Setting Target esp32s2 Fails
markjuggles
Postby markjuggles » Sun Jan 17, 2021 6:22 pm
I re-re-re-re-re-installed the ESP-IDF but cannot get the target changed to esp32s2.
C:\esp\projects\hello_world>idf.py set-target esp32s2
Adding "set-target"'s dependency "fullclean" to list of commands with default set of options.
Executing action: fullclean
Executing action: set-target
Set Target to: esp32s2, new sdkconfig created. Existing sdkconfig renamed to sdkconfig.old.
Running cmake in directory c:\esp\projects\hello_world\build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DIDF_TARGET=esp32s2 -DCCACHE_ENABLE=1 c:\esp\projects\hello_world"...
-- Found Git: C:/Program Files/Git/cmd/git.exe (found version "2.29.2.windows.3")
CMake Error at C:/esp/esp-idf/tools/cmake/targets.cmake:19 (message):
  IDF_TARGET in CMake cache does not match IDF_TARGET environment variable.
  To change the target, clear the build directory and sdkconfig file, and
  build the project again
  C:/esp/esp-idf/tools/cmake/project.cmake:35 (__target_init)
  CMakeLists.txt:5 (include)
cmake failed with exit code 1
Building the project will succeed but flashing it fails because I have an esp32s2 chip.
A fatal error occurred: This chip is ESP32-S2 not ESP32. Wrong --chip argument?
CMake Error at run_serial_tool.cmake:50 (message):
  C:/esp/.espressif/python_env/idf4.3_py3.9_env/Scripts/python.exe
  C:/esp/esp-idf/components/esptool_py/esptool/esptool.py --chip esp32 failed
My environment is the latest Python, the latest git, today's ESP-IDF master branch, and esp-idf-tools-setup-2.3.
git clone --recursive https://github.com/espressif/esp-idf.git
Can anyone tell me how to create a working ESP32S2 build environment?
Thank you
chegewara
Re: Setting Target esp32s2 Fails
Postby chegewara » Sun Jan 17, 2021 7:05 pm
Try to delete build folder in hello-world project, then set-target again.
markjuggles
Postby markjuggles » Sun Jan 17, 2021 8:12 pm
Same results.
C:\esp\projects\hello_world>rm -rf build
Build directory 'c:\esp\projects\hello_world\build' not found. Nothing to clean.
markjuggles
Postby markjuggles » Sun Jan 17, 2021 8:44 pm
Since following the instructions step by step wasn't working, I tried something different.
idf.py set-target esp32s2 # still fails
set IDF_TARGET=esp32s2 # just guessing
idf.py menuconfig
idf.py build
idf.py -p com15 flash
idf.py -p com15 monitor
It works!!!!
So hello_world is running. I will try a real networking project.... Wish me luck.
chegewara
Postby chegewara » Sun Jan 17, 2021 8:45 pm
Do you have by accident sdkconfig.default in project folder?
markjuggles
Postby markjuggles » Sun Jan 17, 2021 10:00 pm
There is a "sdkconfig.defaults" file.
I don't know which step created it but it wasn't in the original "esp-idf\examples\get-started\hello_world" folder.
chegewara
Postby chegewara » Sun Jan 17, 2021 11:53 pm
Is this set in sdkconfig.defaults:
CONFIG_IDF_TARGET=
markjuggles
Postby markjuggles » Mon Jan 18, 2021 2:16 am
No, after getting the project to work by setting the environment manually, the file contained this:
# Enable FATFS read only with long filename support
# for loading Cert/CA/etc from filesystem
# (if enabled in config)
CONFIG_FATFS_READONLY=y
CONFIG_FATFS_CODEPAGE_437=y
CONFIG_FATFS_LFN_HEAP=y
# Enable TLS asymmetric in/out content length
CONFIG_MBEDTLS_ASYMMETRIC_CONTENT_LEN=y
Going back to the 'blink' project which I had not configured via the environment, there was also a "sdkconfig.defaults" file but it only contained this:
ESP_Angus
Postby ESP_Angus » Mon Jan 18, 2021 5:07 am
Hi Mark,
I'm glad you were able to get the project to build, and sorry for all the hassles encountered.
This error, and the success you had with "set IDF_TARGET=esp32s2" seems to suggest that your system already had an environment variable named IDF_TARGET set. This isn't part of the getting started guide for recent ESP-IDF versions, is it possible this variable was set somehow while following an earlier/different set of steps?
If you open a new Command Prompt, can you get it to build without setting this variable? If you run "echo %IDF_TARGET%" in the same window, what do you see?
markjuggles
Postby markjuggles » Mon Jan 18, 2021 1:19 pm
I have evaluated several WiFi chips and have two products in production with competing radios. The ESP32 has the best price but by far the most challenging development environment.
Trying to re-build with a clean environment:
Created a CMD window.
Ran 'esp-idf\export.bat'.
C:\esp\projects\esp-aws-iot\aws-projects\subscribe_publish>idf.py build
Executing action: all (aliases: build)
Project sdkconfig was generated for target 'esp32s2', but environment variable IDF_TARGET is set to 'esp32'. Run 'idf.py set-target esp32' to generate new sdkconfig file for target esp32.
C:\esp\projects\esp-aws-iot\aws-projects\subscribe_publish>echo %IDF_TARGET%
esp32
Users browsing this forum: No registered users and 62 guests
