader config
CONFIG_BOOTLOADER_COMPILER_OPTIMIZATION_SIZE=y
# CONFIG_BOOTLOADER_COMPILER_OPTIMIZATION_DEBUG is not set
# CONFIG_BOOTLOADER_COMPILER_OPTIMIZATION_PERF is not set
# CONFIG_BOOTLOADER_COMPILER_OPTIMIZATION_NONE is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_NONE is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_ERROR is not set
CONFIG_BOOTLOADER_LOG_LEVEL_WARN=y
# CONFIG_BOOTLOADER_LOG_LEVEL_INFO is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_DEBUG is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_VERBOSE is not set
CONFIG_BOOTLOADER_LOG_LEVEL=2
CONFIG_BOOTLOADER_SPI_WP_PIN=7
CONFIG_BOOTLOADER_VDDSDIO_BOOST_1_9V=y
# CONFIG_BOOTLOADER_FACTORY_RESET is not set
# CONFIG_BOOTLOADER_APP_TEST is not set
CONFIG_BOOTLOADER_WDT_ENABLE=y
# CONFIG_BOOTLOADER_WDT_DISABLE_IN_USER_CODE is not set
CONFIG_BOOTLOADER_WDT_TIME_MS=9000
# CONFIG_BOOTLOADER_APP_ROLLBACK_ENABLE is not set
# CONFIG_BOOTLOADER_SKIP_VALIDATE_IN_DEEP_SLEEP is not set
CONFIG_BOOTLOADER_RESERVE_RTC_SIZE=0
# CONFIG_BOOTLOADER_CUSTOM_RESERVE_RTC is not set
# end of Bootloader config
# Security features
# CONFIG_SECURE_SIGNED_APPS_NO_SECURE_BOOT is not set
# CONFIG_SECURE_BOOT is not set
# CONFIG_SECURE_FLASH_ENC_ENABLED is not set
# end of Security features
# Serial flasher config
CONFIG_ESPTOOLPY_BAUD_OTHER_VAL=115200
CONFIG_ESPTOOLPY_FLASHMODE_QIO=y
# CONFIG_ESPTOOLPY_FLASHMODE_QOUT is not set
# CONFIG_ESPTOOLPY_FLASHMODE_DIO is not set
# CONFIG_ESPTOOLPY_FLASHMODE_DOUT is not set
CONFIG_ESPTOOLPY_FLASHMODE="dio"
CONFIG_ESPTOOLPY_FLASHFREQ_80M=y
# CONFIG_ESPTOOLPY_FLASHFREQ_40M is not set
# CONFIG_ESPTOOLPY_FLASHFREQ_26M is not set
# CONFIG_ESPTOOLPY_FLASHFREQ_20M is not set
CONFIG_ESPTOOLPY_FLASHFREQ="80m"
# CONFIG_ESPTOOLPY_FLASHSIZE_1MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_2MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_4MB is not set
CONFIG_ESPTOOLPY_FLASHSIZE_8MB=y
# CONFIG_ESPTOOLPY_FLASHSIZE_16MB is not set
CONFIG_ESPTOOLPY_FLASHSIZE="8MB"
CONFIG_ESPTOOLPY_FLASHSIZE_DETECT=y
CONFIG_ESPTOOLPY_BEFORE_RESET=y
# CONFIG_ESPTOOLPY_BEFORE_NORESET is not set
CONFIG_ESPTOOLPY_BEFORE="default_reset"
CONFIG_ESPTOOLPY_AFTER_RESET=y
# CONFIG_ESPTOOLPY_AFTER_NORESET is not set
CONFIG_ESPTOOLPY_AFTER="hard_reset"
# CONFIG_ESPTOOLPY_MONITOR_BAUD_9600B is not set
# CONFIG_ESPTOOLPY_MONITOR_BAUD_57600B is not set
CONFIG_ESPTOOLPY_MONITOR_BAUD_115200B=y
# CONFIG_ESPTOOLPY_MONITOR_BAUD_230400B is not set
# CONFIG_ESPTOOLPY_MONITOR_BAUD_921600B is not set
# CONFIG_ESPTOOLPY_MONITOR_BAUD_2MB is not set
# CONFIG_ESPTOOLPY_MONITOR_BAUD_OTHER is not set
CONFIG_ESPTOOLPY_MONITOR_BAUD_OTHER_VAL=115200
CONFIG_ESPTOOLPY_MONITOR_BAUD=115200
# end of Serial flasher config
# Partition Table
# CONFIG_PARTITION_TABLE_SINGLE_APP is not set
# CONFIG_PARTITION_TABLE_TWO_OTA is not set
CONFIG_PARTITION_TABLE_CUSTOM=y
CONFIG_PARTITION_TABLE_CUSTOM_FILENAME="partitions.csv"
CONFIG_PARTITION_TABLE_FILENAME="partitions.csv"
CONFIG_PARTITION_TABLE_OFFSET=0x8000
CONFIG_PARTITION_TABLE_MD5=y
# end of Partition Table
# Camera Web Server
# WiFi Settings
CONFIG_ESP_HOST_NAME=""
CONFIG_ESP_WIFI_SSID=""
CONFIG_ESP_WIFI_PASSWORD=""
CONFIG_ESP_WIFI_AP_SSID="KIOT-OV5640"
CONFIG_ESP_WIFI_AP_PASSWORD=""
CONFIG_MAX_STA_CONN=1
CONFIG_ESP_WIFI_AP_CHANNEL=""
CONFIG_SERVER_IP="192.168.1.1"
CONFIG_ESP_MAXIMUM_RETRY=5
# end of WiFi Settings
# LED Illuminator
CONFIG_LED_ILLUMINATOR_ENABLED=y
CONFIG_LED_LEDC_PIN=4
CONFIG_LED_MAX_INTENSITY=255
CONFIG_LED_LEDC_LOW_SPEED_MODE=y
# CONFIG_LED_LEDC_HIGH_SPEED_MODE is not set
CONFIG_LED_LEDC_TIMER=1
CONFIG_LED_LEDC_CHANNEL=1
# end of LED Illuminator
# Camera Pins
# CONFIG_CAMERA_MODEL_WROVER_KIT is not set
# CONFIG_CAMERA_MODEL_ESP32_CAM_BOARD is not set
# CONFIG_CAMERA_MODEL_ESP_EYE is not set
# CONFIG_CAMERA_MODEL_M5STACK_PSRAM is not set
# CONFIG_CAMERA_MODEL_M5STACK_WIDE is not set
# CONFIG_CAMERA_MODEL_AI_THINKER is not set
CONFIG_CAMERA_MODEL_CUSTOM=y
CONFIG_CAMERA_PIN_PWDN=-1
CONFIG_CAMERA_PIN_RESET=-1
CONFIG_CAMERA_PIN_XCLK=19
CONFIG_CAMERA_PIN_SIOD=18
CONFIG_CAMERA_PIN_SIOC=22
CONFIG_CAMERA_PIN_VSYNC=21
CONFIG_CAMERA_PIN_HREF=16
CONFIG_CAMERA_PIN_PCLK=23
CONFIG_CAMERA_PIN_Y2=32
CONFIG_CAMERA_PIN_Y3=25
CONFIG_CAMERA_PIN_Y4=26
CONFIG_CAMERA_PIN_Y5=33
CONFIG_CAMERA_PIN_Y6=39
CONFIG_CAMERA_PIN_Y7=35
CONFIG_CAMERA_PIN_Y8=34
CONFIG_CAMERA_PIN_Y9=36
# end of Camera Pins
# CONFIG_ESP_FACE_DETECT_ENABLED is not set
# end of Camera Web Server
# Compiler options
CONFIG_COMPILER_OPTIMIZATION_DEFAULT=y
# CONFIG_COMPILER_OPTIMIZATION_SIZE is not set
# CONFIG_COMPILER_OPTIMIZATION_PERF is not set
# CONFIG_COMPILER_OPTIMIZATION_NONE is not set
CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_ENABLE=y
# CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_SILENT is not set
# CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_DISABLE is not set
# CONFIG_COMPILER_CXX_EXCEPTIONS is not set
# CONFIG_COMPILER_CXX_RTTI is not set
CONFIG_COMPILER_STACK_CHECK_MODE_NONE=y
# CONFIG_COMPILER_STACK_CHECK_MODE_NORM is not set
# CONFIG_COMPILER_STACK_CHECK_MODE_STRONG is not set
# CONFIG_COMPILER_STACK_CHECK_MODE_ALL is not set
# CONFIG_COMPILER_WARN_WRITE_STRINGS is not set
# CONFIG_COMPILER_DISABLE_GCC8_WARNINGS is not set
# end of Compiler options
# Component config
# Application Level Tracing
# CONFIG_APPTRACE_DEST_TRAX is not set
CONFIG_APPTRACE_DEST_NONE=y
CONFIG_APPTRACE_LOCK_ENABLE=y
# end of Application Level Tracing
# Bluetooth
# CONFIG_BT_ENABLED is not set
CONFIG_BTDM_CTRL_BR_EDR_SCO_DATA_PATH_EFF=0
CONFIG_BTDM_CTRL_BLE_MAX_CONN_EFF=0
CONFIG_BTDM_CTRL_BR_EDR_MAX_ACL_CONN_EFF=0
CONFIG_BTDM_CTRL_BR_EDR_MAX_SYNC_CONN_EFF=0
CONFIG_BTDM_CTRL_PINNED_TO_CORE=0
CONFIG_BTDM_BLE_SLEEP_CLOCK_ACCURACY_INDEX_EFF=1
CONFIG_BT_RESERVE_DRAM=0
# end of Bluetooth
# CONFIG_BLE_MESH is not set
# CoAP Configuration
CONFIG_COAP_MBEDTLS_PSK=y
# CONFIG_COAP_MBEDTLS_PKI is not set
# CONFIG_COAP_MBEDTLS_DEBUG is not set
CONFIG_COAP_LOG_DEFAULT_LEVEL=0
# end of CoAP Configuration
# Driver configurations
# ADC configuration
# CONFIG_ADC_FORCE_XPD_FSM is not set
CONFIG_ADC_DISABLE_DAC=y
# end of ADC configuration
# SPI configuration
# CONFIG_SPI_MASTER_IN_IRAM is not set
CONFIG_SPI_MASTER_ISR_IN_IRAM=y
# CONFIG_SPI_SLAVE_IN_IRAM is not set
CONFIG_SPI_SLAVE_ISR_IN_IRAM=y
# end of SPI configuration
# UART configuration
# CONFIG_UART_ISR_IN_IRAM is not set
# end of UART configuration
# RTCIO configuration
# CONFIG_RTCIO_SUPPORT_RTC_GPIO_DESC is not set
# end of RTCIO configuration
# end of Driver configurations
# eFuse Bit Manager
# CONFIG_EFUSE_CUSTOM_TABLE is not set
# CONFIG_EFUSE_VIRTUAL is not set
# CONFIG_EFUSE_CODE_SCHEME_COMPAT_NONE is not set
CONFIG_EFUSE_CODE_SCHEME_COMPAT_3_4=y
# CONFIG_EFUSE_CODE_SCHEME_COMPAT_REPEAT is not set
CONFIG_EFUSE_MAX_BLK_LEN=192
# end of eFuse Bit Manager
# ESP-TLS
CONFIG_ESP_TLS_USING_MBEDTLS=y
# CONFIG_ESP_TLS_SERVER is not set
# CONFIG_ESP_TLS_PSK_VERIFICATION is not set
# end of ESP-TLS
# ESP32-specific
CONFIG_ESP32_REV_MIN_0=y
# CONFIG_ESP32_REV_MIN_1 is not set
# CONFIG_ESP32_REV_MIN_2 is not set
# CONFIG_ESP32_REV_MIN_3 is not set
CONFIG_ESP32_REV_MIN=0
CONFIG_ESP32_DPORT_WORKAROUND=y
# CONFIG_ESP32_DEFAULT_CPU_FREQ_80 is not set
# CONFIG_ESP32_DEFAULT_CPU_FREQ_160 is not set
CONFIG_ESP32_DEFAULT_CPU_FREQ_240=y
CONFIG_ESP32_DEFAULT_CPU_FREQ_MHZ=240
CONFIG_ESP32_SPIRAM_SUPPORT=y
# SPI RAM config
CONFIG_SPIRAM_TYPE_AUTO=y
# CONFIG_SPIRAM_TYPE_ESPPSRAM32 is not set
# CONFIG_SPIRAM_TYPE_ESPPSRAM64 is not set
CONFIG_SPIRAM_SIZE=-1
CONFIG_SPIRAM_SPEED_40M=y
# CONFIG_SPIRAM_SPEED_80M is not set
CONFIG_SPIRAM=y
CONFIG_SPIRAM_BOOT_INIT=y
# CONFIG_SPIRAM_IGNORE_NOTFOUND is not set
CONFIG_SPIRAM_USE_MEMMAP=y
# CONFIG_SPIRAM_USE_CAPS_ALLOC is not set
# CONFIG_SPIRAM_USE_MALLOC is not set
CONFIG_SPIRAM_MEMTEST=y
# CONFIG_SPIRAM_ALLOW_BSS_SEG_EXTERNAL_MEMORY is not set
CONFIG_SPIRAM_CACHE_WORKAROUND=y
# SPIRAM cache workaround debugging
CONFIG_SPIRAM_CACHE_WORKAROUND_STRATEGY_MEMW=y
# CONFIG_SPIRAM_CACHE_WORKAROUND_STRATEGY_DUPLDST is not set
# CONFIG_SPIRAM_CACHE_WORKAROUND_STRATEGY_NOPS is not set
# end of SPIRAM cache workaround debugging
CONFIG_SPIRAM_BANKSWITCH_ENABLE=y
CONFIG_SPIRAM_BANKSWITCH_RESERVE=8
# PSRAM clock and cs IO for ESP32-DOWD
CONFIG_D0WD_PSRAM_CLK_IO=17
CONFIG_D0WD_PSRAM_CS_IO=16
# end of PSRAM clock and cs IO for ESP32-DOWD
# PSRAM clock and cs IO for ESP32-D2WD
CONFIG_D2WD_PSRAM_CLK_IO=9
CONFIG_D2WD_PSRAM_CS_IO=10
# end of PSRAM clock and cs IO for ESP32-D2WD
# PSRAM clock and cs IO for ESP32-PICO
CONFIG_PICO_PSRAM_CS_IO=10
# end of PSRAM clock and cs IO for ESP32-PICO
# CONFIG_SPIRAM_2T_MODE is not set
# end of SPI RAM config
# CONFIG_ESP32_TRAX is not set
CONFIG_ESP32_TRACEMEM_RESERVE_DRAM=0x0
# CONFIG_ESP32_UNIVERSAL_MAC_ADDRESSES_TWO is not set
CONFIG_ESP32_UNIVERSAL_MAC_ADDRESSES_FOUR=y
CONFIG_ESP32_UNIVERSAL_MAC_ADDRESSES=4
# CONFIG_ESP32_ULP_COPROC_ENABLED is not set
CONFIG_ESP32_ULP_COPROC_RESERVE_MEM=0
# CONFIG_ESP32_PANIC_PRINT_HALT is not set
CONFIG_ESP32_PANIC_PRINT_REBOOT=y
# CONFIG_ESP32_PANIC_SILENT_REBOOT is not set
# CONFIG_ESP32_PANIC_GDBSTUB is not set
CONFIG_ESP32_DEBUG_OCDAWARE=y
CONFIG_ESP32_BROWNOUT_DET=y
CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_0=y
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_1 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_2 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_3 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_4 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_5 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_6 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_7 is not set
CONFIG_ESP32_BROWNOUT_DET_LVL=0
CONFIG_ESP32_REDUCE_PHY_TX_POWER=y
CONFIG_ESP32_TIME_SYSCALL_USE_RTC_FRC1=y
# CONFIG_ESP32_TIME_SYSCALL_USE_RTC is not set
# CONFIG_ESP32_TIME_SYSCALL_USE_FRC1 is not set
# CONFIG_ESP32_TIME_SYSCALL_USE_NONE is not set
CONFIG_ESP32_RTC_CLK_SRC_INT_RC=y
# CONFIG_ESP32_RTC_CLK_SRC_EXT_CRYS is not set
# CONFIG_ESP32_RTC_CLK_SRC_EXT_OSC is not set
# CONFIG_ESP32_RTC_CLK_SRC_INT_8MD256 is not set
CONFIG_ESP32_RTC_CLK_CAL_CYCLES=1024
CONFIG_ESP32_DEEP_SLEEP_WAKEUP_DELAY=2000
CONFIG_ESP32_XTAL_FREQ_40=y
# CONFIG_ESP32_XTAL_FREQ_26 is not set
# CONFIG_ESP32_XTAL_FREQ_AUTO is not set
CONFIG_ESP32_XTAL_FREQ=40
# CONFIG_ESP32_DISABLE_BASIC_ROM_CONSOLE is not set
# CONFIG_ESP32_NO_BLOBS is not set
# CONFIG_ESP32_COMPATIBLE_PRE_V2_1_BOOTLOADERS is not set
# CONFIG_ESP32_USE_FIXED_STATIC_RAM_SIZE is not set
CONFIG_ESP32_DPORT_DIS_INTERRUPT_LVL=5
# end of ESP32-specific
# Power Management
# CONFIG_PM_ENABLE is not set
# end of Power Management
# ADC-Calibration
CONFIG_ADC_CAL_EFUSE_TP_ENABLE=y
CONFIG_ADC_CAL_EFUSE_VREF_ENABLE=y
CONFIG_ADC_CAL_LUT_ENABLE=y
# end of ADC-Calibration
# Common ESP-related
# CONFIG_ESP_TIMER_PROFILING is not set
CONFIG_ESP_ERR_TO_NAME_LOOKUP=y
CONFIG_ESP_SYSTEM_EVENT_QUEUE_SIZE=32
CONFIG_ESP_SYSTEM_EVENT_TASK_STACK_SIZE=2304
CONFIG_ESP_MAIN_TASK_STACK_SIZE=3584
CONFIG_ESP_IPC_TASK_STACK_SIZE=1024
CONFIG_ESP_IPC_USES_CALLERS_PRIORITY=y
CONFIG_ESP_TIMER_TASK_STACK_SIZE=3584
CONFIG_ESP_MINIMAL_SHARED_STACK_SIZE=2048
CONFIG_ESP_CONSOLE_UART_DEFAULT=y
# CONFIG_ESP_CONSOLE_UART_CUSTOM is not set
# CONFIG_ESP_CONSOLE_UART_NONE is not set
CONFIG_ESP_CONSOLE_UART_NUM=0
CONFIG_ESP_CONSOLE_UART_BAUDRATE=115200
CONFIG_ESP_INT_WDT=y
CONFIG_ESP_INT_WDT_TIMEOUT_MS=800
CONFIG_ESP_INT_WDT_CHECK_CPU1=y
# CONFIG_ESP_TASK_WDT is not set
# CONFIG_ESP_PANIC_HANDLER_IRAM is not set
# end of Common ESP-related
# Ethernet
CONFIG_ETH_ENABLED=y
CONFIG_ETH_USE_ESP32_EMAC=y
CONFIG_ETH_PHY_INTERFACE_RMII=y
# CONFIG_ETH_PHY_INTERFACE_MII is not set
CONFIG_ETH_RMII_CLK_INPUT=y
# CONFIG_ETH_RMII_CLK_OUTPUT is not set
CONFIG_ETH_RMII_CLK_IN_GPIO=0
CONFIG_ETH_DMA_BUFFER_SIZE=512
CONFIG_ETH_DMA_RX_BUFFER_NUM=10
CONFIG_ETH_DMA_TX_BUFFER_NUM=10
CONFIG_ETH_USE_SPI_ETHERNET=y
CONFIG_ETH_SPI_ETHERNET_DM9051=y
# CONFIG_ETH_USE_OPENETH is not set
# end of Ethernet
# Event Loop Library
# CONFIG_ESP_EVENT_LOOP_PROFILING is not set
CONFIG_ESP_EVENT_POST_FROM_ISR=y
CONFIG_ESP_EVENT_POST_FROM_IRAM_ISR=y
# end of Event Loop Library
# GDB Stub
# end of GDB Stub
# ESP HTTP client
CONFIG_ESP_HTTP_CLIENT_ENABLE_HTTPS=y
# CONFIG_ESP_HTTP_CLIENT_ENABLE_BASIC_AUTH is not set
# end of ESP HTTP client
# HTTP Server
CONFIG_HTTPD_MAX_REQ_HDR_LEN=512
CONFIG_HTTPD_MAX_URI_LEN=512
CONFIG_HTTPD_ERR_RESP_NO_DELAY=y
CONFIG_HTTPD_PURGE_BUF_LEN=32
# CONFIG_HTTPD_LOG_PURGE_DATA is not set
# end of HTTP Server
# ESP HTTPS OTA
# CONFIG_OTA_ALLOW_HTTP is not set
# end of ESP HTTPS OTA
# ESP HTTPS server
# CONFIG_ESP_HTTPS_SERVER_ENABLE is not set
# end of ESP HTTPS server
# ESP NETIF Adapter
CONFIG_ESP_NETIF_IP_LOST_TIMER_INTERVAL=120
CONFIG_ESP_NETIF_TCPIP_LWIP=y
# CONFIG_ESP_NETIF_LOOPBACK is not set
CONFIG_ESP_NETIF_TCPIP_ADAPTER_COMPATIBLE_LAYER=y
# end of ESP NETIF Adapter
# Wi-Fi
CONFIG_ESP32_WIFI_STATIC_RX_BUFFER_NUM=10
CONFIG_ESP32_WIFI_DYNAMIC_RX_BUFFER_NUM=32
CONFIG_ESP32_WIFI_STATIC_TX_BUFFER=y
# CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER is not set
CONFIG_ESP32_WIFI_TX_BUFFER_TYPE=0
CONFIG_ESP32_WIFI_STATIC_TX_BUFFER_NUM=16
# CONFIG_ESP32_WIFI_CSI_ENABLED is not set
CONFIG_ESP32_WIFI_AMPDU_TX_ENABLED=y
CONFIG_ESP32_WIFI_TX_BA_WIN=6
CONFIG_ESP32_WIFI_AMPDU_RX_ENABLED=y
CONFIG_ESP32_WIFI_RX_BA_WIN=16
CONFIG_ESP32_WIFI_NVS_ENABLED=y
CONFIG_ESP32_WIFI_TASK_PINNED_TO_CORE_0=y
# CONFIG_ESP32_WIFI_TASK_PINNED_TO_CORE_1 is not set
CONFIG_ESP32_WIFI_SOFTAP_BEACON_MAX_LEN=752
CONFIG_ESP32_WIFI_MGMT_SBUF_NUM=32
# CONFIG_ESP32_WIFI_DEBUG_LOG_ENABLE is not set
CONFIG_ESP32_WIFI_IRAM_OPT=y
CONFIG_ESP32_WIFI_RX_IRAM_OPT=y
CONFIG_ESP32_WIFI_ENABLE_WPA3_SAE=y
# end of Wi-Fi
# PHY
CONFIG_ESP32_PHY_CALIBRATION_AND_DATA_STORAGE=y
# CONFIG_ESP32_PHY_INIT_DATA_IN_PARTITION is not set
CONFIG_ESP32_PHY_MAX_WIFI_TX_POWER=20
CONFIG_ESP32_PHY_MAX_TX_POWER=20
# end of PHY
# Core dump
# CONFIG_ESP32_ENABLE_COREDUMP_TO_FLASH is not set
# CONFIG_ESP32_ENABLE_COREDUMP_TO_UART is not set
CONFIG_ESP32_ENABLE_COREDUMP_TO_NONE=y
# end of Core dump
# FAT Filesystem support
# CONFIG_FATFS_CODEPAGE_DYNAMIC is not set
CONFIG_FATFS_CODEPAGE_437=y
# CONFIG_FATFS_CODEPAGE_720 is not set
# CONFIG_FATFS_CODEPAGE_737 is not set
# CONFIG_FATFS_CODEPAGE_771 is not set
# CONFIG_FATFS_CODEPAGE_775 is not set
# CONFIG_FATFS_CODEPAGE_850 is not set
# CONFIG_FATFS_CODEPAGE_852 is not set
# CONFIG_FATFS_CODEPAGE_855 is not set
# CONFIG_FATFS_CODEPAGE_857 is not set
# CONFIG_FATFS_CODEPAGE_860 is not set
# CONFIG_FATFS_CODEPAGE_861 is not set
# CONFIG_FATFS_CODEPAGE_862 is not set
# CONFIG_FATFS_CODEPAGE_863 is not set
# CONFIG_FATFS_CODEPAGE_864 is not set
# CONFIG_FATFS_CODEPAGE_865 is not set
# CONFIG_FATFS_CODEPAGE_866 is not set
# CONFIG_FATFS_CODEPAGE_869 is not set
# CONFIG_FATFS_CODEPAGE_932 is not set
# CONFIG_FATFS_CODEPAGE_936 is not set
# CONFIG_FATFS_CODEPAGE_949 is not set
# CONFIG_FATFS_CODEPAGE_950 is not set
CONFIG_FATFS_CODEPAGE=437
CONFIG_FATFS_LFN_NONE=y
# CONFIG_FATFS_LFN_HEAP is not set
# CONFIG_FATFS_LFN_STACK is not set
CONFIG_FATFS_FS_LOCK=0
CONFIG_FATFS_TIMEOUT_MS=10000
CONFIG_FATFS_PER_FILE_CACHE=y
# end of FAT Filesystem support
# Modbus configuration
CONFIG_FMB_COMM_MODE_RTU_EN=y
CONFIG_FMB_COMM_MODE_ASCII_EN=y
CONFIG_FMB_MASTER_TIMEOUT_MS_RESPOND=150
CONFIG_FMB_MASTER_DELAY_MS_CONVERT=200
CONFIG_FMB_QUEUE_LENGTH=20
CONFIG_FMB_SERIAL_TASK_STACK_SIZE=2048
CONFIG_FMB_SERIAL_BUF_SIZE=256
CONFIG_FMB_SERIAL_ASCII_BITS_PER_SYMB=8
CONFIG_FMB_SERIAL_ASCII_TIMEOUT_RESPOND_MS=1000
CONFIG_FMB_SERIAL_TASK_PRIO=10
# CONFIG_FMB_CONTROLLER_SLAVE_ID_SUPPORT is not set
CONFIG_FMB_CONTROLLER_NOTIFY_TIMEOUT=20
CONFIG_FMB_CONTROLLER_NOTIFY_QUEUE_SIZE=20
CONFIG_FMB_CONTROLLER_STACK_SIZE=4096
CONFIG_FMB_EVENT_QUEUE_TIMEOUT=20
CONFIG_FMB_TIMER_PORT_ENABLED=y
CONFIG_FMB_TIMER_GROUP=0
CONFIG_FMB_TIMER_INDEX=0
# CONFIG_FMB_TIMER_ISR_IN_IRAM is not set
# end of Modbus configuration
# FreeRTOS
# CONFIG_FREERTOS_UNICORE is not set
CONFIG_FREERTOS_NO_AFFINITY=0x7FFFFFFF
CONFIG_FREERTOS_CORETIMER_0=y
# CONFIG_FREERTOS_CORETIMER_1 is not set
CONFIG_FREERTOS_HZ=100
CONFIG_FREERTOS_ASSERT_ON_UNTESTED_FUNCTION=y
# CONFIG_FREERTOS_CHECK_STACKOVERFLOW_NONE is not set
# CONFIG_FREERTOS_CHECK_STACKOVERFLOW_PTRVAL is not set
CONFIG_FREERTOS_CHECK_STACKOVERFLOW_CANARY=y
# CONFIG_FREERTOS_WATCHPOINT_END_OF_STACK is not set
CONFIG_FREERTOS_INTERRUPT_BACKTRACE=y
CONFIG_FREERTOS_THREAD_LOCAL_STORAGE_POINTERS=1
CONFIG_FREERTOS_ASSERT_FAIL_ABORT=y
# CONFIG_FREERTOS_ASSERT_FAIL_PRINT_CONTINUE is not set
# CONFIG_FREERTOS_ASSERT_DISABLE is not set
CONFIG_FREERTOS_IDLE_TASK_STACKSIZE=1536
CONFIG_FREERTOS_ISR_STACKSIZE=1536
# CONFIG_FREERTOS_LEGACY_HOOKS is not set
CONFIG_FREERTOS_MAX_TASK_NAME_LEN=16
CONFIG_FREERTOS_SUPPORT_STATIC_ALLOCATION=y
# CONFIG_FREERTOS_ENABLE_STATIC_TASK_CLEAN_UP is not set
CONFIG_FREERTOS_TIMER_TASK_PRIORITY=1
CONFIG_FREERTOS_TIMER_TASK_STACK_DEPTH=2048
CONFIG_FREERTOS_TIMER_QUEUE_LENGTH=10
CONFIG_FREERTOS_QUEUE_REGISTRY_SIZE=0
# CONFIG_FREERTOS_USE_TRACE_FACILITY is not set
# CONFIG_FREERTOS_GENERATE_RUN_TIME_STATS is not set
# CONFIG_FREERTOS_DEBUG_INTERNALS is not set
CONFIG_FREERTOS_TASK_FUNCTION_WRAPPER=y
CONFIG_FREERTOS_CHECK_MUTEX_GIVEN_BY_OWNER=y
# CONFIG_FREERTOS_CHECK_PORT_CRITICAL_COMPLIANCE is not set
CONFIG_FREERTOS_DEBUG_OCDAWARE=y
# end of FreeRTOS
# Heap memory debugging
CONFIG_HEAP_POISONING_DISABLED=y
# CONFIG_HEAP_POISONING_LIGHT is not set
# CONFIG_HEAP_POISONING_COMPREHENSIVE is not set
CONFIG_HEAP_TRACING_OFF=y
# CONFIG_HEAP_TRACING_STANDALONE is not set
# CONFIG_HEAP_TRACING_TOHOST is not set
# end of Heap memory debugging
# jsmn
# CONFIG_JSMN_PARENT_LINKS is not set
# CONFIG_JSMN_STRICT is not set
# end of jsmn
# libsodium
CONFIG_LIBSODIUM_USE_MBEDTLS_SHA=y
# end of libsodium
# Log output
# CONFIG_LOG_DEFAULT_LEVEL_NONE is not set
# CONFIG_LOG_DEFAULT_LEVEL_ERROR is not set
# CONFIG_LOG_DEFAULT_LEVEL_WARN is not set
CONFIG_LOG_DEFAULT_LEVEL_INFO=y
# CONFIG_LOG_DEFAULT_LEVEL_DEBUG is not set
# CONFIG_LOG_DEFAULT_LEVEL_VERBOSE is not set
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_LOG_COLORS=y
CONFIG_LOG_TIMESTAMP_SOURCE_RTOS=y
# CONFIG_LOG_TIMESTAMP_SOURCE_SYSTEM is not set
# end of Log output
# LWIP
CONFIG_LWIP_LOCAL_HOSTNAME="espressif"
CONFIG_LWIP_DNS_SUPPORT_MDNS_QUERIES=y
# CONFIG_LWIP_L2_TO_L3_COPY is not set
# CONFIG_LWIP_IRAM_OPTIMIZATION is not set
CONFIG_LWIP_TIMERS_ONDEMAND=y
CONFIG_LWIP_MAX_SOCKETS=10
# CONFIG_LWIP_USE_ONLY_LWIP_SELECT is not set
# CONFIG_LWIP_SO_LINGER is not set
CONFIG_LWIP_SO_REUSE=y
CONFIG_LWIP_SO_REUSE_RXTOALL=y
# CONFIG_LWIP_SO_RCVBUF is not set
# CONFIG_LWIP_NETBUF_RECVINFO is not set
# CONFIG_LWIP_IP_FRAG is not set
# CONFIG_LWIP_IP_REASSEMBLY is not set
# CONFIG_LWIP_STATS is not set
# CONFIG_LWIP_ETHARP_TRUST_IP_MAC is not set
CONFIG_LWIP_ESP_GRATUITOUS_ARP=y
CONFIG_LWIP_GARP_TMR_INTERVAL=60
CONFIG_LWIP_TCPIP_RECVMBOX_SIZE=32
CONFIG_LWIP_DHCP_DOES_ARP_CHECK=y
# CONFIG_LWIP_DHCP_RESTORE_LAST_IP is not set
# DHCP server
CONFIG_LWIP_DHCPS_LEASE_UNIT=60
CONFIG_LWIP_DHCPS_MAX_STATION_NUM=8
# end of DHCP server
# CONFIG_LWIP_AUTOIP is not set
# CONFIG_LWIP_IPV6_AUTOCONFIG is not set
CONFIG_LWIP_NETIF_LOOPBACK=y
CONFIG_LWIP_LOOPBACK_MAX_PBUFS=8
# TCP
CONFIG_LWIP_MAX_ACTIVE_TCP=16
CONFIG_LWIP_MAX_LISTENING_TCP=16
CONFIG_LWIP_TCP_MAXRTX=12
CONFIG_LWIP_TCP_SYNMAXRTX=6
CONFIG_LWIP_TCP_MSS=1440
CONFIG_LWIP_TCP_TMR_INTERVAL=250
CONFIG_LWIP_TCP_MSL=60000
CONFIG_LWIP_TCP_SND_BUF_DEFAULT=5744
CONFIG_LWIP_TCP_WND_DEFAULT=5744
CONFIG_LWIP_TCP_RECVMBOX_SIZE=6
CONFIG_LWIP_TCP_QUEUE_OOSEQ=y
# CONFIG_LWIP_TCP_SACK_OUT is not set
# CONFIG_LWIP_TCP_KEEP_CONNECTION_WHEN_IP_CHANGES is not set
CONFIG_LWIP_TCP_OVERSIZE_MSS=y
# CONFIG_LWIP_TCP_OVERSIZE_QUARTER_MSS is not set
# CONFIG_LWIP_TCP_OVERSIZE_DISABLE is not set
# end of TCP
# UDP
CONFIG_LWIP_MAX_UDP_PCBS=16
CONFIG_LWIP_UDP_RECVMBOX_SIZE=6
# end of UDP
CONFIG_LWIP_TCPIP_TASK_STACK_SIZE=3072
CONFIG_LWIP_TCPIP_TASK_AFFINITY_NO_AFFINITY=y
# CONFIG_LWIP_TCPIP_TASK_AFFINITY_CPU0 is not set
# CONFIG_LWIP_TCPIP_TASK_AFFINITY_CPU1 is not set
CONFIG_LWIP_TCPIP_TASK_AFFINITY=0x7FFFFFFF
# CONFIG_LWIP_PPP_SUPPORT is not set
# ICMP
# CONFIG_LWIP_MULTICAST_PING is not set
# CONFIG_LWIP_BROADCAST_PING is not set
# end of ICMP
# LWIP RAW API
CONFIG_LWIP_MAX_RAW_PCBS=16
# end of LWIP RAW API
# SNTP
CONFIG_LWIP_DHCP_MAX_NTP_SERVERS=1
CONFIG_LWIP_SNTP_UPDATE_DELAY=3600000
# end of SNTP
# end of LWIP
# mbedTLS
CONFIG_MBEDTLS_INTERNAL_MEM_ALLOC=y
# CONFIG_MBEDTLS_EXTERNAL_MEM_ALLOC is not set
# CONFIG_MBEDTLS_DEFAULT_MEM_ALLOC is not set
# CONFIG_MBEDTLS_CUSTOM_MEM_ALLOC is not set
CONFIG_MBEDTLS_ASYMMETRIC_CONTENT_LEN=y
CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN=16384
CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN=4096
# CONFIG_MBEDTLS_DEBUG is not set
# CONFIG_MBEDTLS_ECP_RESTARTABLE is not set
# CONFIG_MBEDTLS_CMAC_C is not set
CONFIG_MBEDTLS_HARDWARE_AES=y
# CONFIG_MBEDTLS_HARDWARE_MPI is not set
# CONFIG_MBEDTLS_HARDWARE_SHA is not set
CONFIG_MBEDTLS_HAVE_TIME=y
# CONFIG_MBEDTLS_HAVE_TIME_DATE is not set
CONFIG_MBEDTLS_TLS_SERVER_AND_CLIENT=y
# CONFIG_MBEDTLS_TLS_SERVER_ONLY is not set
# CONFIG_MBEDTLS_TLS_CLIENT_ONLY is not set
# CONFIG_MBEDTLS_TLS_DISABLED is not set
CONFIG_MBEDTLS_TLS_SERVER=y
CONFIG_MBEDTLS_TLS_CLIENT=y
CONFIG_MBEDTLS_TLS_ENABLED=y
# TLS Key Exchange Methods
# CONFIG_MBEDTLS_PSK_MODES is not set
CONFIG_MBEDTLS_KEY_EXCHANGE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ELLIPTIC_CURVE=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_RSA=y
# end of TLS Key Exchange Methods
CONFIG_MBEDTLS_SSL_RENEGOTIATION=y
# CONFIG_MBEDTLS_SSL_PROTO_SSL3 is not set
CONFIG_MBEDTLS_SSL_PROTO_TLS1=y
CONFIG_MBEDTLS_SSL_PROTO_TLS1_1=y
CONFIG_MBEDTLS_SSL_PROTO_TLS1_2=y
# CONFIG_MBEDTLS_SSL_PROTO_DTLS is not set
CONFIG_MBEDTLS_SSL_ALPN=y
CONFIG_MBEDTLS_CLIENT_SSL_SESSION_TICKETS=y
CONFIG_MBEDTLS_SERVER_SSL_SESSION_TICKETS=y
# Symmetric Ciphers
CONFIG_MBEDTLS_AES_C=y
# CONFIG_MBEDTLS_CAMELLIA_C is not set
# CONFIG_MBEDTLS_DES_C is not set
CONFIG_MBEDTLS_RC4_DISABLED=y
# CONFIG_MBEDTLS_RC4_ENABLED_NO_DEFAULT is not set
# CONFIG_MBEDTLS_RC4_ENABLED is not set
# CONFIG_MBEDTLS_BLOWFISH_C is not set
# CONFIG_MBEDTLS_XTEA_C is not set
CONFIG_MBEDTLS_CCM_C=y
CONFIG_MBEDTLS_GCM_C=y
# end of Symmetric Ciphers
# CONFIG_MBEDTLS_RIPEMD160_C is not set
# Certificates
CONFIG_MBEDTLS_PEM_PARSE_C=y
CONFIG_MBEDTLS_PEM_WRITE_C=y
CONFIG_MBEDTLS_X509_CRL_PARSE_C=y
CONFIG_MBEDTLS_X509_CSR_PARSE_C=y
# end of Certificates
CONFIG_MBEDTLS_ECP_C=y
CONFIG_MBEDTLS_ECDH_C=y
CONFIG_MBEDTLS_ECDSA_C=y
CONFIG_MBEDTLS_ECP_DP_SECP192R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP224R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP256R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP521R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP192K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP224K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP256K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP256R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP512R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_CURVE25519_ENABLED=y
CONFIG_MBEDTLS_ECP_NIST_OPTIM=y
# CONFIG_MBEDTLS_SECURITY_RISKS is not set
# end of mbedTLS
# mDNS
CONFIG_MDNS_MAX_SERVICES=10
CONFIG_MDNS_TASK_PRIORITY=1
# CONFIG_MDNS_TASK_AFFINITY_NO_AFFINITY is not set
CONFIG_MDNS_TASK_AFFINITY_CPU0=y
# CONFIG_MDNS_TASK_AFFINITY_CPU1 is not set
CONFIG_MDNS_TASK_AFFINITY=0x0
CONFIG_MDNS_SERVICE_ADD_TIMEOUT_MS=2000
CONFIG_MDNS_TIMER_PERIOD_MS=100
# end of mDNS
# ESP-MQTT Configurations
CONFIG_MQTT_PROTOCOL_311=y
CONFIG_MQTT_TRANSPORT_SSL=y
CONFIG_MQTT_TRANSPORT_WEBSOCKET=y
CONFIG_MQTT_TRANSPORT_WEBSOCKET_SECURE=y
# CONFIG_MQTT_USE_CUSTOM_CONFIG is not set
# CONFIG_MQTT_TASK_CORE_SELECTION_ENABLED is not set
# CONFIG_MQTT_CUSTOM_OUTBOX is not set
# end of ESP-MQTT Configurations
# Newlib
CONFIG_NEWLIB_STDOUT_LINE_ENDING_CRLF=y
# CONFIG_NEWLIB_STDOUT_LINE_ENDING_LF is not set
# CONFIG_NEWLIB_STDOUT_LINE_ENDING_CR is not set
# CONFIG_NEWLIB_STDIN_LINE_ENDING_CRLF is not set
# CONFIG_NEWLIB_STDIN_LINE_ENDING_LF is not set
CONFIG_NEWLIB_STDIN_LINE_ENDING_CR=y
# CONFIG_NEWLIB_NANO_FORMAT is not set
# end of Newlib
# NVS
# end of NVS
# OpenSSL
# CONFIG_OPENSSL_DEBUG is not set
# CONFIG_OPENSSL_ASSERT_DO_NOTHING is not set
CONFIG_OPENSSL_ASSERT_EXIT=y
# end of OpenSSL
# PThreads
CONFIG_PTHREAD_TASK_PRIO_DEFAULT=5
CONFIG_PTHREAD_TASK_STACK_SIZE_DEFAULT=3072
CONFIG_PTHREAD_STACK_MIN=768
CONFIG_PTHREAD_DEFAULT_CORE_NO_AFFINITY=y
# CONFIG_PTHREAD_DEFAULT_CORE_0 is not set
# CONFIG_PTHREAD_DEFAULT_CORE_1 is not set
CONFIG_PTHREAD_TASK_CORE_DEFAULT=-1
CONFIG_PTHREAD_TASK_NAME_DEFAULT="pthread"
# end of PThreads
# SPI Flash driver
# CONFIG_SPI_FLASH_VERIFY_WRITE is not set
# CONFIG_SPI_FLASH_ENABLE_COUNTERS is not set
CONFIG_SPI_FLASH_ROM_DRIVER_PATCH=y
CONFIG_SPI_FLASH_DANGEROUS_WRITE_ABORTS=y
# CONFIG_SPI_FLASH_DANGEROUS_WRITE_FAILS is not set
# CONFIG_SPI_FLASH_DANGEROUS_WRITE_ALLOWED is not set
# CONFIG_SPI_FLASH_USE_LEGACY_IMPL is not set
# CONFIG_SPI_FLASH_BYPASS_BLOCK_ERASE is not set
CONFIG_SPI_FLASH_YIELD_DURING_ERASE=y
CONFIG_SPI_FLASH_ERASE_YIELD_DURATION_MS=20
CONFIG_SPI_FLASH_ERASE_YIELD_TICKS=1
# Auto-detect flash chips
CONFIG_SPI_FLASH_SUPPORT_ISSI_CHIP=y
CONFIG_SPI_FLASH_SUPPORT_GD_CHIP=y
# end of Auto-detect flash chips
# end of SPI Flash driver
# SPIFFS Configuration
CONFIG_SPIFFS_MAX_PARTITIONS=3
# SPIFFS Cache Configuration
CONFIG_SPIFFS_CACHE=y
CONFIG_SPIFFS_CACHE_WR=y
# CONFIG_SPIFFS_CACHE_STATS is not set
# end of SPIFFS Cache Configuration
CONFIG_SPIFFS_PAGE_CHECK=y
CONFIG_SPIFFS_GC_MAX_RUNS=10
# CONFIG_SPIFFS_GC_STATS is not set
CONFIG_SPIFFS_PAGE_SIZE=256
CONFIG_SPIFFS_OBJ_NAME_LEN=32
# CONFIG_SPIFFS_FOLLOW_SYMLINKS is not set
CONFIG_SPIFFS_USE_MAGIC=y
CONFIG_SPIFFS_USE_MAGIC_LENGTH=y
CONFIG_SPIFFS_META_LENGTH=4
CONFIG_SPIFFS_USE_MTIME=y
# Debug Configuration
# CONFIG_SPIFFS_DBG is not set
# CONFIG_SPIFFS_API_DBG is not set
# CONFIG_SPIFFS_GC_DBG is not set
# CONFIG_SPIFFS_CACHE_DBG is not set
# CONFIG_SPIFFS_CHECK_DBG is not set
# CONFIG_SPIFFS_TEST_VISUALISATION is not set
# end of Debug Configuration
# end of SPIFFS Configuration
# Unity unit testing library
CONFIG_UNITY_ENABLE_FLOAT=y
CONFIG_UNITY_ENABLE_DOUBLE=y
# CONFIG_UNITY_ENABLE_COLOR is not set
CONFIG_UNITY_ENABLE_IDF_TEST_RUNNER=y
# CONFIG_UNITY_ENABLE_FIXTURE is not set
# CONFIG_UNITY_ENABLE_BACKTRACE_ON_FAIL is not set
# end of Unity unit testing library
# Virtual file system
CONFIG_VFS_SUPPRESS_SELECT_DEBUG_OUTPUT=y
CONFIG_VFS_SUPPORT_TERMIOS=y
# Host File System I/O (Semihosting)
CONFIG_SEMIHOSTFS_MAX_MOUNT_POINTS=1
CONFIG_SEMIHOSTFS_HOST_PATH_MAX_LEN=128
# end of Host File System I/O (Semihosting)
# end of Virtual file system
# Wear Levelling
# CONFIG_WL_SECTOR_SIZE_512 is not set
CONFIG_WL_SECTOR_SIZE_4096=y
CONFIG_WL_SECTOR_SIZE=4096
# end of Wear Levelling
# Wi-Fi Provisioning Manager
CONFIG_WIFI_PROV_SCAN_MAX_ENTRIES=16
CONFIG_WIFI_PROV_AUTOSTOP_TIMEOUT=30
# end of Wi-Fi Provisioning Manager
# Supplicant
CONFIG_WPA_MBEDTLS_CRYPTO=y
# CONFIG_WPA_TLS_V12 is not set
# end of Supplicant
# CONFIG_C_IMPL is not set
CONFIG_XTENSA_IMPL=y
# ESP-FACE Configuration
CONFIG_MTMN_LITE_QUANT=y
# CONFIG_MTMN_LITE_FLOAT is not set
# CONFIG_MTMN_HEAVY_QUANT is not set
# CONFIG_FRMN is not set
CONFIG_MFN56_1X=y
# CONFIG_MFN56_2X is not set
# CONFIG_MFN56_3X is not set
# CONFIG_MFN56_4X is not set
# Object Detection
# CONFIG_DETECT_WITH_LANDMARK is not set
# end of Object Detection
# Pose Estimation
CONFIG_HD_NANO1=y
# CONFIG_HD_LITE1 is not set
CONFIG_HP_NANO1=y
# CONFIG_HP_LITE1 is not set
# end of Pose Estimation
# end of ESP-FACE Configuration
# Camera configuration
CONFIG_OV7670_SUPPORT=y
# CONFIG_OV7725_SUPPORT is not set
CONFIG_NT99141_SUPPORT=y
CONFIG_OV2640_SUPPORT=y
CONFIG_OV3660_SUPPORT=y
CONFIG_OV5640_SUPPORT=y
# CONFIG_SCCB_HARDWARE_I2C_PORT0 is not set
CONFIG_SCCB_HARDWARE_I2C_PORT1=y
CONFIG_CAMERA_CORE0=y
# CONFIG_CAMERA_CORE1 is not set
# CONFIG_CAMERA_NO_AFFINITY is not set
# end of Camera configuration
# end of Component config
# Compatibility options
# CONFIG_LEGACY_INCLUDE_COMMON_HEADERS is not set
# end of Compatibility options
# Deprecated options for backward compatibility
CONFIG_TOOLPREFIX="xtensa-esp32-elf-"
# CONFIG_LOG_BOOTLOADER_LEVEL_NONE is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_ERROR is not set
CONFIG_LOG_BOOTLOADER_LEVEL_WARN=y
# CONFIG_LOG_BOOTLOADER_LEVEL_INFO is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_DEBUG is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_VERBOSE is not set
CONFIG_LOG_BOOTLOADER_LEVEL=2
# CONFIG_APP_ROLLBACK_ENABLE is not set
# CONFIG_FLASH_ENCRYPTION_ENABLED is not set
CONFIG_FLASHMODE_QIO=y
# CONFIG_FLASHMODE_QOUT is not set
# CONFIG_FLASHMODE_DIO is not set
# CONFIG_FLASHMODE_DOUT is not set
# CONFIG_MONITOR_BAUD_9600B is not set
# CONFIG_MONITOR_BAUD_57600B is not set
CONFIG_MONITOR_BAUD_115200B=y
# CONFIG_MONITOR_BAUD_230400B is not set
# CONFIG_MONITOR_BAUD_921600B is not set
# CONFIG_MONITOR_BAUD_2MB is not set
# CONFIG_MONITOR_BAUD_OTHER is not set
CONFIG_MONITOR_BAUD_OTHER_VAL=115200
CONFIG_MONITOR_BAUD=115200
CONFIG_COMPILER_OPTIMIZATION_LEVEL_DEBUG=y
# CONFIG_COMPILER_OPTIMIZATION_LEVEL_RELEASE is not set
CONFIG_OPTIMIZATION_ASSERTIONS_ENABLED=y
# CONFIG_OPTIMIZATION_ASSERTIONS_SILENT is not set
# CONFIG_OPTIMIZATION_ASSERTIONS_DISABLED is not set
# CONFIG_CXX_EXCEPTIONS is not set
CONFIG_STACK_CHECK_NONE=y
# CONFIG_STACK_CHECK_NORM is not set
# CONFIG_STACK_CHECK_STRONG is not set
# CONFIG_STACK_CHECK_ALL is not set
# CONFIG_WARN_WRITE_STRINGS is not set
# CONFIG_DISABLE_GCC8_WARNINGS is not set
# CONFIG_ESP32_APPTRACE_DEST_TRAX is not set
CONFIG_ESP32_APPTRACE_DEST_NONE=y
CONFIG_ESP32_APPTRACE_LOCK_ENABLE=y
CONFIG_BTDM_CONTROLLER_BLE_MAX_CONN_EFF=0
CONFIG_BTDM_CONTROLLER_BR_EDR_MAX_ACL_CONN_EFF=0
CONFIG_BTDM_CONTROLLER_BR_EDR_MAX_SYNC_CONN_EFF=0
CONFIG_BTDM_CONTROLLER_PINNED_TO_CORE=0
CONFIG_ADC2_DISABLE_DAC=y
CONFIG_SPIRAM_SUPPORT=y
CONFIG_TRACEMEM_RESERVE_DRAM=0x0
# CONFIG_TWO_UNIVERSAL_MAC_ADDRESS is not set
CONFIG_FOUR_UNIVERSAL_MAC_ADDRESS=y
CONFIG_NUMBER_OF_UNIVERSAL_MAC_ADDRESS=4
# CONFIG_ULP_COPROC_ENABLED is not set
CONFIG_ULP_COPROC_RESERVE_MEM=0
CONFIG_BROWNOUT_DET=y
CONFIG_BROWNOUT_DET_LVL_SEL_0=y
# CONFIG_BROWNOUT_DET_LVL_SEL_1 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_2 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_3 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_4 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_5 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_6 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_7 is not set
CONFIG_BROWNOUT_DET_LVL=0
CONFIG_REDUCE_PHY_TX_POWER=y
CONFIG_ESP32_RTC_CLOCK_SOURCE_INTERNAL_RC=y
# CONFIG_ESP32_RTC_CLOCK_SOURCE_EXTERNAL_CRYSTAL is not set
# CONFIG_ESP32_RTC_CLOCK_SOURCE_EXTERNAL_OSC is not set
# CONFIG_ESP32_RTC_CLOCK_SOURCE_INTERNAL_8MD256 is not set
# CONFIG_DISABLE_BASIC_ROM_CONSOLE is not set
# CONFIG_NO_BLOBS is not set
# CONFIG_COMPATIBLE_PRE_V2_1_BOOTLOADERS is not set
CONFIG_SYSTEM_EVENT_QUEUE_SIZE=32
CONFIG_SYSTEM_EVENT_TASK_STACK_SIZE=2304
CONFIG_MAIN_TASK_STACK_SIZE=3584
CONFIG_IPC_TASK_STACK_SIZE=1024
CONFIG_TIMER_TASK_STACK_SIZE=3584
CONFIG_CONSOLE_UART_DEFAULT=y
# CONFIG_CONSOLE_UART_CUSTOM is not set
# CONFIG_CONSOLE_UART_NONE is not set
CONFIG_CONSOLE_UART_NUM=0
CONFIG_CONSOLE_UART_BAUDRATE=115200
CONFIG_INT_WDT=y
CONFIG_INT_WDT_TIMEOUT_MS=800
CONFIG_INT_WDT_CHECK_CPU1=y
# CONFIG_TASK_WDT is not set
# CONFIG_EVENT_LOOP_PROFILING is not set
CONFIG_POST_EVENTS_FROM_ISR=y
CONFIG_POST_EVENTS_FROM_IRAM_ISR=y
CONFIG_MB_MASTER_TIMEOUT_MS_RESPOND=150
CONFIG_MB_MASTER_DELAY_MS_CONVERT=200
CONFIG_MB_QUEUE_LENGTH=20
CONFIG_MB_SERIAL_TASK_STACK_SIZE=2048
CONFIG_MB_SERIAL_BUF_SIZE=256
CONFIG_MB_SERIAL_TASK_PRIO=10
# CONFIG_MB_CONTROLLER_SLAVE_ID_SUPPORT is not set
CONFIG_MB_CONTROLLER_NOTIFY_TIMEOUT=20
CONFIG_MB_CONTROLLER_NOTIFY_QUEUE_SIZE=20
CONFIG_MB_CONTROLLER_STACK_SIZE=4096
CONFIG_MB_EVENT_QUEUE_TIMEOUT=20
CONFIG_MB_TIMER_PORT_ENABLED=y
CONFIG_MB_TIMER_GROUP=0
CONFIG_MB_TIMER_INDEX=0
CONFIG_SUPPORT_STATIC_ALLOCATION=y
# CONFIG_ENABLE_STATIC_TASK_CLEAN_UP_HOOK is not set
CONFIG_TIMER_TASK_PRIORITY=1
CONFIG_TIMER_TASK_STACK_DEPTH=2048
CONFIG_TIMER_QUEUE_LENGTH=10
# CONFIG_L2_TO_L3_COPY is not set
# CONFIG_USE_ONLY_LWIP_SELECT is not set
CONFIG_ESP_GRATUITOUS_ARP=y
CONFIG_GARP_TMR_INTERVAL=60
CONFIG_TCPIP_RECVMBOX_SIZE=32
CONFIG_TCP_MAXRTX=12
CONFIG_TCP_SYNMAXRTX=6
CONFIG_TCP_MSS=1440
CONFIG_TCP_MSL=60000
CONFIG_TCP_SND_BUF_DEFAULT=5744
CONFIG_TCP_WND_DEFAULT=5744
CONFIG_TCP_RECVMBOX_SIZE=6
CONFIG_TCP_QUEUE_OOSEQ=y
# CONFIG_ESP_TCP_KEEP_CONNECTION_WHEN_IP_CHANGES is not set
CONFIG_TCP_OVERSIZE_MSS=y
# CONFIG_TCP_OVERSIZE_QUARTER_MSS is not set
# CONFIG_TCP_OVERSIZE_DISABLE is not set
CONFIG_UDP_RECVMBOX_SIZE=6
CONFIG_TCPIP_TASK_STACK_SIZE=3072
CONFIG_TCPIP_TASK_AFFINITY_NO_AFFINITY=y
# CONFIG_TCPIP_TASK_AFFINITY_CPU0 is not set
# CONFIG_TCPIP_TASK_AFFINITY_CPU1 is not set
CONFIG_TCPIP_TASK_AFFINITY=0x7FFFFFFF
# CONFIG_PPP_SUPPORT is not set
CONFIG_ESP32_PTHREAD_TASK_PRIO_DEFAULT=5
CONFIG_ESP32_PTHREAD_TASK_STACK_SIZE_DEFAULT=3072
CONFIG_ESP32_PTHREAD_STACK_MIN=768
CONFIG_ESP32_DEFAULT_PTHREAD_CORE_NO_AFFINITY=y
# CONFIG_ESP32_DEFAULT_PTHREAD_CORE_0 is not set
# CONFIG_ESP32_DEFAULT_PTHREAD_CORE_1 is not set
CONFIG_ESP32_PTHREAD_TASK_CORE_DEFAULT=-1
CONFIG_ESP32_PTHREAD_TASK_NAME_DEFAULT="pthread"
CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ABORTS=y
# CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_FAILS is not set
# CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ALLOWED is not set
CONFIG_SUPPRESS_SELECT_DEBUG_OUTPUT=y
CONFIG_SUPPORT_TERMIOS=y
# End of deprecated options
salbdch
Postby salbdch » Wed Jan 13, 2021 3:07 pm
I made logs
static esp_err_t camera_fb_init(size_t count)
    if(!count) {
        return ESP_ERR_INVALID_ARG;
    camera_fb_deinit();
        ESP_LOGI(TAG, "Allocating %u frame buffers (%d KB total)", count, (s_state->fb_size * count) / 1024);
	ESP_LOGI(TAG, "Get Total size %d KB in PSRAM", heap_caps_get_total_size(MALLOC_CAP_SPIRAM) );
	ESP_LOGI(TAG, "Get free size %d KB in PSRAM", heap_caps_get_free_size(MALLOC_CAP_SPIRAM) );
	ESP_LOGI(TAG, "Get minimum free size %d KB in PSRAM", heap_caps_get_minimum_free_size(MALLOC_CAP_SPIRAM) );
	ESP_LOGI(TAG, "Get largest free block %d KB in PSRAM", heap_caps_get_largest_free_block(MALLOC_CAP_SPIRAM) );
and it shows
I (2498) camera: Detected OV5640 camera
E (2498) camera: in_bpp: 2, fb_bpp: 2, fb_size: 983040, mode: 3, wa`ph8㉡븼쓠那듙뭳?0m
E (2498) camera: [DEBUG] Frame Buffer Init...in Camera.c
I (2498) camera: Allocating 2 frame buffers (1920 KB total)
I (2508) camera: Get Total size 4194303 KB in PSRAM
I (2518) camera: Get free size -33 KB in PSRAM
I (2518) camera: Get minimum free size -1 KB in PSRAM
Guru Meditation Error: Core  0 panic'ed (StoreProhibited). Exception was unhandled.
means something goes abnormal with PSRAM?
Regards,
salbdch
Postby salbdch » Mon Jan 18, 2021 8:29 am
Well... problem solved.
In my case, problem caused because below one pin between
ESP32 and OV5640 was mistakenly disconnected.
Thanks for advice anyway!
Regards,
Users browsing this forum: Baidu [Spider] and 6 guests
