BLE: How change UUID16 by UUID128
GustavoGB
Postby GustavoGB » Fri Jan 15, 2021 1:58 am
Hello, I am using the example https://github.com/espressif/esp-idf/bl ... eat_demo.c that sets all UUIDs (Service and Characteristics) to 16 bits by default, however I am interested in setting them to 128 bits.
But I'm having a lot of problems since I don't know what to modify.
I'm pretty sure all I have to do is within the following code excerpt:
static const uint16_t GATTS_SERVICE_UUID_TEST      = 0x00FF;
static const uint16_t GATTS_CHAR_UUID_TEST_A       = 0xFF01;
static const esp_gatts_attr_db_t gatt_db[HRS_IDX_NB] =
    // Service Declaration
    [IDX_SVC]        =
    {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&primary_service_uuid, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
      sizeof(uint16_t), sizeof(GATTS_SERVICE_UUID_TEST), (uint8_t *)&GATTS_SERVICE_UUID_TEST}},
    /* Characteristic Declaration */
    [IDX_CHAR_A]     =
    {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_128, (uint8_t *)&character_declaration_uuid, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
      CHAR_DECLARATION_SIZE, CHAR_DECLARATION_SIZE, (uint8_t *)&char_prop_read_write}},
    /* Characteristic Value */
    [IDX_CHAR_VAL_A] =
    {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_128, (uint8_t *)&GATTS_CHAR_UUID_TEST_A, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
      GATTS_DEMO_CHAR_VAL_LEN_MAX, sizeof(char_value), (uint8_t *)char_value}},
If anyone has any advice to modify the code to get UUID128, I will be very grateful.
Thanks a lot :D :D
Gustavo
Minatel
Re: BLE: How change UUID16 by UUID128
Postby Minatel » Fri Jan 15, 2021 1:15 pm
You can take a look at the ANCS example to see how to deal with UUID128. I'm supposing that you are using bluedroid, not NimBLE, right?
https://github.com/espressif/esp-idf/tr ... e/ble_ancs
Minatel
Postby Minatel » Fri Jan 15, 2021 3:45 pm
You can also try to change the gatt_server example ESP-IDF Gatt Server Demo (for ESP-IDF version 4.2).
Change from:
#define GATTS_SERVICE_UUID_TEST_A   0x00FF
To:
uint8_t gatts_service_uuid128_test_a[ESP_UUID_LEN_16] = {0x06, 0x18, 0x7a, 0xec, 0xbe, 0x11, 0x11, 0xea, 0x00, 0x16, 0x02, 0x42, 0x01, 0x13, 0x00, 0x04};
And:
gl_profile_tab[PROFILE_A_APP_ID].service_id.id.uuid.len = ESP_UUID_LEN_16;
gl_profile_tab[PROFILE_A_APP_ID].service_id.id.uuid.uuid.uuid16 = GATTS_SERVICE_UUID_TEST_A;
To:
gl_profile_tab[PROFILE_A_APP_ID].service_id.id.uuid.len = ESP_UUID_LEN_128;
memcpy(gl_profile_tab[PROFILE_A_APP_ID].service_id.id.uuid.uuid.uuid128, gatts_service_uuid128_test_a,ESP_UUID_LEN_128);
Hope this could help you!
GustavoGB
Postby GustavoGB » Tue Jan 19, 2021 2:13 pm
Change from:
To:
And:
To:
Excellent ESP_Minatel!, works in this way. Only I had to do a little modification to your code.
In several places you put ESP_UUID_LEN_16, when it should be ESP_UUID_LEN_128 in all cases.
Thanks for your help, I couldn't have done it without you telling me.
I have another question to ask you, I don't know if we can follow this post or should I make a new one.
It is about modifying Characteristics Values from the same code during the execution of the program. I'm having trouble doing it as
esp_ble_gatts_set_attr_value(42, sizeof(char_value), (uint8_t *)char_value))
because doesn't seem to work.
If you want we do another post.
Again, thank you very much ESP_Minatel.
Gustavo
Minatel
Postby Minatel » Tue Jan 19, 2021 2:46 pm
Hi Gustavo,
You're welcome! :D
It's better to create a new topic and then we could help others on the same issue.
Tanuja Gudaje
Postby Tanuja Gudaje » Tue Jun 13, 2023 11:49 am
Hi ,
I am working on EP32 module as peripheral. and I am trying to add one more service in the gatts_gattc_coex .
I am not able to get the customized UUID in the android app.
#define GATTS_SERVICE_UUID_LOC_NAV 0x00DD
#define GATTS_CHAR_UUID_LOC_NAV 0xDD01
#define GATTS_NUM_HANDLE_LOC_NAV 3
Can you please help me get it work?
Kind Regards,
tanuja
Users browsing this forum: Applebot, ChatGPT-User, PetalBot and 6 guests
