ESP32-S2 Arduino UART1 & USB problem
Posted: Tue Feb 09, 2021 4:33 pm
by allenpan
Hello i got 2 problems:
1) UART1, how do i defined the pin? i believe default GPIO18 = UART1RX and GPIO17 = UART1TX, but i can't seems to get it working with HardwareSerial or just simply calling Serial1... also how do i remap UART1's pins?
2) i use the USB example, to create USBCDC in arduino, but i can't get my pc/host to detect the USB serial connection
Re: ESP32-S2 Arduino UART1 & USB problem
Posted: Tue Feb 09, 2021 6:03 pm
by Miraculix
I think you need to install this driver. And compile your code with CDC enabled.
https://github.com/hathach/tinyusb
Posted: Tue Feb 09, 2021 6:55 pm
by chegewara
No, it is already compiled in arduino-esp32.
This example requires to connect pins 19/20 (D+/D-) to USB port. You can cut regular USB cable.
https://docs.espressif.com/projects/esp ... connection
