Can the transmit power of wifi be set to -10dbm?
''Make menuconfig" can only set the transmit power of WiFi to 0dbm.Can the transmit power of wifi be set to -10dbm?If it can be set,how to set?
Re: Can the transmit power of wifi be set to -10dbm?
you know about tools and flash download tool?''Make menuconfig" can only set the transmit power of WiFi to 0dbm.Can the transmit power of wifi be set to -10dbm?If it can be set,how to set?
have not tested it for low energy - so you must play with it by self
rudi
after reading your question again,''Make menuconfig" can only set the transmit power of WiFi to 0dbm.Can the transmit power of wifi be set to -10dbm?If it can be set,how to set?
in menuconfig there is range 0..20 not sure - perhabs i misunderstand the question,
you want set the Tx -10dbm
or want you set the Tx 0dbm -10dbm?
why you want to set 0 lees than 0?
think you want set to 10dbm?
rudi
"flash download"'s RF config only works in esp8266 according to my test.after reading your question again,''Make menuconfig" can only set the transmit power of WiFi to 0dbm.Can the transmit power of wifi be set to -10dbm?If it can be set,how to set?
rudi
************I want to set the Tx to -10dbm.*****************
****************Because we want to save the power of battery.***********************
****************I dont want to set power to 10 dbm*****************
which version u use?"flash download"'s RF config only works in esp8266 according to my test.
rc2.0which version u use?"flash download"'s RF config only works in esp8266 according to my test.
you mean SDK version,rc2.0which version u use?"flash download"'s RF config only works in esp8266 according to my test.
i asked for the flash download tool version
3.4.5you mean SDK version,rc2.0
you mean 3.4.43.4.5you mean SDK version,rc2.0
I have tested 3.4.4.But RF congfig cannot set to -10 dbm for esp32.Have you tested -10dbm。you mean 3.4.43.4.5
我测试了flashdownload的3.4.4版本,无法为esp32将发射功率设置为-10dm。请问你是否测试过将esp32的发射功率设置为-10dbm?
