https://github.com/loboris/ESP32_TFT_library
Features
- Full support for ILI9341 & ILI9488 based TFT modules in 4-wire SPI mode. Support for other controllers will be added later
- 18-bit (RGB) color mode used
- SPI displays oriented SPI driver based on spi-master driver. Does not use queues like spi-master to improve speed.
- Combined DMA SPI transfer mode and direct SPI to improve speed
- Grayscale mode can be selected during runtime which converts all colors to gray scale
- SPI speeds up to 40 MHz are tested and works without problems
- Demo application included which demonstrates most of the library features
- TFT_drawPixel Draw pixel at given x,y coordinates
- TFT_drawLine Draw line between two points
- TFT_drawFastVLine, TFT_drawFastHLine Draw vertical or horizontal line of given lenght
- TFT_drawLineByAngle Draw line on screen from (x,y) point at given angle
- TFT_drawRect, TFT_fillRect Draw rectangle on screen or fill given rectangular screen region with color
- TFT_drawRoundRect, TFT_fillRoundRect Draw rectangle with rounded corners or fill given rectangular screen region with rounded corners
- TFT_drawCircle, TFT_fillCircle Draw or fill circle on screen
- TFT_drawEllipse, TFT_fillEllipse Draw or fill ellipse on screen
- TFT_drawTriangel, TFT_fillTriangle Draw or fill triangle on screen
- TFT_drawArc Draw circle arc on screen, from start angle to end angle, with given thickness. Can be outlined with different color
- TFT_drawPolygon Draw poligon on screen with given number of sides (3~60). Can be outlined with different color and rotated by given angle.
- fixed width and proportional fonts are supported; 8 fonts embeded
- unlimited number of fonts from file
- 7-segment vector font with variable width/height is included (only numbers and few characters)
- Proportional fonts can be used in fixed width mode.
- Related functions:
- TFT_setFont Set current font from one of embeded fonts or font file
- TFT_getfontsize Returns current font height & width in pixels.
- TFT_getfontheight Returns current font height in pixels.
- set_7seg_font_atrib Set atributes for 7 segment vector font
- getFontCharacters Get all font's characters to buffer
- TFT_print Write text to display.
- Strings can be printed at any angle. Rotation of the displayed text depends on font_ratate variable (0~360)
- if font_transparent variable is set to 1, no background pixels will be printed
- If the text does not fit the screen/window width it will be clipped ( if text_wrap=0), or continued on next line ( if text_wrap=1)
- Two special characters are allowed in strings: \r (CR, 0x0D), clears the display to EOL, \n (LF, 0x0A), continues to the new line, x=0
- Special values can be entered for X position:
- CENTER centers the text
- RIGHT right justifies the text horizontaly
- LASTX continues from last X position; offset can be used: LASTX+n
- Special values can be entered for Y:
- CENTER centers the text verticaly
- BOTTOM bottom justifies the text
- LASTY continues from last Y position; offset can be used: LASTY+n
- TFT_getStringWidth Returns the string width in pixels based on current font characteristics. Useful for positioning strings on the screen.
- TFT_clearStringRect Fills the rectangle occupied by string with current background color
- TFT_jpg_image Decodes and displays JPG images
- Limits:
- Baseline only. Progressive and Lossless JPEG format are not supported.
- Image size: Up to 65520 x 65520 pixels
- Color space: YCbCr three components only. Gray scale image is not supported.
- Sampling factor: 4:4:4, 4:2:2 or 4:2:0.
- Can display the image from file or memory buffer
- Image can be scaled by factor 0 ~ 3 (1/1, 1/2, 1/4 or 1/8)
- Image is displayed from X,Y position on screen/window:
- X: image left position; constants CENTER & RIGHT can be used; negative value is accepted
- Y: image top position; constants CENTER & BOTTOM can be used; negative value is accepted
- TFT_bmp_image Decodes and displays BMP images
- Only uncompressed RGB 24-bit with no color space information BMP images can be displayed
- Image can be scaled by factor 0 ~ 7; if scale>0, image is scaled by factor 1/(scale+1)
- Drawing on screen can be limited to rectangular window, smaller than the full display dimensions
- When defined, all graphics, text and image coordinates are translated to window coordinates
- Related functions
- TFT_setclipwin Sets the window area coordinates
- TFT_resetclipwin Reset the window to full screen dimensions
- TFT_saveClipWin Save current window to temporary variable
- TFT_restoreClipWin Restore current window from temporary variable
- TFT_fillWindow Fill window area with color
- for now only XPT2046 and compatible controllers are supported
- TFT_read_touch Detect if touched and return X,Y coordinates. Raw touch screen or calibrated values can be returned.
- calibrated coordinates are adjusted for screen orientation.
- TFT_readPixel Read pixel color value from display GRAM at given x,y coordinates.
- TFT_readData Read color data from rectangular screen area
- TFT_fillScreen Fill the whole screen with color
- TFT_setRotation Set screen rotation; PORTRAIT, PORTRAIT_FLIP, LANDSCAPE and LANDSCAPE_FLIP are supported
- TFT_invertDisplay Set inverted/normal colors
- TFT_compare_colors Compare two color structures
- disp_select() Activate display's CS line
- disp_deselect() Deactivate display's CS line
- find_rd_speed() Find maximum spi clock for successful read from display RAM
- TFT_display_init() Perform display initialization sequence. Sets orientation to landscape; clears the screen. SPI interface must already be setup, tft_disp_type, _width, _height variables must be set.
- HSBtoRGB Converts the components of a color, as specified by the HSB model to an equivalent set of values for the default RGB model.
- compile_font_file Function which compiles font c source file to binary font file which can be used in TFT_setFont() function to select external font. Created file has the same name as source file and extension .fnt
- orientation current screen orientation
- font_rotate current font rotate angle (0~395)
- font_transparent if not 0 draw fonts transparent
- font_forceFixed if not zero force drawing proportional fonts with fixed width
- text_wrap if not 0 wrap long text to the new line, else clip
- _fg current foreground color for fonts
- _bg current background for non transparent fonts
- dispWin current display clip window
- _angleOffset angle offset for arc, polygon and line by angle functions
- image_debug print debug messages during image decode if set to 1
- cfont Currently used font structure
- TFT_X X position of the next character after TFT_print() function
- TFT_Y Y position of the next character after TFT_print() function
- tp_calx touch screen X calibration constant
- tp_caly touch screen Y calibration constant
- gray_scale convert all colors to gray scale if set to 1
- max_rdclock current spi clock for reading from display RAM
- _width screen width (smaller dimension) in pixels
- _height screen height (larger dimension) in pixels
- tft_disp_type current display type (DISP_TYPE_ILI9488 or DISP_TYPE_ILI9341)
Full functions syntax and descriptions can be found in tft.h and tftspi.h files.
Full demo application, well documented, is included, please analyze it to learn how to use the library functions.
Connecting the display
To run the demo, attach ILI9341 or ILI9488 based display module to ESP32. Default pins used are:
- mosi: 23
- miso: 19
- sck: 18
- CS: 5 (display CS)
- DC: 26 (display DC)
- TCS: 25 (touch screen CS)
if you want to use the touch screen functions, set #define USE_TOUCH 1 in tftspi.h
Using make menuconfig select tick rate 1000 ( → Component config → FreeRTOS → Tick rate (Hz) ) to get more accurate timings
How to build
Configure your esp32 build environment as for other ESP32 projects and esp-idf examples.
Clone the repository
git clone https://github.com/loboris/ESP32_TFT_library.gitNavigate to TFT Display DEMO Configuration and set SPIFFS options (or just use defaults, recommended for this demo).
Select if you want to use wifi to get the time from NTP server and set your WiFi SSID and password.
make menuconfigCode: Select all
make all && make flashThe demo uses some image and font files and it is necessary to flash the spiffs image
To flash already prepared image (components/spiffs_image/image/spiffs_image.img), execute:
make copyfsYou can also prepare different SFPIFFS image and flash it to ESP32 if you want to include your own files.
Tested and works under Linux, Windows and Mac OS.
Files to be included on spiffs are in components/spiffs_image/image/ directory. You can add more files or remove the existing files.
When the file system content is prepared, execute:
make makefsOr execute:
make flashfsMore info about using SPIFFS on ESP32: viewtopic.php?f=18&t=1901&p=8924#p8924
