ESP32 and ethernet controller DM9051 stop working
fabiolikke
Postby fabiolikke » Sat Jan 16, 2021 10:00 pm
I made a board to verify the functionality of Esp32 Wroom 32D and the demo board of DM9051 the classic examples work correctly but I find a complicated problem to verify when I push the data exchange becomes voluminous and intense.
using the iperf example launched for 600 seconds there is an interruption in operation of the ethernet section after a short time not recoverable only with a reset the system can be recovered the system does not generate any warning or error in the console I cannot have a debug of the driver or the network layer that allows me to understand what happens
it appears to be an untracked error from the spi driver or network layer not tracked
rpress
Re: ESP32 and ethernet controller DM9051 stop working
Postby rpress » Mon Mar 22, 2021 7:32 pm
PeterR
Postby PeterR » Mon Mar 22, 2021 11:03 pm
As I read this; it does not work at volume on your board. I did not hear you say that it works at volume on an EVB.
Plz clarify. A simple trueth table would help.
When I read 'custom' its a fair bet to ask OP to post the 'custom' code or schematics. Post your schematics.
Users browsing this forum: ChatGPT-User, Google [Bot] and 2 guests
