Debugging custom ESP32-SOLO-1 board
Posted: Tue Mar 09, 2021 9:21 am
Hi all,
I've designed a custom board using the ESP32-solo-1. I'm using JTAG (JLink) to flash and debug it (currently from command line, intent to switch to Eclipse when everything is working).
I can flash it just fine with the following command:
The console log shows that verification was OK.
When I then start a debug session (from a second terminal) using, the temporary breakpoint at app_main() is never hit.
I've recompiled the app_template IDF example with FreeRTOS configured to use only a single core.
When I use a DevKitC V4 development board (with ESP32-WROOM-32D), the previous commands will indeed result in GDB stopping at the app_main() breakpoint. So it seems the JTAG setup and application are fine.
How can I verify why my custom board never hits the app_main() breakpoint?
Thanks in advance.
Kind regards,
Remco Poelstra
openocd -f interface/jlink.cfg -f target/esp32-solo-1.cfg -c "program_esp /Users/remco/eclipse-workspace/IDFTest/build/app-template.bin 0x10000 verify"When I then start a debug session (from a second terminal) using
xtensa-esp32-elf-gdb -x gdbinit ~/eclipse-workspace/IDFTest/build/app-template.elfI've recompiled the app_template IDF example with FreeRTOS configured to use only a single core.
Thanks in advance.
Kind regards,
Remco Poelstra
