[INFO] Soft-USB-OTG on ESP32 (ESP-IDF & Arduino ) done ...
Postby rudi ;-) » Tue Mar 16, 2021 9:36 pm
short & dirty
hi folks,
from now you can use USB-OTG by SOFTWARE on an ESP32.
ESP32 can do usb-soft-host, it's still limited to some HID classes but very promising
it is based on GPIO and the timer in this projects.
details:
ESP32 software USB host through general IO pins. We can connect up to 4 USB-LS HID (keyboard mouse joystick) devices simultaneously.
you find the work for ESP-IDF here
and you find the Arduino wrapp there
credits:
ESP-IDF Version: Samsonov Dima
ESP32 USB Soft Host library for Arduino IDE: TobozoTagada
now you can combine ESP32 which has no USB - with a simply software solution by
SOFT-USB-HOST
following work comes also for MicroPython..
credit: Samsonov Dima
ESP-IDF example (credit: Samsonov Dima)
/* Blink Example
#include <stdio.h>
#include <time.h>
#include <sys/time.h>
#include <string.h>
#include "freertos/task.h"
#include "driver/gpio.h"
#include "sdkconfig.h"
#include "hal/timer_ll.h"
/* Can run 'make menuconfig' to choose the GPIO to blink,
   or you can edit the following line and set a number here.
#include "freertos/queue.h"
#include "driver/periph_ctrl.h"
#include "driver/timer.h"
#include "soc/soc.h"
#include "soc/periph_defs.h"
#include "esp_log.h"
#include "usb_host.h"
void IRAM_ATTR timer_group0_isr(void *para)
	timer_group_clr_intr_status_in_isr(TIMER_GROUP_0, TIMER_0);
	usb_process();
	timer_group_enable_alarm_in_isr(TIMER_GROUP_0, TIMER_0);
#define BLINK_GPIO CONFIG_BLINK_GPIO
#define DP_P  16
#define DM_P  17
#define DP_P1  22
#define DM_P1  23
#define DP_P2  18
#define DM_P2  19
#define DP_P3  13
#define DM_P3  15
void led(int on_fff)
			gpio_set_level(BLINK_GPIO, on_fff);
void timer_task(void *pvParameter)
	    timer_config_t config = {
        .divider = TIMER_DIVIDER,
        .counter_dir = TIMER_COUNT_UP,
        .counter_en = TIMER_PAUSE,
        .alarm_en = TIMER_ALARM_EN,
        .auto_reload = 1,
    }; // default clock source is APB
    initStates(DP_P,DM_P,DP_P1,DM_P1,DP_P2,DM_P2,DP_P3,DM_P3);
  //  initStates(DP_P,DM_P,-1,-1,-1,-1,-1,-1);
    gpio_pad_select_gpio(BLINK_GPIO);
    gpio_set_direction(BLINK_GPIO, GPIO_MODE_OUTPUT);
    int timer_idx = TIMER_0;
    double timer_interval_sec = TIMER_INTERVAL0_SEC;
     timer_init(TIMER_GROUP_0, timer_idx, &config);
    timer_set_counter_value(TIMER_GROUP_0, timer_idx, 0x00000000ULL);
    timer_set_alarm_value(TIMER_GROUP_0, timer_idx, timer_interval_sec * TIMER_SCALE);
    timer_enable_intr(TIMER_GROUP_0, timer_idx);
    timer_isr_register(TIMER_GROUP_0, timer_idx, timer_group0_isr,(void *) timer_idx, ESP_INTR_FLAG_IRAM, NULL);
    timer_start(TIMER_GROUP_0, timer_idx);
    while(1)
	    printState();
	    vTaskDelay(10 / portTICK_PERIOD_MS);
void blink_task(void *pvParameter)
    /* Configure the IOMUX register for pad BLINK_GPIO (some pads are
       muxed to GPIO on reset already, but some default to other
       functions and need to be switched to GPIO. Consult the
       Technical Reference for a list of pads and their default
       functions.)
    while(1) {
		vTaskDelay(100 / portTICK_PERIOD_MS);
void app_main()
    xTaskCreatePinnedToCore(&timer_task, "timer_task", 4096, "task 0", 5, NULL,1);
    xTaskCreatePinnedToCore(&blink_task, "blink_task", 4096, "task 1", 5, NULL,0);
   printf("Hello world end!\n");
credit: TobozoTagada
Arduino example
#include <ESP32-USBSoftHost.hpp>
// set pin numbers here
#define DP_P0  16  // always enabled
#define DM_P0  17  // always enabled
#define DP_P1  22 // -1 to disable
#define DM_P1  23 // -1 to disable
#define DP_P2  18 // -1 to disable
#define DM_P2  19 // -1 to disable
#define DP_P3  13 // -1 to disable
#define DM_P3  15 // -1 to disable
usb_pins_config_t USB_Pins_Config =
  DP_P0, DM_P0,
  DP_P1, DM_P1,
  DP_P2, DM_P2,
  DP_P3, DM_P3
static void USB_SoftHostTimerTask(void *arg)
  while (1) {
    timer_event_t evt;
    xQueueReceive(timer_queue, &evt, portMAX_DELAY);
    printState();
static void my_USB_PrintCB( uint8_t* data, uint8_t data_len )
  printf("in :");
  for(int k=0;k<data_len;k++) {
    printf("%02x ",data[k]);
  printf("\n");
void setup()
  setPrintCb( &my_USB_PrintCB );
  usb_init( USB_Pins_Config );
  xTaskCreatePinnedToCore(&USB_SoftHostTimerTask, "USB Soft Host Timer Task", 4096, NULL, 5, NULL, 1);
void loop()
  vTaskDelete(NULL);
