ESP32 receive broadcast UDP packets
sensors
Postby sensors » Mon Feb 08, 2021 1:55 pm
I'm attempting to configure a number of connected ESP32 stations using a single ESP32 AP. The easiest way for me to do this would be to send a single broadcast UDP packet to 255.255.255.255. However, my stations who are listening with an open UDP port are not receiving broadcast data at all. Is there something else I need to configure on the station/AP for this to be possible?
Here's my current station UDP listening task:
static void udp_listen_task(void *pvParameters)
    while (1) {
        struct sockaddr_in dest_addr;
        dest_addr.sin_addr.s_addr = htonl(INADDR_ANY);
        dest_addr.sin_family = AF_INET;
        dest_addr.sin_port = htons(PORT);
        int addr_family = AF_INET;
        int ip_protocol = IPPROTO_IP;
        inet_ntoa_r(dest_addr.sin_addr, addr_str, sizeof(addr_str) - 1);
        int sock = socket(addr_family, SOCK_DGRAM, ip_protocol);
        if (sock < 0) {
            ESP_LOGE(TAG, "Unable to create socket: errno %d", errno);
        //ESP_LOGI(TAG, "Socket created");
        int err = bind(sock, (struct sockaddr *)&dest_addr, sizeof(dest_addr));
        if (err < 0) {
            ESP_LOGE(TAG, "Socket unable to bind: err %d", err);
        while (1) {
            struct sockaddr_in6 source_addr;
            socklen_t socklen = sizeof(source_addr);
            int len = recvfrom(sock, &controller_msg, sizeof(controller_msg), 0, (struct sockaddr *)&source_addr, &socklen);
            //Error occurred during receiving
            if (len < 0) {
                ESP_LOGE(TAG, "recvfrom failed: errno %d", errno);
            // Data received
            else {
                // Get the sender's ip address as string
                if (source_addr.sin6_family == PF_INET) {
                    inet_ntoa_r(((struct sockaddr_in *)&source_addr)->sin_addr.s_addr, addr_str, sizeof(addr_str) - 1);
                } else if (source_addr.sin6_family == PF_INET6) {
                    inet6_ntoa_r(source_addr.sin6_addr, addr_str, sizeof(addr_str) - 1);
                // Post event to act on message
                xEventGroupSetBits(conn_evt, CONN_EVT_UDP_RECEIVED);
        if (sock != -1) {
            ESP_LOGE(TAG, "Shutting down socket and restarting...");
            shutdown(sock, 0);
            close(sock);
    vTaskDelete(NULL);
Venketraj
Re: ESP32 receive broadcast UDP packets
Postby Venketraj » Fri Feb 12, 2021 11:13 am
can you post the full code to analyse it
Magnetuz
Postby Magnetuz » Tue Nov 23, 2021 9:34 am
Hello sensors,
I am having the same problem. Did you find a solution?
Regards.
Users browsing this forum: No registered users and 9 guests
