Can't set SPI registers with ESP-IDF V4
Posted: Mon Feb 08, 2021 6:01 am
by IanKibblewhite
Code: Untitled.c Select all
Hi All,
I have an ESP32 project using VSPI. It runs great on ESP-IDF V3.0 but the SPI won't run after moving to V4.2. I eventually traced it to a problem setting the VSPI registers.
For example, I read VSPI_CLOCK_REG (0x3ff65018), it's 0x80003043. I set it to 0x00001001 with either direct register write or using WRITE_PERI_REG (VSPI_CLOCK_REG, 0x00001001); When I read it immediately after it appears to be set, but with the second and subsequent reads it's back to it's original value, 0x80003043.
Same problem for all VSPI registers (0x3ff65xxx) and also HSPI registers (0x3ff64xxx), always with V4.n, works fine with V3.0. I thought it may be project code or config related so I tested in the hello_world example running on a DevKitC just adding:
printf("\n HSPI_CLOCK_REG \t\t %08x %08x %08x\n\n", HSPI_CLOCK_REG, 0x3FF64018, *((int*) 0x3FF64018));
WRITE_PERI_REG (HSPI_CLOCK_REG, 0x00001001); // SPI Clock f_SPI = 160MHz/(n+1), 0x00001001 = 40MHz (SYSCLK 40MHZ clock)
printf(" HSPI_CLOCK_REG \t\t %08x %08x %08x\n", HSPI_CLOCK_REG, 0x3FF64018, *((int*) 0x3FF64018));
printf(" HSPI_CLOCK_REG \t\t %08x %08x %08x\n\n", HSPI_CLOCK_REG, 0x3FF64018, *((int*) 0x3FF64018));
Get with V4.2
80003043
00001001
80003043
80003043
Get with V3.0
80003043
00001001
00001001
00001001
Anyone got any ideas on what could cause this and a workaround?
Many thanks,
Ian
Re: Can't set SPI registers with ESP-IDF V4
Posted: Mon Feb 08, 2021 7:35 am
by Sprite
Is it possible the SPI device is still clockgated / kept in reset? 3.0 is a while ago, could be that it didn't disable the SPI peripheral while not in use.
Posted: Fri Feb 12, 2021 1:52 am
by IanKibblewhite
You got it. Fantastic! It appears that v3.0 initializes with SPI's enabled. v4.2 initializes with SPI's disabled. All it took was:
DPORT_SET_PERI_REG_MASK (DPORT_PERIP_CLK_EN_REG, 0x00010000); // Enable VSPI Clock thru' DPORT
DPORT_CLEAR_PERI_REG_MASK (DPORT_PERIP_RST_EN_REG, 0x00010000); // Disable VSPI Reset
at initialization and problem solved. Thanks so much for your help. Really appreciated!
Ian
