ESP32 with Ethernet and WiFiClientSecure
Posted: Sat Feb 20, 2021 6:05 pm
by nmaas87
Dear all,
I try to get an ESP32 running with an W5500 Ethernet controller and the possibility to use Arduino-MQTT ( https://github.com/256dpi/arduino-mqtt ) for MQTTS / secure MQTT.
First things first, the Arduino-Ethernet Library is widely used, however it does not work with ESP32 out of the box anymore.
According to the developers, Espressif changed libaries and are to blame for that. They had an pull request which would have fixed the issue in the library, but closed it now ( https://github.com/arduino-libraries/Ethernet/pull/107 )
So you have to get this https://github.com/arduino-libraries/Et ... Ethernet.h Ethernet.h and replaces it with the one in your default Ethernet library.
After this, I wired my W5500 module according to this
MISO = GPIO19
MOSI = GPIO23
RST = GPIO5
SCS = GPIO33
SCLK = GPIO18
GND = GND
and had to set Ethernet.init(33);
The resulting/working code to connect via Ethernet to MQTT was this:
Code: Untitled.c Select all
// This example uses an Arduino Uno together with
// an Ethernet Shield to connect to shiftr.io.
// You can check on your device after a successful
// connection here: https://shiftr.io/try.
// by Joël Gähwiler
// https://github.com/256dpi/arduino-mqtt
#include <SPI.h>
#include <Ethernet.h>
#include <MQTT.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
byte ip[] = {192, 168, 4, 177}; // <- change to match your network
EthernetClient net;
MQTTClient client;
unsigned long lastMillis = 0;
void connect() {
Serial.print("connecting...");
while (!client.connect("arduino", "public", "public")) {
Serial.print(".");
delay(1000);
Serial.println("\nconnected!");
client.subscribe("/hello4711");
// client.unsubscribe("/hello");
void messageReceived(String &topic, String &payload) {
Serial.println("incoming: " + topic + " - " + payload);
// Note: Do not use the client in the callback to publish, subscribe or
// unsubscribe as it may cause deadlocks when other things arrive while
// sending and receiving acknowledgments. Instead, change a global variable,
// or push to a queue and handle it in the loop after calling `client.loop()`.
void setup() {
Serial.begin(115200);
Ethernet.init(33);
Ethernet.begin(mac, ip);
// Note: Local domain names (e.g. "Computer.local" on OSX) are not supported
// by Arduino. You need to set the IP address directly.
client.begin("public.cloud.shiftr.io", net);
client.onMessage(messageReceived);
connect();
void loop() {
client.loop();
delay(10); // <- fixes some issues with WiFi stability
if (!client.connected()) {
connect();
// publish a message roughly every second.
if (millis() - lastMillis > 1000) {
lastMillis = millis();
client.publish("/hello4711", "world");
However, I now need to use MQTTS via Ethernet.
For Wifi with ESP32, the library uses WifiClientSecure.
Is there any way to somehow connect the WifiClientSecure with the already existing socket of the Ethernet library and use the SSL functionality to make the connection?
Code for ESP32 MQTTS via Wifi
// This example uses an ESP32 Development Board
// to connect to shiftr.io.
// by Joël Gähwiler
#include <WiFiClientSecure.h>
#include <MQTT.h>
const char ssid[] = "";
const char pass[] = "";
WiFiClientSecure net;
MQTTClient client;
void connect() {
Serial.print("checking wifi...");
Serial.print(".");
delay(1000);
Serial.print("\nconnecting...");
Serial.print(".");
delay(1000);
void setup() {
WiFi.begin(ssid, pass);
// MQTT brokers usually use port 8883 for secure connections.
client.begin("public.cloud.shiftr.io", 8883, net);
connect();
void loop() {
client.loop();
connect();
client.publish("/hello", "world");
Thanks!
Re: ESP32 with Ethernet and WiFiClientSecure
Posted: Wed Apr 05, 2023 12:47 pm
by SamLaserray
Hello!
Did you manage to make it work?
Posted: Fri Apr 07, 2023 1:04 am
by nmaas87
Nope
Posted: Mon Feb 26, 2024 2:54 pm
by FiwiDev
You cannot use the WiFiClientSecure library with anything else--it's internally bound to the WiFi module.
However, you can use a wrapper library that utilizes the exact same mbedTLS functionality under the hood--and assign it to any device library that implements Client. I personally suggest https://github.com/alkonosst/SSLClientESP32/ as it utilizes the mbedTLS instance provided in the Arduino-ESP32 library.
