Setup:
1. Mac Catelina
2. ESP-IDF 4.0 (and I've tried 4.1)
3. Python 3.9
4. VSCode
When flashing my ESP-32 I receive the following FLASH error related to '/dev/ttyUSB1' (which is a linux port and I'm on mac):
$ /Users/nathan/.espressif/python_env/idf4.0.2_py3.9_env/bin/python
esptool.py v2.8
Serial port /dev/ttyUSB1
File "/Users/nathan/.espressif/python_env/idf4.0.2_py3.9_env/lib/python3.9/site-packages/serial/serialposix.py", line 322, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
FileNotFoundError: [Errno 2] No such file or directory: '/dev/ttyUSB1'
During handling of the above exception, another exception occurred:
File "/Users/nathan/esp/esp-idf/components/esptool_py/esptool/esptool.py", line 3201, in <module>
_main()
File "/Users/nathan/esp/esp-idf/components/esptool_py/esptool/esptool.py", line 3194, in _main
main()
File "/Users/nathan/esp/esp-idf/components/esptool_py/esptool/esptool.py", line 2883, in main
esp = ESPLoader.detect_chip(each_port, initial_baud, args.before, args.trace)
File "/Users/nathan/esp/esp-idf/components/esptool_py/esptool/esptool.py", line 273, in detect_chip
detect_port = ESPLoader(port, baud, trace_enabled=trace_enabled)
File "/Users/nathan/esp/esp-idf/components/esptool_py/esptool/esptool.py", line 237, in __init__
self._port = serial.serial_for_url(port)
File "/Users/nathan/.espressif/python_env/idf4.0.2_py3.9_env/lib/python3.9/site-packages/serial/__init__.py", line 90, in serial_for_url
instance.open()
File "/Users/nathan/.espressif/python_env/idf4.0.2_py3.9_env/lib/python3.9/site-packages/serial/serialposix.py", line 325, in open
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 2] could not open port /dev/ttyUSB1: [Errno 2] No such file or directory: '/dev/ttyUSB1'
The terminal process failed to launch (exit code: 1).
Terminal will be reused by tasks, press any key to close it.
- BUILDING works, just FLASH fails.
- Installed drivers (https://ftdichip.com/drivers/vcp-drivers/)
- And these drivers too (https://www.silabs.com/developers/usb-t ... cp-drivers)
- I can connect to the device (https://docs.espressif.com/projects/esp ... requisites) via:
ls /dev/cu.*
/dev/cu.Bluetooth-Incoming-Port /dev/cu.NathansAirPodRacers-Wir /dev/cu.SLAB_USBtoUART /dev/cu.SRS-XB10-CSRGAIA /dev/cu.usbserial-0001
then run...
screen /dev/cu.SLAB_USBtoUART 115200
... (output from the esp32)
