We need two 2 pins for connecting I2C slave device to a ESP-EYE development board. Are there pins available that we can access with some SMD soldering work?
Please help. Any information positive or negative will help.
Thanks.
Need to attach an I2C device to ESP EYE
Re: Need to attach an I2C device to ESP EYE
I think that only have SPI port
https://wiki.dfrobot.com/ESP-EYE%20Deve ... %20DFR0620
Content creator at https://911electronic.com
Check the schematic
https://pbs.twimg.com/media/DxBt7mGUwAA-CoH.jpg:large
Look at connector J2, the display uses I2C. You could carefully solder to the connector pins. They connect to io18 and 23
