korvo_du1906实例无法编译成功 Unknown CMake command "add_prebuilt_library"
Posted: Thu Jan 14, 2021 7:56 am
by fleche
我之前做过很多esp32的实例,都没有问题;这次买了korvo_du1906的板,怎么都完不成
1. 我是完全下载了的,也是用的adf里面的idf版本。
git clone --recursive
https://github.com/espressif/esp-adf.git
2. 执行了idf里的Install,和export
- E:/iot/esp-adf/components/esp-adf-libs, Chip is esp32
-- Current board name is CONFIG_ESP32_KORVO_DU1906_BOARD
CMake Error at components/bdsc_engine/CMakeLists.txt:9 (add_prebuilt_library):
Unknown CMake command "add_prebuilt_library".
Re: korvo_du1906实例无法编译成功 Unknown CMake command "add_prebuilt_library"
Posted: Mon Jan 18, 2021 6:22 am
by HengYC
你好, 请更新到最新的 adf 版本, readme 文档说明的编译是需要 [IDF]: audio/stack_on_psram_v3.3 这个分支。
你按照文档说明操作一遍试试?
https://github.com/espressif/esp-adf/bl ... /README.md
Posted: Sat Feb 20, 2021 10:53 am
by sagesiot
楼主解决了么?我同样出现类似的问题:
Loading defaults file /home/gfzou/esp/esp-adf/examples/korvo_du1906/sdkconfig.defaults...
-- IDF_VER: v3.3.1-276-g606dd2b62
-- Project version: v1.3.0
-- Found PythonInterp: /home/gfzou/.espressif/python_env/idf3.3_py3.8_env/bin/python (found version "3.8.5")
-- Found Perl: /bin/perl (found version "5.30.0")
-- Adding linker script /home/gfzou/esp/esp-adf/examples/korvo_du1906/build/esp-idf/esp32/esp32_out.ld
-- Adding linker script /home/gfzou/esp/esp-adf/esp-idf/components/esp32/ld/esp32.extram.bss.ld
-- Adding linker script /home/gfzou/esp/esp-adf/esp-idf/components/esp32/ld/esp32.rom.ld
-- Adding linker script /home/gfzou/esp/esp-adf/esp-idf/components/esp32/ld/esp32.peripherals.ld
-- Adding linker script /home/gfzou/esp/esp-adf/esp-idf/components/esp32/ld/esp32.rom.libgcc.ld
-- Adding linker script /home/gfzou/esp/esp-adf/esp-idf/components/esp32/ld/esp32.rom.spiram_incompatible_fns.ld
-- /home/gfzou/esp/esp-adf/components/esp-adf-libs, Chip is esp32
See also "/home/gfzou/esp/esp-adf/examples/korvo_du1906/build/CMakeFiles/CMakeOutput.log".
See also "/home/gfzou/esp/esp-adf/examples/korvo_du1906/build/CMakeFiles/CMakeError.log".
cmake failed with exit code 1
Posted: Sun Apr 25, 2021 2:14 am
by HengYC
楼主解决了么?我同样出现类似的问题:
你好, DU1906 是较复杂的一个 ADF 例程,依赖 特殊IDF 分支和 patch, 请仔细阅读说明文档 README.md ,按照说明步骤操作,再尝试一下,谢谢!
Posted: Fri Sep 10, 2021 8:26 am
by ActonYuan
发现使用idf.py工具编译就会报这个错,通过make命令可以正常编译并烧录,供参考!
Posted: Mon Sep 13, 2021 9:14 am
by HengYC
audio/stack_on_psram_v3.3 这个分支,请使用 GNU make 方式来编译。
