Powering ESP32 module directly
buster
Postby buster » Sun Jan 24, 2021 11:47 am
I have used a development board like this: Image
Everything works perfect but now i want to use the WRover module without this board.
I tried to connect 3.3V from a bench power supply but the module won't start. I read something about GPIO0 and EN pin but i cannot find any information on how to start the EPS32 WRover without the development board.
I am sorry but i am really new to ESP32.
Did i forget something or should it work with just connecting 3.3V to the 3.3V pin and 1 ground to the ground pin?
Thanks a lot!
Michalpu
Re: Powering ESP32 module directly
Postby Michalpu » Sun Jan 24, 2021 1:41 pm
Look at this datasheet at topic 7 https://www.espressif.com/sites/default ... eet_en.pdf
There is connection schematics which should help
Content creator at https://911electronic.com
WiFive
Postby WiFive » Sun Jan 24, 2021 4:56 pm
https://docs.espressif.com/projects/esp ... index.html
Hardware design guidelines and reference schematics are available
buster
Postby buster » Sun Jan 24, 2021 6:33 pm
Thank you, i got it working
Users browsing this forum: Bing [Bot], PetalBot and 1 guest
