ESP32 W5500
koryckid
ESP32 W5500
Postby koryckid » Thu Jan 14, 2021 12:34 pm
Hi
I am working on Ethernet project using W5500 and example common_components/protocol_examples_common.
And there is a few problem, in default configuration for SPI CLK PINis GPIO 20 is choosen, but i can't find this pin.
Is there any connection requirments like max cable length or specific pins to connect W5500 to ESP32?
Also default configuration for SPI_CLK is 36MHz but if i used that i get error about it should be use spi in half duplex mode?
Could someone tell me more about this?
Thank you.
Daniel
pdemianczuk
Re: ESP32 W5500
Postby pdemianczuk » Fri Jan 15, 2021 9:57 am
which demoboard or module do you use?
SPI is rather internal interface so You should prepare approprite PCB or short wires to testing
Do you check setting configuration in menuconfig/sdk.cfg file?
Users browsing this forum: Baidu [Spider] and 52 guests
