Bluetooth problem
sarosead
Bluetooth problem
Postby sarosead » Wed Feb 17, 2021 2:23 am
Code: Untitled.txt Select all
I have used 5 Oled for displaying 5 different sensor values. It was working fine but when i use bluetooth, one Oled which is connected to GPIO pins 01 and 03 is not working and other 4 Oled are working. If i keep bluetooth code that oled wont work and if i again dump another code which donot include bluetooth program then all oled is working. Why it is happening? What may be the problem?
I have shown pins that i have used for Oled(SDA , SCL) and Sensors(S0-S4) in image below.
Re: Bluetooth problem
Postby Sprite » Wed Feb 17, 2021 11:10 am
That can be anything... BT should not affect I2C communication, so it's either something in your software, or perhaps the extra current used by BT upsets the OLED somehow.
